Old 05-12-2016, 05:02 PM   #1
baclay9
5.3L to 383 stroker
My block is at the machine shop getting sonic tested now. Barring anything crazy I will be punching is out to 3.905 and installing a 4" crank soon. the bottom end will all be forged. 10.8:1 compression is what the compression calculators are telling me.
I am pretty new to all this, been reading a lot over the last couple of months. Several of these have been done but it seems most step up to a 6.0 and build a 408 stroker. I am not going that route. I want something a little different and am curious just how far I can push a NA "5.3". For anyone interested here is the parts list
K1 technologies crank
Callies H-beam rods
JE 10cc dish pistons
Ported 243 heads (milled.035)
Cam will be a custom grind
TBSS intake with 54 lb injectors
92mm TB
I will eventually put a 150 shot or so on it but just going to get it running for now.
I have no idea what to expect power wise. I decided to go with the stroker to up the torque for hauling the truck around. I wil update as I go.
baclay9 is offline   Reply With Quote
Old 05-13-2016, 01:25 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3L to 383 stroker
Depending on what kind of cam it ends up with, your dynamic compression will change a bit. The milling will decrease it a bit, but depending how much the chambers are worked, you might gain volume there. I'm assuming this is supposed to stay a pump gas truck?
Do you have any #'s on the heads (or who's heads they are)? What about a rough idea of cam? Between that and how high you plan on spinning, the #'s could be all over the place. I don't think in the neighborhood of 550 would be out of the question provided your willing to spin it a little.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-13-2016, 07:17 AM   #3
baclay9
The heads are OE 243/799 castings that I am having ported. Pump gas is definitely the plan. Plans are to spin it up to about 7k.
Old 05-13-2016, 06:01 PM   #4
Heavymetl
Who's doing the porting? TEA, Texas Speed, Advanced Induction, WCCH?
They all have killer CNC programs for that factory casting.
On motor with those heads on a 383 LS, I'd say 450rwhp would be a a piece of cake on any dyno. Torque probably in the same range, near 450 at the tire.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 05-13-2016, 07:30 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
On a stock casting, HeavyMetl #'s are a bit more realistic than mine.
Old 05-13-2016, 08:50 PM   #6
baclay9
If I got 450/450 with NA I would be ecstatic! Throw a 150-200 shot ontop of that and it will be all I need
Old 05-14-2016, 01:17 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I think it was either Chevy Hi or Super Chevy that did a pretty neat build along the same lines. Iirc they used some pretty badass heads, and I think at some point they threw boost at it too.
Oh, and make sure ARP Rod bolts are on your parts list!
Old 05-15-2016, 12:31 PM   #8
Tork?
243 heads are a great choice! So many of them around for relatively cheap. Note for future buyers, there no need to fall for the "sodium filled valves" pitch and pay up for Zo6 243's the regular 243 gets the job done just as well and found on I think a lot of 02 LS1s and all the 04 GTOs. Maybe if you're spinning the motor to 7k+ they're a good option though. I think the exhaust are the only ones sodium filled? My past LS life says 450 crank should come pretty easy
Tork? is offline   Reply With Quote
Old 05-16-2016, 11:49 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
Nice. I have a similar iron 5.3/383 combo going in the buick, but haven't run it yet. It's getting fed by a pair of S300s though. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-16-2016, 01:12 PM   #10
boostedc10
boostedc10's Avatar
So you are saying two is better than one!!!!!!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 05-16-2016, 03:51 PM   #11
Wasted Income
Boosted Member
Nah! I'm saying I want to see how the other half lives.
Turbo diesel
Old 05-16-2016, 04:51 PM   #12
jwilb88
jwilb88's Avatar
That motor should make 425-450 rhwp with ease as long as it's not a baby camshaft. The 243 castings flow in the 260 range as cast and a good valve job will pick that up a few numbers.. There are plenty of cam only LS6 video's out there of car's making over 400 rwhp. You with 36 more cubes and a small bump in compression should put you well over the 425 mark through an overdrive auto.
I have a similar combo but I stayed with a stock stroke 347 cube motor because I plan to lay some boost to it.
jwilb88 is offline   Reply With Quote
