Old 02-25-2016, 10:31 PM   #26
CABLESCUM
CABLESCUM's Avatar
Re: '72 GMC Shortbed Stepside...last truck
I dropped a couple trucks before, but not a 67-72.
I did a bunch of measuring today.
The measurements to the tops of each wheel well are 33" if the tires were the same size.
(I didn't figure out if the tops of the wheel wells are a "level" measurement yet, just starting the process)
Now, the tires are 1" shorter in front.
I'm thinking I'll get the drop kit off Summt+drop spindles.
5" drop springs for the rear, and 2" on the front(the spindles are 2.5" drop)
Any minor leveling or rake I need can be adjusted with the wheel/tire setup, it should be minimal.
I'm looking for EVEN, or a VERY slightly higher rear end...
I know many of you have spent the time and money to figure this out already, your experienced comments would be greatly appreciated.
I need a new goat, mine is worn the hell out!
MY TRUCK: https://67-72chevytrucks.com/vboard/...d.php?t=698511
MY SONS TRUCK: https://67-72chevytrucks.com/vboard/...d.php?t=812054
CABLESCUM is offline   Reply With Quote
Old 02-26-2016, 10:36 PM   #27
CABLESCUM
CABLESCUM's Avatar
Wheels/tires are the last thing it'll get.
It'll be mini-rubbed, just to the frame...so I can cram 4" wider tires under it.
Until I get it dropped, and see how it sit, choose tire size and all that...I got these to make it look a tiny bit better...
...I'm adding up the cost of everything. Realistically, this thing will be completed the way I want it in approximately 1 year. I'm setting my goal for 5/12/2018(birthday)...I always meet my deadlines lol
Old 02-29-2016, 01:48 PM   #28
CABLESCUM
CABLESCUM's Avatar
I guess these are hard to find, so I made it look a little nicer. I'll try to work the dents out when I start on the bodywork.
My buddy got one from Classic Industries and was not pleased, paid the $100 shipping to return it.
Old 03-08-2016, 11:17 PM   #29
CABLESCUM
CABLESCUM's Avatar
Found a bumper...it'll do for now
Old 03-12-2016, 10:30 PM   #30
CABLESCUM
CABLESCUM's Avatar
A little surgery. Should be all tacked up tomorrow, ready to solid weld...
The rear will be shaved(even with my hand) and welded solid. Smooth except for the GMC cut-out. The rounded rails will be continued all the way around the bed. LED tail lights in the columns on each side...
Old 03-13-2016, 08:51 PM   #31
CABLESCUM
CABLESCUM's Avatar
Got it all tacked up. I'll finish the welds another day, then bodywork and a coat of white 'til it's time for the real paint job.
After its dropped, I'll make a proper bumper which will cover some of the lower part of the "tailgate"...
Old 03-14-2016, 09:26 PM   #32
Rod Run
Rod Run's Avatar
Originally Posted by CABLESCUM View Post
I took off the bumpers, rubbed off some rust stains, changed the oil....it is wickedly fast. It's a 402, which is a 396 w/454 head because GM ran out of 396 heads
It has nothing to do with the heads. A 402 was just a 396 with a .030 overbore. If you bore it another .030 (for a total bore of .060) it becomes a 408, which is what I did to the one in my 1969 Camaro
Chevrolet came out with the 402 in 1970 in light trucks (including El Caminos). They still used the same anemic oval port closed chamber heads that most 396s came with. The only 396s that came with the better heads were the L78 (375HP) and none of the 402s came with those better heads.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-14-2016, 09:52 PM   #33
CABLESCUM
CABLESCUM's Avatar
Good enough 'til final bony/paint work, I'll insert the LEDs when I get a minute...
Old 03-14-2016, 10:05 PM   #34
CABLESCUM
CABLESCUM's Avatar
Thanks, I was made aware of that earlier in this thread. What my dad taught me was not Gospel lol
Old 03-26-2016, 10:31 AM   #35
Rod Run
Rod Run's Avatar
It happens
Old 03-27-2016, 12:13 AM   #36
AKC
AKC's Avatar
Likin' it a lot! Great score, diggin' the work so far.
That's the way to recycle newspaper!
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline   Reply With Quote
Old 03-27-2016, 11:57 PM   #37
CABLESCUM
CABLESCUM's Avatar
Just grabbing cheap CL parts as I go. Valve covers today from what turned out to be a tweeker living in a pop-up in a storage lot....good times lol
I'm kinda glad my appearance has a calming effect on even the most radical individuals haha...
Old 04-02-2016, 01:14 AM   #38
CABLESCUM
CABLESCUM's Avatar
That was a Summit catalog lmmfao
Old 04-03-2016, 10:19 PM   #39
CABLESCUM
CABLESCUM's Avatar
Finally got the Holley dialed in, it's SO much stronger...was definitely under-carbed.
Now I have to adjust the rockers to get rid of that clatter, this thing doesn't burn a drop of oil.
BB/FTW...
http://youtu.be/IG127rMIIbQ
Old 04-03-2016, 11:08 PM   #40
AKC
AKC's Avatar
So it is...
Lord knows, they send enough of them.
Covers look good, glad she's drinkin' better.
Old 05-22-2016, 11:24 PM   #41
CABLESCUM
CABLESCUM's Avatar
Picked up some 2" drop spindles, and made a new bumper. Not sure where the plate is gonna end up...
Old 06-01-2016, 10:01 PM   #42
CABLESCUM
CABLESCUM's Avatar
Shaved the tail lights and put in a "hidden" light bar. I made this bracket to bolt in, but it is so tight I don't need bolts...pops in like Legos
Old 06-16-2016, 10:19 AM   #43
CABLESCUM
CABLESCUM's Avatar
Finished welding on the tailgate. Dusted it w/ paint to prevent rust til bodywork. Buying the drop kit in 2 weeks...
Old 07-24-2016, 02:31 AM   #44
CABLESCUM
CABLESCUM's Avatar
Steps and 42 holes fixed(ready for bodywork)...
Old 07-24-2016, 02:33 AM   #45
CABLESCUM
CABLESCUM's Avatar
Old 07-25-2016, 12:47 AM   #46
CABLESCUM
CABLESCUM's Avatar
IDK what I'll do in the end. Just don't want to shave the markers off good original fenders, so I made them less horrible.
They'll be less noticeable when the truck is painted...black.
Old 01-06-2017, 10:35 PM   #47
CABLESCUM
CABLESCUM's Avatar
Old 01-06-2017, 10:41 PM   #48
CABLESCUM
CABLESCUM's Avatar
Old 02-19-2017, 12:55 AM   #49
CABLESCUM
CABLESCUM's Avatar
Adjustable Trailing Arms/New Cross Member
Old 02-19-2017, 01:02 AM   #50
CABLESCUM
CABLESCUM's Avatar
Tubular Control Arms...AntiSway Bar...3.5/5 Drop
