Old 06-23-2016, 09:32 AM   #126
CarbonRight
So there is about a $350 difference between this setup and the fatbar when they are both using Ridetech shocks. What are the advantages of going with this vs your fatbar setup?
CarbonRight is offline   Reply With Quote
Old 06-24-2016, 09:37 AM   #127
robnolimit
robnolimit's Avatar
Re: No Limit Trailing Arm Rear Suspension
Fair question. It's really kind of "Apples vs. Oranges". We wanted to do an actual 'Bolt-in' rear upgrade for a long time. So, the Trailing arm kit was developed. The extra cost mostly has to do with the extra hardware cost in the arms, monster balls, and hardware for the panhard rod. On the plus side, this kit can be installed in a day, with a grinder, a drill, and a Craftsman tool kit. Now, if you have a torch or plasma cutter to help with the rivets, it can be done a lot faster. But, no welding at all.
The Fatbar was originally designed for 55-59 Chevs and 53-56 F100s. (sorry for the F word) And, over the years, we tuned on the design to get the best ride and handling we could from a classic truck. It's advantage when compared to the O.E. trailing arm was in Instant Center location/tuning, and the lack of binding during articulation. (we didn't have Monster balls back then) But remember, the Fatbar has parts that MUST be welded to the axle housing. Thus, the install takes a little longer, and requires more tools and skill.
In head to head competition, the Fatbar may win out due to it's ability to launch and exit the corner. On the road, the trailing arm may be a little more compliant due to it's longer travel. As for cost, an increase in hardware offsets some addition labor to install. Take your pick, it's a Win-Win.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-24-2016, 05:08 PM   #128
SierraMtns
SierraMtns's Avatar
Has anyone figured out which diff covers fit with the panhard bar?
SierraMtns is offline   Reply With Quote
Old 07-03-2016, 12:59 AM   #129
SierraMtns
SierraMtns's Avatar
Hey Rob,
Any pictures of the c-notch?
Old 07-17-2016, 06:14 PM   #130
SierraMtns
SierraMtns's Avatar
Hey Rob,
Any updates on the c-notch?
Old 07-19-2016, 01:20 PM   #131
robnolimit
robnolimit's Avatar
Getting close. matching the bends to fit the OE rail is harder than it looks. We should have formed parts next week. Fixtures and press jigs are ready. - It won't be long.
Old 07-20-2016, 11:13 PM   #132
gringoloco
A guy with a truck
gringoloco's Avatar
Cool stuff here. Any updates/opinions from those who have purchased?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-27-2016, 01:16 PM   #133
TTurbo565
Hey Chris. I purchased and installed the kit with the Ridetech three way adjustable shocks from Rob a couple of months ago. I have a 72 Chevy long bed that is pretty much stock except for the suspension and wheels/tires. I removed the bed for the installation and everything went pretty smooth. Drilling out the stock rivets is the worst part of the job. Everything is great quality, and with a little careful measurement, my truck didn’t require any adjustments in the rear for a perfect four wheel alignment. I haven’t had a chance to put it through the paces on a track, but the ride and handling is amazing. I had to add more clearance to the inside wheel houses to accommodate the 345/19X12 wheels and extra axle articulation for street driving, but the axle tracks the pavement really well and the rear axle hop/oversteer of death is greatly reduced. Rob did a great job!!
TTurbo565 is offline   Reply With Quote
Old 07-28-2016, 04:00 PM   #134
crakarjax
crakarjax's Avatar
I tried every method of removing rivets and let me tell you, the $300 you'd spend on a cheap plasma cutter is so worth it -- you can shave the head off a rivet in about 10 seconds and then punch it out.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-28-2016, 04:40 PM   #135
SCOTI
SCOTI's Avatar
Same thing w/a quality air chisel vs a cheap one. I struggled on rivets w/a new Craftsman unit. Upgraded to a Snap-On . . .... night & day difference.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-29-2016, 10:55 AM   #136
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the review, and welcome to the board!
Must find one of these $300 plasmas
So true. The HF air chisel will get it done, but you'll be there all day
-Chris
Old 07-29-2016, 01:19 PM   #137
crakarjax
crakarjax's Avatar
This is the one I have, it's $290 now or $260 through warehouse deals:
Lotos Plasma LT5000D
Old 08-10-2016, 11:08 AM   #138
gringoloco
A guy with a truck
gringoloco's Avatar
Any provisions for e-brake cables on the arms?
-Chris
Old 08-10-2016, 04:35 PM   #139
robnolimit
robnolimit's Avatar
We did not put any cable mounts on the arms fot the OE style cable. Currie and others have bolt-on tabs that can be used. When running Wilwood, or other aftermarket disc set ups, custom cables can be made for you at www.controlcables.com We run the cables through the arm, notice that they are ported on the top/front and side/rear for cable housings.
