#301 |
Re: 46 pickemup in NJ "the Rebuild"
You must really like that ignition switch.
Maybe a push button with a hidden on off switch, like a parking light power to a relay and a momentary push button switch to start only The aftermarket switches I have used (keyed) had a lock washer and I was able to tighten it up so it had enough tension to start!
#302 | |
#303 |
Well that was fun
#304 |
And it works !!
#305 |
Man your truck is looking good. I wish I was that far on mine. We got that snow here in Hanover too it really slows things down. I had trouble getting to my garage and that's just a walk to the back yard! Did that wiring kit include things like headlight switch and dimmer switch with harness plugs for them?
46 Chevy Pickup (project) 60 Chevy Biscayne 93 Caprice wagon(Impala SS style) 99 Corvette convertible 2014 Silverado 2500HD 92 Chevy 1500 (Shop/plow truck) 02 Silverwing 05 H-D Springer Classic 2011 Civic (Wifes car) 03 Highlander (beater) 96 Honda Elite 80 |
#306 | |
Yes the American Autowire kit came with all the switches and plug connectors. The only thing I will need to buy in addition to the kit is a long cable for the battery to the starter, as I am going to put the battery inside the bed of the truck in an old Coke cooler. |
#307 |
![]() Join Date: Mar 2013
Truck is looking Good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#308 |
A couple of small updates.........While I am waiting for warmer weather so I can paint the dash and get going on the wiring I figured I would throw the seat back in one more time before upholstery and get the throttle pedal figured out. Worked out pretty good with the new linkages I made on the carb side. I just had to make a small plate so I could off set the pedal enough so that the linkage arm could travel past the side of the dog house.
If you look close you can see a black dot to the left of the linkage. that is where the original would of had to have been to line up with the carb linkage. ![]() ![]() carb side ![]() Also got my brake booster line installed. Tapped into the clifford manifold for vacuum. ![]() Booster side.. And yes I will put a grommet in that hole ![]() ![]() Be back soon with more fun times. Cheers, Paintman |
#309 |
Slick linkage Paintman, looking good
#310 |
. A lot of nice work going into this one - looking forward to following your progress. . . |
#311 |
OK guys some small updates. I started making some of the connections on my wires. That is after having to buy all the right crimpers. The weather in Joisey has not allowed me to get my dash painted yet so I figured I would work in the engine bay. As I mentioned before I don't like sloppy wires hanging all over the place so I tried to hide as many as I could. To do this I ran my MSD wires in 2 seperate 5/16 aluminium tubing. The 2 tubes are clamped together with tubing seperators and then fastened to the fuel line. Turned out pretty good as the tubes kind of match the fins on the valve cover. The one tube carries the 2 wires from the box down to the harness on the dizzy, and the other tube carries the 2 coil wires. I flared all the ends of the tubes to prevent any chafing
![]() Here's how they come out of the end of the tubes. I welded a spud to the coil bracket so I would have a place to mount a wire keeper so that the harness would not touch the engine when it was hot. turned out pretty good I guess. ![]() I also made up a PCV line. I don't like the way most inliners have done there PCV line by taking a piece of black tubing and just laying it over the top of the valve cover to the carb. To me that looks half assed. So again I took a piece of 1/2" aluminium tubing and wrapped it around behind the engine. ![]() And that's about the best this amamteur can do, I guess I will have to live with it for now.... ![]() |
#312 |
Still watching. Very Clean.
#313 |
Very clean and Very nicely done. Gave me some ideas for mine.
#314 |
Where did the trans cross member and master cylinder kits come from?
Great pics and very nice work
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
#315 |
Well, the NJ weather finally took a turn for the better and we got a few warm days to finish painting the dash. As soon as it was dry enough I got the damn thing back in and out of the way in the garage.
![]() I had to make a bracket to firm up the the dash behind the steering column as the old one was thrown out with the half assed swing arm brake pedal assembly. You can kind of see it through the dash cluster opening. I also started putting in some of the switches so I can plan my wire routing. This is going to take some time as my OCD tends to make me contemplate things for hours on end. LOL! ![]() Got the heater back in with a new core and new 12 volt motor. I don't want to re-hash everything I had to do to save this heater, but lets just say it was a pain in the butt. Looking back I probably should have just nixed a heater altogether but we get some nice days here in the fall and winter, their just a little cold. Unfortunately it was my only option as I could not find a heater that would fit in the space I had (9 1/4"). ![]() Also got the last piece of the puzzle for the dash so I can start making my wire connections. I was going to go with Dakota digital but I cheaped out and went with Autometer. Just waiting on a wiper switch and grounding blocks that are on order. Then I can really jump into it! ![]() |
#316 |
................. The End Is Near !!
Good choice on the gauges
#317 | |
I have been pluggin away on the under dash connections. Got most everything buttoned up under the dash except for the column harness. Guages are done, as well as the ignition and headlight switches. Got all my wires as neatly bundled up as I can, and secured under the dash. I am going to leave the wires unloomed for now until I am sure everything works. Here a shot of how everything looks under the dash before the guages went in. I mounted a terminal block to the dash support so I could run all my grounds to one central location. I also mounted my GPS speedo brain to the dash support brace. Not sure where I am going to mount the antenna as of yet but they give you 16ft. of wire so there is alot of options. ![]() ![]() You know your getting something accomplished when all the holes in the dash start to disappear! LOL! The 2 wires sticking out of the dash are for the wiper switch and the kill switch from the MSD box. ![]() In other news.............word must have gotten around town that I was starting to loose interest in finishing my truck. The other day a total stranger came pulling up my driveway in this to give me motivation. Super nice guy with alot of advice. ![]() ![]() |
#318 |
Got everything buttoned up under the dash. That is after i realized I had the wrong guage for the Mustang sending unit, and had to take the cluster back out to change it.
![]() Also got everything buttoned up on the fuse block side. And NO, I didn't use enough tie wraps! ![]() Open............... ![]() Closed............. ![]() |
#319 |
I obviously don't use near enough zip ties. Clean work. Love the drawer
#320 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Looking good paintman.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#321 |
Hey does anybody have any experience with the one piece Vbend windshields? Do they fit? What vendor to use?
I have come to a crossroad and I'm trying to figure out what I want to do. The window frame I have has some rot at the bottom and I don't really see anyway to fix it. The cross bar covers it but just barely. I guess I could shot a load of panel adhesive behing the cross bar when I do the re assemble and then try to shape it to look half way decent. I really don't want to pop for $500 bucks for a new frame. Might as well just go the one piece glass rouet at that point. ![]() ![]() |
#322 |
If you are talking about the 1 piece windshields that are actually bent in the middle the problem you are going to have is the bend is more of a curve than a straight bend. I have never seen one that actually lays flat and looks right(and seals good). If you are talking a v butt window, I have always thought they were ugly because of the seam in the middle. There is a reason GM used a chrome piece in the middle. I personally think a frame that is chromed with the center bar looks the best in these trucks but that is my opinion.
#323 |
We used a V butt glass cut locally to fit a chrome WS frame and all is well, I think it came from Bowtie Bits and a bit pricey but it fits along with Steel rubber
#324 |
I personally think a frame that is chromed with the center bar looks the best in these trucks but that is my opinion.[/QUOTE]
It also sounds like you have no trouble spending $600+ of my money! ![]() |
#325 | |
![]() Quote:
![]() It is easier to spend your money than mine. But seriously your truck has the vibe that I think would look great with a chromed windshield frame. Plus how could you not have the leaky crank out windshield? ![]() |
