Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-04-2016, 10:40 PM   #1
3QTRTONS
3QTRTONS's Avatar
366 5+2 to gen VI 454 swap?
Looking for your thoughts....
I am considering swapping in a Gen VI 454 from my 2000 bus into my c60/c70 that currently has a 366 with a 5+2 trans. I haven't found much info about if this will work and what the pros/cons might be.
My C60/C70 is:
a '76 c60 Frame and running gear with an '85 c70 cab and nose.
My bus is now my "parts room" and I'm pretty sure the Allison trans is pooched.
1994 C1500 rclb 1988 C1500 rclb
1969 ES5500 B E A S T 1983 C10 'farm truck'
1976 K20 Suburban 1984 K10 Suburban
1981 Jeep CJ5/350 Vortec
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 09-05-2016, 06:39 AM   #2
rkn463
rkn463's Avatar
Re: 366 5+2 to gen VI 454 swap?
My C60/C70 is:
I don't know anything about the gen VI 454, if it happens to be a tall deck big block then I would expect everything will just bolt up. If it isn't a tall deck then you might have trouble bolting up the accessories. Since it is in a bus i think there is a good chance it is a tall deck. i think if you measure the width if the intake you will be able to tell. Also the flywheel might be an issue, I don't know if either of the motors are internally or externally balanced. If one is internal and the other external you may have an issue.
Good luck and let us know how it goes.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
