Old 03-31-2016, 08:03 PM   #1
Genaro Sandoval
What Engine do i have
/Users/Genaro/Desktop/IMG_5943.JPG/Users/Genaro/Desktop/IMG_5944.JPG
Genaro Sandoval is offline   Reply With Quote
Old 03-31-2016, 08:08 PM   #2
PIG-TECH
PIG-TECH's Avatar
Re: What Engine do i have
your pics did not show up,try to load one at a time
PIG-TECH is offline   Reply With Quote
Old 03-31-2016, 08:39 PM   #3
DBK81
DBK81's Avatar
Hmmmmmmmm hard to tell
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 03-31-2016, 09:33 PM   #4
hugger6933
Judging from this post I'd say a greasy one
hugger6933 is offline   Reply With Quote
Old 03-31-2016, 09:40 PM   #5
Genaro Sandoval
LOL sorry ok will do
Old 03-31-2016, 09:43 PM   #6
67chevy_hotrod
67chevy_hotrod's Avatar
You have a small block chevy
Gotta get numbers! Don't once things are changed around it's usually impossible to tell without seeing numbers. Check the deck of the block, which is right in front of the pass. Side head. or on the bell housing! Post pics of those numbers!
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 04-01-2016, 12:44 AM   #7
Genaro Sandoval
casting number is 3932388
Old 04-01-2016, 12:56 AM   #8
ChopsawSurgeon
ChopsawSurgeon's Avatar
Based on that, the block is a 68-79 GM 350 with a 4-bolt main. The stamps on the right hand deck might give a little more info, you might have to pull the alternator out to read the stampings properly.
1996 Chevrolet K1500 (daily runner)
1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!*
ChopsawSurgeon is offline   Reply With Quote
Old 04-02-2016, 01:51 PM   #9
67chevy_hotrod
Go to nastyz28.com and you can decipher each part number and all that! Great site if you like to know about the numbers!
1967 Chevy CST 10
1969 K10 Suburban
Old 04-13-2016, 02:25 AM   #10
Genaro Sandoval
Thanks guys for the info.
Old 04-13-2016, 09:30 AM   #11
Shady Rascal
Shady Rascal's Avatar
Small block Chevy with HEI distributor, sitting on six cylinder mounts, with the newer style long water pump front accessory setup.
Shady Rascal is offline   Reply With Quote
Old 04-13-2016, 10:51 AM   #12
GRX
GRX's Avatar
Rubber hoses with a glass body filter resting on top of the exhaust manifold ... what you have
there is a fire hazard.
And yeah. 1968-79 350. Could be two or four bolt main.
Only way to be sure is pull the pan & look.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
engine, engine type, motor info
