Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-27-2016, 02:47 AM   #76
El Dorado Jim
Re: 1970 K20 Restoration
http://www.billavista.com/Tech/Artic...ble/index.html this is good info for 14 bolts, got it from (JIM's 70GMC) in the all 4x4 tech section
El Dorado Jim is offline   Reply With Quote
Old 01-27-2016, 10:34 AM   #77
K20rookie
Lots of very good information there. Appreciate it.
-Nick
1970 Chevy K20 Restoration
2001 Chevy Suburban 2500
K20rookie is offline   Reply With Quote
Old 02-24-2016, 11:48 AM   #78
K20rookie
Picked the frame up from sandblast and powder coat a couple weeks ago. The powder coat shop drilled holes for my ORD steering box brace, powder coated brace, cleaned up a couple welds, filled and re-drilled bumper mount holes, straightened frame in rear, and blasted the exhaust manifolds. Really happy with how it turned out.
-Nick
Old 02-24-2016, 05:20 PM   #79
DWilbur
Nice work on the frame almost as nice as mine. just kidding. looking good.
DWilbur is offline   Reply With Quote
Old 02-24-2016, 10:59 PM   #80
rgunlock
rgunlock's Avatar
Nice platform to start building it back up from!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is online now   Reply With Quote
Old 02-28-2016, 01:46 PM   #81
K20rookie
Got the engine and transmission crossmembers bolted back on the frame yesterday. Id like to torque them down today. Anyone know the torque specs for frame crossmembers and miscellaneous frame bolts? Also, should I be using threadlocker on these bolts? Thanks
-Nick
Old 02-29-2016, 04:56 AM   #82
swamp rat
swamp rat's Avatar
Don't know if your using 5/16, 3/8 or 7/16 but you should use Grade 8 bolts nuts and loc washers, note the zinc chromate finish, the bolts will have the 6 lines on the head of the bolt.
https://www.boltdepot.com/fastener-i...head-size.aspx
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-29-2016, 10:02 AM   #83
cmabolt
cmabolt's Avatar
That frame sure is purdy! Nice job.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 02-29-2016, 10:33 AM   #84
K20rookie
This is exactly what I picked up at tractor supply. Grade 8 yellow zinc chromate. Thanks for the chart.
-Nick
Old 03-01-2016, 01:20 PM   #85
K20rookie
Do you guys recommend I use threadlocker on the frame bolts? If so, what kind should I look for? Thanks
-Nick
Old 03-01-2016, 09:17 PM   #86
msgross
msgross's Avatar
I used lock washers, or nylock nuts
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-02-2016, 02:26 AM   #87
El Dorado Jim
yes, use nylock nuts
Old 03-02-2016, 01:07 PM   #88
swamp rat
swamp rat's Avatar
Here's my take on the subject, your buying grade 8 bolts, most Nyloc nuts are grad 5 or grade 2, plus the only part that lock's on the bolt is the nylon, i would try and find steel deformed thread lock nuts if your insistent on a loc nuts.
I would just use the loc washers and permanent loctite
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-03-2016, 04:27 PM   #89
El Dorado Jim
If you use loctite, don't use the red permanent,it is PERMANENT! use the blue,it is good and you can get the nuts back off at a later time....
Old 03-30-2016, 02:26 PM   #90
El Dorado Jim
Any new progress on your truck lately?
Old 03-30-2016, 08:25 PM   #91
K20rookie
Unfortunately I haven't got much done on the truck lately. Kind of at a stand still until I find some axles. I did go pick up some blue loctite, so hopefully I can get the frame bolts torqued down this weekend.
-Nick
Old 03-30-2016, 09:28 PM   #92
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Nick, did you check with Tom up in Phoenix? He usually has axles around his place.
Tom, http://67-72chevytrucks.com/vboard/member.php?u=966
I'll be in Sierra vista the first week in May, love to see the project.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-31-2016, 08:20 PM   #93
K20rookie
Yeah I got a hold of Tom, but he didn't have what I was looking for right now.
-Nick
Old 04-01-2016, 02:00 AM   #94
El Dorado Jim
I guess you are still trying to find axles from a 71 or 72 K20? wish I was closer, I could move perches for you on a newer rearend
Old 04-01-2016, 02:44 AM   #95
K20rookie
Yeah I'm still trying to find a 71-72 14 bolt rear and dana 44 front with discs. Most of the stuff I've found is 73+. Trying to make it a simple bolt in swap since I don't have any welding equipment or experience. I have a mechanic friend that could probably do it. If I can't find what I'm looking for I may just have to have him relocate spring perches/shock mounts.
-Nick
Old 04-28-2016, 05:41 PM   #96
K20rookie
Ok, so I'm ready to get this project moving again. Got a little sidetracked the last few months. Tom up in Phoenix has a 14 bolt rear with detroit locker and 10 bolt front with discs in 4.10 gears for $700. Came out of a 76. Anyone have any advice on the 10 bolt vs a d44?
Also I'm looking to buy a lift kit and get that installed on the frame. Would like new springs all around, probably 4" lift with 35's. Thought some of you might have advice on what companies to look into. Skyjacker, Tuff Country? Let me know what you would recommend. Not looking to do any hardcore wheeling, just occasional off-roading for hunting, etc. More concerned with ride quality than anything else.
-Nick
Old 04-28-2016, 07:58 PM   #97
swamp rat
swamp rat's Avatar
You could look into BDS for lift springs or SDtrucksprings.com also Offroad design for springs and shackles
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-06-2016, 04:20 PM   #98
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The truck I am working on has Rough Country suspension on it. Looks pretty good. You can swing by and check it out if you want. I also have all the parts I used for the disk upgrade.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 05-06-2016, 06:14 PM   #99
K20rookie
Smitty
Right on, I'd like to check that out sometime. How much did the disc upgrade run you? Dana44 front I'm assuming?
-Nick
Old 05-06-2016, 11:40 PM   #100
71meangreenc10
I used a lot of rockauto, so it wasnt that bad, i could show you the receipts....It is a Dana.
Truck will be here for another week so you might wanna come over soon, pm me and Ill shoot you the address.
Smitty
71 C30 Wrecker
