Old 05-05-2016, 03:05 PM   #201
donandal
Re: Plus Five
I installed the inner fenders and some components.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 05-05-2016, 03:13 PM   #202
donandal
Re: Plus Five
I installed the radiator reservoir. I built this from .060 aluminum.
The cap is from a nissan reservoir. I copied the thread profile and
cut the threads on the lathe, then welded the neck to the top flange
before welding up the rest of the tank.
The over flow refills into the bottom of the reservoir, and any more than
that will go out the reservoir overflow at the top of the tank, then down to
the ground.
53 Chevy Pickup
Old 05-05-2016, 03:17 PM   #203
donandal
Re: Plus Five
The big square hole on the passenger side inner fender is for the
air intake. I'll post that soon.
53 Chevy Pickup
Old 05-07-2016, 05:19 PM   #204
donandal
Re: Plus Five
I reinstalled the front end tilt frame and greased up the pivots and the sway bar links and pivots.
53 Chevy Pickup
Old 05-07-2016, 05:30 PM   #205
donandal
Re: Plus Five
half round rubber pads for the stop,
front pivot bushings...
53 Chevy Pickup
Old 05-07-2016, 05:35 PM   #206
donandal
Re: Plus Five
just enough clearance...
53 Chevy Pickup
Old 05-07-2016, 09:22 PM   #207
oldman3
oldman3's Avatar
Re: Plus Five
Very nice...Jim
oldman3 is offline   Reply With Quote
Old 05-09-2016, 10:27 AM   #208
ricott
Re: Plus Five
I love everything about your build. Your attention to detail, and willingness to modify and/or fabricate parts is what I think hot rodding is all about.
I have a question about your windshield wiper setup. In Post 142 it appears that you used Ford Escort splined shafts and transmission arms for your starting point, is that correct? Also, in Post 143 are those wiper arms from a Ford Escort also?
I have a 1966 GTO that my college son and I restomodded using a 6.0 LS type engine and six speed manual transmission (it is in the link below ). We have driven the car over 30,000 miles and now it is time for some upgrades. I used the same wipe motor you used, and with some work, it works great. The wiper transmission arms and "old style" wiper transmissions are noisy and have a fair amount of slop and need to be upgraded. I was considering using parts from a newer S-10, but your setup looks to be perfect for my GTO.
Thanks in advance for your help.
Ricky
ricott is offline   Reply With Quote
Old 05-09-2016, 08:23 PM   #209
donandal
Re: Plus Five
Ricky
Thanks,
I really enjoy making parts.
As for the wiper setup, I'll have to check my notebook when I get back home. I'm out of town for the rest of the week. I think the splined arms that hold the wipers are from the rear of a couple Ford escort hatchbacks.
The splined shafts had to be turned down on the lathe to fit inside the original cowl bushings. The rest of it, transmission, arms with the sockets, mounts and linkages have all been modified or made from scratch.
I'll try to find more info later in the week.
Don
53 Chevy Pickup
Old 05-13-2016, 09:29 AM   #210
RockinKees
RockinKees's Avatar
Re: Plus Five
That flipfront is just a piece of art!!
Realy nice!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-13-2016, 09:09 PM   #211
donandal
Re: Plus Five
Realy nice!!
Thanks,
I think it will look a little better when I get the fenders and hood
back on and it's working. I'm going to try to make a video of that later,
if I can get my son to help me.
I've been on the road for the last five days, but I have some time
off now so I should get a little done.
53 Chevy Pickup
Old 05-17-2016, 07:27 PM   #212
donandal
Re: Plus Five
Messing with a lot of little things.
The corner windows are in. The ones I had were cloudy
around the edges, so I bought new ones from Classic parts.
I had the glass guy put them in. He was impressed with the quality!
Only charged me $20 per window. Money well spent. All glass is in now.
53 Chevy Pickup
Old 05-17-2016, 07:39 PM   #213
donandal
Re: Plus Five
Also finished up a fresh air line on the intake I made.
I made up a line from the passenger side valve cover to
the air intake. I made a threaded bung and welded it to
the intake pipe, and made a bracket to brace the tube.
Just need a short piece of rubber hose to finish
it up.
I'll be finishing the power steering cooler and transmission
cooler lines next.
