08-23-2016, 06:56 PM | #1 |
*NOOB* about to do an LS swap
Hey guys, I am about to jump off into my first LS Swap. I have purchased an LQ4 with a stage 2 cam, 5.3 heads, and some other goodies for my 72 C10. My neighbor has agreed to help me do the swap, but I have a few questions for the general group.
1. Headers. My SBC currently has short tube headers. If I put short tube headers on the LS, will my current exhaust work? Its okay to tell me if that's a stupid question. 2. Fuel line. I'm going with the blazer tank and 97 chevy fuel pump route. The engine is a 2001, so there is a return line. Should I run -6 or -8 for the return. And does anybody have any idea how much line I'll need of each for a 72 shortbed? Is there a kit that doesn't cost a thousand bucks? I'm going to get a DELPHI HP10001 from rockauto for the sending unit/pump. I can see in the pics that it has screw on connectors. AN fitting with fit that I believe. Thanks all, these are two questions I couldn't get solid info on through research. Any help would be appreciated. |
08-23-2016, 07:41 PM | #2 |
Re: *NOOB* about to do an LS swap
I used -6 on all my fuel line..supply and return...how much depends on where you mount the tank and how you route the lines...I bought a 25 ft bulk roll of stainless braid and fittings from summit and made my own lengths to what I needed ..just get you some rough measurements and go from there.. it wasn't all that expensive
On your headers exhaust question I doubt your pipes will work as is..I reused my pipes from my smallblock but had to have new inlets made to connect them Someone else may chime in but be careful about getting headers..not all will fit even though the manufacturer says they will.. |
08-23-2016, 08:10 PM | #3 |
budget - triple your estimate
time to do swap - double your estimate good luck |
08-23-2016, 09:50 PM | #4 | |
I think I'm gonna go to a reputable exhaust shop and let them make my exhaust. And I'm gonna do the bulk fuel line and get the fittings. |
08-23-2016, 10:11 PM | #5 |
My swap took me 2 weeks of 12 hour +days and double my budget estimate It was worth every hour and dollar
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-24-2016, 12:15 AM | #6 |
Hmm..time and money...I built my 6.0 LQ9 NV4500 truck about 3 yrs ago..I tried to do my homework on the swap before ever commiting to it..the guy i bought my engine from does LS swaps for a living and he slow walked me through the swap process before i started..but i did the work all myself...I didn't have any real surprises jump up and bite me..I only spent a couple hundred more on my swap than i had figured and didn't really keep up with my time..I took my time though cause I hate redoing things..but it still took less than 2 weeks just working part days before I heard it run..I did this swap before I found this site and all the info contained in it. The biggest hurdle was headers which I knew going in would be a issue..other than that I couldn't believe how smooth and simple it went..and like mario says.."worth every hour and dollar"..you sure won't regret it the first time you shove that right pedal to the floor.
08-24-2016, 10:05 AM | #7 | |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-24-2016, 11:08 AM | #8 |
Sorry, stage 2 is subjective to what you're doing I know. The cam upgrade is as follows.
We install a Stage 2 cam (224/234@.050 .612/638 Lift, 115 degree LSA), high lift dual spring valve springs and hardened pushrods. |
08-24-2016, 11:26 PM | #9 |
On your fuel line question I used my donor vehicles fuel lines, just pass the transmission. Bought a roll of Sur&r nylon line, push on fittings with their clamps, a blazer tank and the stock 2011 donor fuel pump. Super cheap
08-26-2016, 02:31 PM | #10 |
i second this.... thru experience!!!! lol
1967custom Last edited by michael bustamante; 08-26-2016 at 03:11 PM. |
