Old 11-06-2015, 01:36 AM   #76
GMC-YA68
GMC-YA68's Avatar
Re: 4x4 LS cross member
Very interesting. Were his blazers 4x4?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 11-09-2015, 02:22 AM   #77
72LSK10
72LSK10's Avatar
Yes, both of the Suburbans where 4x4's.
72LSK10 is offline   Reply With Quote
Old 03-21-2016, 05:14 PM   #78
GMC71k20
https://issuu.com/truckandcarshop/docs/ts_47-59_13_web
Thats a link to the "the Truck Shop" catalogue and like mentioned before, the crossmembers are on pg 93
GMC71k20 is offline   Reply With Quote
Old 06-04-2016, 12:50 PM   #79
preciador6
i have to order this..subscribed
preciador6 is offline   Reply With Quote
Old 06-04-2016, 02:38 PM   #80
preciador6
http://www.dirtydingo.com/shop/produ...id=1408:metal:
Old 06-06-2016, 01:22 AM   #81
DWilbur
If you use the dirty dingo cross member most header don't fit I had to cut and re work the Dough Thorley headers I bought. I tried block hugger type header and had fitment issues as well. or stock manifolds will fit 2.
the main issue is the the headers are made to fit 2 wheel drive truck. the cross member on 2 wheel truck pushes the engine up 1.5" higher than 4 wheel drive.
DWilbur is offline   Reply With Quote
Old 06-07-2016, 10:55 AM   #82
preciador6
I have a 72 4x4
Old 06-07-2016, 12:53 PM   #83
DWilbur
I have a 71 4X4. check out my build thread I have pictures. 71 4X4 frame off Restoration
Old 06-10-2016, 02:37 PM   #84
preciador6
Its here.
Old 06-10-2016, 03:57 PM   #85
DWilbur
Very cool in deed.
Old 06-10-2016, 04:10 PM   #86
preciador6
Very cool in deed.
Do i make the new holes were they say or do i have to move them back or forward on the frame?
Old 06-14-2016, 04:51 PM   #87
Wasted Income
Boosted Member
Wasted Income's Avatar
Put the holes wherever you want/need for your build.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-14-2016, 05:01 PM   #88
preciador6
Done thanks guys.
Old 06-14-2016, 05:57 PM   #89
DWilbur
Done ?. I see a couple bolts missing. I wedged mine up to the top of the frame to get it as high as I could to help out with the headers. your installation looks good. Are you using stock manifolds or headers.
Old 06-14-2016, 06:19 PM   #90
preciador6
Its done took bolts out to clean the frame up..I have Pace Setter headers 70 2265.
Old 06-14-2016, 07:59 PM   #91
DWilbur
Let us know how the headers fit.
Old 07-09-2016, 12:57 PM   #92
preciador6
Nope they hit on the leaf spring bracket bolts on both sides..they do clear the frame no problem..dont know if i should cut and buy exhaust merge collecters to make them longer or just install a set of 2002 ls1 manifiolds i have those bolt right in no prob.
Old 07-12-2016, 05:39 PM   #93
DWilbur
Had email issue just got it fixed. interesting about the issue you have with your headers. mine clear the shackles and hardware.
Old 07-12-2016, 05:45 PM   #94
preciador6
This had came of a 1985 K5.
Old 06-14-2020, 11:00 PM   #95
57taskforce
All about them K’s
57taskforce's Avatar
Anyone have an update on the 47-59 v8 swap crossmember into a 67-72 4x4 LS swap? I’m readying my self for the swap for my K20 and stumbled across this thread. Looks like a very cost effective way to approach this. I’m not honestly crazy about the dingo or pacfab setups, as I don’t plan to lift my truck right away, maybe in the future but not now.
Tyler
Old 06-15-2020, 05:12 PM   #96
rowdy11
I'll add my two cents. I used Dirty Dingo mounts for my '70 K10. I have a Dana 44 up front. Overall I like the mounts (the newer ones have holes for front brake lines that run through the frame). I have a 4" lift and have loads of room between the mount cross member and the pumpkin.
But the two major problems I've had: First, I can tell my LS heads are going to be really tight against the firewall even after pushing the engine all the way forward. Second, headers. I sent back the first pair I bought because of fit. I now have mid-length Doug Thorley headers and still had to modify the header slightly on the drivers side to fit inside the frame. An extra inch or two of engine clearance up above the frame would have made all the difference.
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 07-31-2020, 09:45 AM   #97
Acregger
I took a chance and used the Jegs cross member that was posted earlier. I had the body off the frame so hopefully it all works but the cross member is in and engine set. I will take some photos. Btw 1971 4x4
Acregger is offline   Reply With Quote
Old 08-01-2020, 10:58 PM   #98
57taskforce
All about them K’s
awesome yes please do take some pictures. I’m
Building my engine now and trying to get everything together for this swap.
Tyler
Old 08-02-2020, 08:23 AM   #99
Acregger
Cross member in. I am at stock height right now and there is at least 2 inches from cross member to front diff. The bracket hit right at the bumper stops so I had to remove them but I wanted the cross member back some for my low mount AC. Have to mount the compressor yet but there is enough room with the motor mounts back. I used adjust mounts
Old 08-02-2020, 11:03 AM   #100
57taskforce
All about them K’s
Thanks for the pictures, I think I’m gonna go this route. so is your transmission and transfer case in the stock 67-72 position? I don’t want to move them so I don’t have to modify the driveshafts at all.
Tyler