Old 08-10-2016, 11:43 PM   #140
SierraMtns
SierraMtns's Avatar
I was hoping to run stock brake drums however the OE e-brake cable runs right into the coilover. So I went with Camaro calipers and CaptainFab brackets. My plan is to use the stock Camaro cables and run them right along the trailing arms like the stock ones. The Camaro cables are strong and well built. I only paid $20 for them at pick-n-pull.
Old 08-10-2016, 11:48 PM   #141
SierraMtns
SierraMtns's Avatar
Rob, someone is getting ready for a WideRide frond end....
Old 08-12-2016, 05:17 PM   #142
gringoloco
A guy with a truck
gringoloco's Avatar
Clean! I like
-Chris
Old 08-13-2016, 01:43 PM   #143
Stickman
Stickman's Avatar
Originally Posted by SierraMtns View Post
Hey Rob,
X2 Anything going on with the notches ?
Thx
Kirk
Stickman is offline   Reply With Quote
Old 08-15-2016, 03:04 PM   #144
robnolimit
robnolimit's Avatar
Finishing the first run of Notch kits today. Picts up soon.
Old 08-15-2016, 05:20 PM   #145
moregrip
moregrip's Avatar
We have had so many ask about this, and it was a tough call in some ways to go ahead with this project. I would like to explain that. At No Limit, we are focused on performance suspension. We have never claimed to build the lowest, the 'showy-est' or the lowest price. We focus on the best ride and handling. There are other great builders of the lowest ride, and you should steer clear of the low price crap.
We have the FatBar 4-bar rear for C10's, and it's great. Ask anyone running one. Smitty proved it's ability beyond any doubt. We have the custom 3-link, like the one Wes D. runs and it's a short course killer. Now both of these are great, but they do require welding and fitting, and the three link must use a Ford 9". Then we have a shock mount kit, panhard kit and sway bar for OE C10 rear suspensions as bolt-on upgrades. These work very well to enhance the original truck, but there are some shortcomings.
We also took the time to study what others are offering, as there isn't really any reason to duplicate something that's already available. The big problems are as follows; 1)Limited travel forcing a stiff ride, mostly due to short shocks and poor location. 2)Rigid, fixed front bushings that limit the axle articulation - OE arms twist, tubular arms don't. 3) High roll center that limits the side bite available, forcing the truck to be 'loose'. 4) Limited clearance for exhaust. With this in mind, the goal was to produce a bolt-in kit with none of the shortcomings of the current marketplace.
Love this kit! When is the 73-87 version coming out?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 08-16-2016, 12:08 PM   #146
gringoloco
A guy with a truck
gringoloco's Avatar
What anti-sway bar works with this kit? Is it just the hotchkis blade style? Looks like your top mount *might* work. Looking forward to notch updates
-Chris
Old 08-16-2016, 02:06 PM   #147
bluex
bluex's Avatar
See post #104 he addressed it there and basically says no, since there is welding involved a 4-link would be a better option. You could avoid welding by using a 71/72 rear axle though. I asked him to elaborate on why the trailing arms would be a bad idea in a square but Rob's a busy man so his earlier answer was all he said on the subject.
Your options for trailing arms on a 73-87 are CPP or Porterbuilt, maybe hotrods to hell if they are still around.
bluex is offline   Reply With Quote
Old 08-21-2016, 11:40 PM   #148
SierraMtns
SierraMtns's Avatar
2 more days and the c-notch will be here.... Monkey junk
Old 08-25-2016, 04:15 PM   #149
vtekdis
vtekdis's Avatar
Rob, I know you guys install 9 in floaters on your frames and would like to have one on my truck. Is there any chance you could sell the rear end prepped for this trailing arm setup? I'm all about that bolt-in ...
vtekdis is offline   Reply With Quote
Old 08-27-2016, 01:20 PM   #150
robnolimit
robnolimit's Avatar
We sure do. We can prep both standard 9" big bearing housing/axles. or floaters. Pricing breaks down like this.
9" heavy duty Moser housing with billit Torino (big bearing late model) ends, pinion centered, with fill and drain added + Moser 31 spline axles with access hole, 2 1/2" offset, bearings and seals and 1/2" x 20 studs. Standard C10 width is 63" WMS (wheel mount surface) - can be 62" or 61", no extra charge. With No Limit brackets welded* $1,295.00
9" BBLM brakes 11" Explorer style, drilled/slotted = $590
12.19" x 4 piston Wilwood = $895
13" x 4 piston Wilwood = $1785
9" Moser heavy duty floater housing, fill and drain added. Steel hubs and drive plates, all bearings, seals, retainers, 31 spline axles. Pinion centered, 63" std WMS. - 60" to 62" avail also. No Limit brackets welded = $1395
Floater brakes 11" Speedway style with Wilwood Superlite (no E Brake) $745
12" Wilwood w/E-brake in caliper $895
13" Wilwood with Superlite and Mech spot E-brake caliper $1680
For drilled/slotted rotors on these kits add $90
* Brackets not included, but are part of No Limit suspension packages.