53 Chevy Pickup
Old 05-18-2016, 12:27 AM   #214
mongocanfly
mongocanfly's Avatar
Re: Plus Five
Just curious but what's the fresh air line on the intake tube for?
Old 05-18-2016, 06:48 AM   #215
donandal
Re: Plus Five
It's part of the emissions system. From what my instructions say, the crankcase air is drawn into the intake manifold and burned, and fresh
air to replace it comes from the filtered air. Instructions say it needs to be between the mass air flow sensor and the throttle opening for correct
engine performance.
53 Chevy Pickup
Old 05-18-2016, 08:19 AM   #216
solidaxel
solidaxel's Avatar
Re: Plus Five
Can you say P C V inlet!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-18-2016, 06:32 PM   #217
donandal
Re: Plus Five
I could....
but I'll stick with what the experts that built it call it.
This is copied from my instructions.
This port should be connected to filtered clean air. This connection must be within the engines air cleaner system and must be between the MAF (Mass Air Flow Sensor) and engine’s throttle body. The engine burns the air that enters the PCV system so, if the fresh air port is prior to the MAF then, this air will enter the engine without being measured by the MAF and adverse engine operation may occur.
53 Chevy Pickup
Old 05-20-2016, 09:56 PM   #218
donandal
Re: Plus Five
I mounted the transmission cooler and power steering
cooler. Also made up the hard lines, so just flex lines to go,
then on to the electrical system.
53 Chevy Pickup
Old 05-20-2016, 10:01 PM   #219
donandal
Re: Plus Five
here's the transmission cooler,
53 Chevy Pickup
Old 05-21-2016, 11:53 AM   #220
donandal
Re: Plus Five
Well,
today I put together the braided stainless flex lines for the power steering
and transmission.
What a pain in the ...
The instructions say to wrap black tape tight around the area to be cut, then cut thru the tape with a cut-off wheel. For the fuel lines, this worked great. For the powerflex and speed flex hose it started to unravel as soon as it was cut. The plastic coated braided stainless also swelled just enough that it wouldn't slip thru either.
I fooled around with different methods, then settled on a .020 aluminum wrapped around and hose clamped. I cut the hose right next to the aluminum sleeve while the hose clamp was tight. Then I loosened it just enough to slide and gave it a quick push and it slipped thru the fitting just fine, and no unraveling.
Glad that job is finished!
53 Chevy Pickup
Old 05-21-2016, 12:33 PM   #221
Advanced Design
Advanced Design's Avatar
Re: Plus Five
Good solution. This is pretty handy. http://www.koultools.com/ANHoseAssemblyTools.html
Advanced Design is offline   Reply With Quote
Old 05-21-2016, 01:17 PM   #222
donandal
Re: Plus Five
That looks pretty slick.
Have you ever used it with teflon hoses like speedflex or powerflex ?
53 Chevy Pickup
Old 05-25-2016, 07:00 PM   #223
donandal
Re: Plus Five
I mounted a few pieces in the cab. On the passenger side is a vent and mount for the engine computer. I also painted the floor with tractor enamel to seal it all up, before mat and sound deadening go on.
Also mounted the solenoid/relay? for the tilt mechanism and the flex lines on the power steering.
53 Chevy Pickup
Old 05-25-2016, 07:14 PM   #224
donandal
Re: Plus Five
I had a little trouble with the fittings for the transmission lines. I am replacing the quick connect fittings with AN-6 adapters. I ordered the ones from Summit Racing that are used on 700R4 and various others, but the transmission threads were a little bigger diameter on my 4L65E.
I called Summit, and they checked the part # and thought it should fit. They didn't show anything else that was listed for a 4L65E.
I called Pace performance, and they knew immediately which fitting I needed. The 700R4 has a 1/4 STRAIGHT pipe thread, while the newer 4L65E uses a 9/16-18 straight thread. Pace gave me the part number.
I called Summit and explained all of this, and they were AWESOME!!!!
They sent me the two correct fittings FREE, and no shipping charges either!
So, tomorrow I'll finish those two lines also.
53 Chevy Pickup
Old 05-26-2016, 06:34 AM   #225
Iplumb
Re: Plus Five
FYI - Easy on the teflon on those an x male adapters. I have been told many a trans case has been cracked with to much teflon and over tightening.
Looks Great
Mike
Iplumb is offline   Reply With Quote
