Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-21-2016, 08:02 PM   #1
1968k20
1968k20's Avatar
1967 GMC Suburban Build (Poloma)
Picked this up last week. Engine/trans were unbolted from the frame when I bought her. She's a 67 2wd with barn doors, original ivory white with red interior. So I thought to myself " Lets pull the engine out to freshen it up, since it's already unbolted!" I am glad I did! There's a 6" crack on the block! It was recently rebuilt(.030 over), so I will find a block and put her back together. I need to also pull trans out and ID and make sure fluid looks good. I am not going to do anything to the body yet, as I want to get it running. Poloma has hardly any rust. I have never seen one this clean ( maybe a show Suburban)!
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 03-21-2016, 08:03 PM   #2
1968k20
1968k20's Avatar
Re: 1967 GMC Suburban Build (Poloma)
Here we go!
Old 03-21-2016, 08:04 PM   #3
1968k20
1968k20's Avatar
More
Old 03-21-2016, 08:05 PM   #4
1968k20
1968k20's Avatar
Crack in block
Old 03-21-2016, 08:06 PM   #5
1968k20
1968k20's Avatar
Can't beat the 67 GMC grills!
Old 03-22-2016, 11:45 PM   #6
1968k20
1968k20's Avatar
Pulled trans today(700r4). Pulled the pan, and water was the first to drip out! Should I rebuild or rebuild a 350 that I pulled out of my 72? Which trans is better behind a 350?
Old 03-26-2016, 09:51 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
If the r4 was all hooked up and working and you are going to be putting some highway miles on it I would rebuild it....
Just my 2¢ worth....
LockDoc
Leon
Old 03-26-2016, 10:46 PM   #8
1968k20
1968k20's Avatar
My round-trip commute to work is 2 miles! I don't go out of town much;maybe I would drive it once every 6 months a hundred miles or more!
Old 03-26-2016, 11:38 PM   #9
LockDoc
LockDoc's Avatar
Then it probably wouldn't make a lot of difference.
LockDoc
Leon
Old 07-19-2016, 09:42 AM   #10
bonestock72
hey, this is bonestock 72 over here in sierraville, i've got a 350 4 bolt main casting #3970010 that needs rebuilt. It's standard bore. had a rod knock. you could transfer the parts out of your cracked block to this one. supposedly has a steel crank. let me know if you're interested.
bonestock72 is offline   Reply With Quote
Old 07-19-2016, 08:18 PM   #11
1968k20
1968k20's Avatar
How much do you want for it?
