Old 05-16-2016, 10:48 PM   #751
66ChevyMax
66ChevyMax's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Ok she fired right up but had to cut things short because of a 2 power steering issues, a small leak and the power steering lines were jumping around and pump made a funny noise.
Reservoir may have been pulled dry once lines filled up but not sure that was it.
Can I get a plumbing check?
Power steering pump has a #6 and #10 fitting:
From pump #6 to passenger side of hydro boost, exit drivers side of hydro boost to passenger side of power steering gear box, exit power steering box on drivers side and tee into return from hydro boost to #6 side of reservoir, #10 of reservoir to #10 on power steering pump.
Thanks for the help!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-17-2016, 10:24 AM   #752
mcfarlnd
Originally Posted by 66ChevyMax View Post
I'm anticipating that it will run rich as I have not done any modifications to the computer since I put the Supercharger on. Injectors are LS9, I hope to take a reading with HP Tuners and post and get some information for LS9 injectors in an LS3.
What tuning software are you using? I may have some injector data.
mcfarlnd is offline   Reply With Quote
Old 05-17-2016, 10:44 AM   #753
66ChevyMax
66ChevyMax's Avatar
HP Tuner
Craig
Old 05-17-2016, 11:57 AM   #754
66ChevyMax
66ChevyMax's Avatar
Answered my own plumbing question, I have the hydroboost inlet and outlet backwards
Craig
Old 05-17-2016, 11:58 AM   #755
Hart_Rod
Hart_Rod's Avatar
Busy day in the shop, got the ignition hooked up and turned her over for the first time with an actual key.
All the air ride is hooked up and working, got all of the Dakota Gauges Cluster hooked up.
Still need to install seat, head liner, wiring for A/C and all lights, exterior trim on doors and front fenders.
She's ready to be started again, need to do a one over on all the wires to make sure there are no conflicts with belts and headers.
My plan for now is to do some light tuning so I can drive it to have the exhaust installed. Final tuning will be on a dyno by people who know what they are doing!
Small piece of advice, get your exhaust done prior to any tuning.....be there done that!
http://www.hptuners.com/forum/showth...+injector+data
Hart_Rod is offline   Reply With Quote
Old 05-17-2016, 12:18 PM   #756
66ChevyMax
66ChevyMax's Avatar
For sure, thank for the warning!
Craig
Old 05-17-2016, 10:20 PM   #757
66ChevyMax
66ChevyMax's Avatar
Power Steering issues are solved, amazing how things work when they are not hooked up backwards
Here's a little video, TURN IT UP!
https://youtu.be/MAqwlFNOe8U
Craig
Old 05-18-2016, 08:45 AM   #758
clemdaddy
clemdaddy's Avatar
sounds good... looks really good in there too.
clemdaddy is offline   Reply With Quote
Old 05-18-2016, 11:15 AM   #759
66ChevyMax
66ChevyMax's Avatar
Thanks Clem!
Craig
Old 05-19-2016, 12:37 PM   #760
66ChevyMax
66ChevyMax's Avatar
Seat is in and headliner is in, hard to get a good picture of the headliner indoors:
Craig
Old 05-19-2016, 01:43 PM   #761
greg65
greg65's Avatar
Very nice work.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 05-19-2016, 08:45 PM   #762
Advanced Design
Advanced Design's Avatar
Looks good, sounds good, awesome work!
Advanced Design is offline   Reply With Quote
Old 05-21-2016, 12:19 AM   #763
66ChevyMax
66ChevyMax's Avatar
Thanks Greg, its been a long time coming!
Originally Posted by greg65 View Post
Very nice work.
Thanks for checking in Doug!
Craig
Old 05-21-2016, 12:23 AM   #764
66ChevyMax
66ChevyMax's Avatar
Playing with some tuning, just injector data so far. Haven't actually uploaded it yet, trying to get approval from those who know what they are doing first
Was going to attached tune files but uploader says invalid file type?
Craig
Old 05-21-2016, 07:41 AM   #765
chad64chevy
chad64chevy's Avatar
man it just gets better an better, interior looks good too
chad64chevy is offline   Reply With Quote
Old 05-21-2016, 11:59 AM   #766
66ChevyMax
66ChevyMax's Avatar
Thanks Chad
Craig
Old 05-21-2016, 06:24 PM   #767
66ChevyMax
66ChevyMax's Avatar
Talked to Magnuson and the person actually looked up my order instead of guessing, Injectors are Deatsch Werks 16U-00-0065-8 65lbs, they have data on their site.
Anyone know why the forum won't let me upload .hpt files?
Craig
Old 05-21-2016, 10:28 PM   #768
Advanced Design
My guess is because .hpt isn't one of the allowed file types. It isn't shown on the upload list.
Old 05-21-2016, 11:35 PM   #769
66ChevyMax
66ChevyMax's Avatar
Bummer
Craig
Old 05-23-2016, 12:11 AM   #770
ChuckLee
Thank you for the well-documented and inspiring build! Time for me to get to work. I have a 69 longbed c10 with a 355 and a manual Mid 80's Iroc tranny. I'm going to LS swap it and REALLY want a t56 over an auto. Need all the inspiration I can get, especially with keeping a manual.
ChuckLee is offline   Reply With Quote
Old 05-23-2016, 01:01 AM   #771
66ChevyMax
66ChevyMax's Avatar
Thanks for checking in and the kind words Chuck. This is my 4th build and everyone of them had a manual when done. You just can't beat being in control of those RPM'S!
Look forward to seeing you build, good luck!
Craig
Old 05-23-2016, 01:13 AM   #772
66ChevyMax
66ChevyMax's Avatar
Wires Wires Wires, taillights, headlights, gauges, E Brake, Transmission Reverse Lockout all wired.
Still need to wire, A/C, Wipers, Dome and Radio. Will upload new tune tomorrow and take her for a test drive.
Now I can make the neighbors mad at night:
Craig
Old 05-23-2016, 10:16 PM   #773
youngrodder
youngrodder's Avatar
Very cool.....Good luck on the test drive..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-24-2016, 12:01 AM   #774
siggyfreud
siggyfreud's Avatar
Grab a free Dropbox account then you can upload there and link the tune file. I back up all my important stuff there or to Google drive. Download the app on the computer and it'll make either appear as another drive that you can save to directly from your programs.
siggyfreud is offline   Reply With Quote
Old 05-24-2016, 10:30 AM   #775
66ChevyMax
66ChevyMax's Avatar
Thanks Marc
Marc
Craig
