04-19-2016, 01:37 PM | #1 |
MAF mounted to throttle body. Problems?
Still in the middle of my LS swap.
One thing that has come up is my air intake. Using the Sadden A/C compressor and Dirty Dingo A/C brackets, does not leave a lot of room for the air intake. I bought a Spectre intake that puts the filter right where my battery currently sits. I could relocate the battery but that would be a hassle as I already have my PCM mounted in that corner. My current plan is to cut about 5" off the intake pipe and see if that gives me enough room to mount the filter and still close the hood without it touching the A/C compressor. If all else fails. Was thinking of just mounting a filter to the throttle body. Could I do this and mount the MAF sensor between the filter and throttle body? I heard GM likes these to be further away from the throttle body, but I may not have a choice.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
04-19-2016, 02:39 PM | #2 |
Re: MAF mounted to throttle body. Problems?
"Was thinking of just mounting a filter to the throttle body. Could I do this and mount the MAF sensor between the filter and throttle body?"
That is what I did initially for my C10...until the 4l80e forced me to bring the engine forward more than I wanted. It should not be a problem.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
04-19-2016, 03:06 PM | #3 |
I'm not sure of the locations of your stuff and I'm assumimg you have a spectre cold air but this is how I did mine using spectre parts..I just bought a aluminum tube off ebay and cut it to fit...I've had no issues with where the maf is. Its about 2 " from the throttle.
04-19-2016, 03:59 PM | #4 |
meowMEOWmeowMEOW
Technically speaking, putting the MAF on the TB puts it at a point of potentially turbulent air, and doesn't fit within the GM/Delphi recommendations for installation. On most "squishy" tunes (i.e tunes with plenty of safe-room, not max effort jagged-edge builds), the MAF and 02's will be able to dial out some of the negative effects. You run a slight risk of stalling on situations in which the throttle goes from full open to snap shut, because of the rapid change in air volume around the tb as it snaps shut.
Or you can also change to SD tuning and ditch the MAF (or use it as a glorified temp sensor).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-20-2016, 02:29 PM | #5 |
To piggy back on what Brew said, if your MAF is a dual IAT sensor, getting it further away from the engine will help reduce the sensor "heat soak" and give more accurate readings to the ECM.
With that being said, lots of LS conversions run the setup you are talking about with minimal problem. more info here: http://ls1tech.com/forums/pcm-diagno...elocation.html
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
