Old 09-14-2016, 09:18 PM   #1
T'S1972
A new member
First I want to say,Thanks to all you guys that offer up the free information on here. I am looking forward to contributing where possible. I have owned pickups previously but this is my first Jimmy/Blazer. I just picked it up in Bakersfield CA. I happened to be working here and drove past it and decided to go ahead and get a new toy. I am adding a four inch lift it had brand new 35" tires on it and were rubbing.PO had installed a sbc 400 in it that only has about 5000 miles and runs good. The only thing is it has a two barrel on it? I am also in the process of changing all ball joints,resealing the rear end, shocks and new body mounts. It will have to stay in original paint (patina)for now until I can gather up more money but that will be fine.
Thanks for the add.
Tom
T'S1972 is offline   Reply With Quote
Old 09-14-2016, 10:37 PM   #2
truckster
truckster's Avatar
Re: A new member
That looks like a very nice starting point for whatever you want to do with it. Congratulations - you're going to love your Jimmy. Over the years I've owned dozens of Chevy and GMC trucks from 64 to late models. My Blazer is my favorite of all of them.
truckster is online now   Reply With Quote
Old 09-15-2016, 09:54 AM   #3
lks dcvn
lks dcvn's Avatar
Re: A new member
Congrats on the new truck - these things are awesome when they are running/driving right.
A lot of people like the patina look.
lks dcvn is offline   Reply With Quote
Old 09-15-2016, 02:42 PM   #4
Chad22873
Chad22873's Avatar
Re: A new member
Welcome
BR549
Chad22873 is offline   Reply With Quote
Old 09-15-2016, 10:24 PM   #5
T'S1972
Re: A new member
Thanks for the welcome, Here are some picks of the BDS suspension going in.
Hopefully finished with suspension tomorrow.
Old 09-16-2016, 12:03 AM   #6
swyfor5
swyfor5's Avatar
Re: A new member
Welcome aboard!
swyfor5 is offline   Reply With Quote
Old 09-16-2016, 09:43 AM   #7
chastain90
chastain90's Avatar
Re: A new member
Nice Jimmy, looks like you got a really good starting point. suspension looks good too.
chastain90 is offline   Reply With Quote
Old 09-18-2016, 09:02 PM   #8
TheKorndog
Re: A new member
How was it getting the leaf bolts out? Been working on cutting mine out. Several blades and one bolt later... :-/
Nice truck!
1972 Chevy Blazer K5/CST 4x4
Stroked L31 & serpentine belt system (97 C1500 donor); K case 4L60e; Fitech GoEFI 4; In Tank retrofitted fuel pump tnk-pa-6; Fitech GoShift controller; 12 bolt Yukon gear posi 3.73 rear diff; NP205; Redhead steering gear; JB Custom Fab NP205 twin sticks
TheKorndog is offline   Reply With Quote
Old 09-20-2016, 11:58 PM   #9
T'S1972
Re: A new member
After the lift and new rallys. I will post better pics later.
Old 09-21-2016, 12:01 AM   #10
T'S1972
Re: A new member
Nice truck!
The bolts weren't bad the underside is rust free and clean on this thing. It had some undercarriage work done about 8 years ago and been garaged since then.
Old 09-21-2016, 07:27 AM   #11
jaros44sr
jaros44sr's Avatar
Re: A new member
looks much better already
welcome aboard
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-21-2016, 01:30 PM   #12
cleszkie
cleszkie's Avatar
Re: A new member
Did you put longer rubber brake lines on it? That picture of the new front springs shows the front rubber brake line being stretched to its limit, and probably preventing further droop of the suspension.
cleszkie is offline   Reply With Quote
Old 09-21-2016, 01:46 PM   #13
T'S1972
Re: A new member
I haven't put the lines on yet but I am going to. That picture was pretty much full travel frame was jacked up and no support under the axle. But I did ntice that I just did not have the lines at the time and I would like to add braided there when I do it. It will need rear brakes in the next few months so I will probably take care of it then.
Old 09-21-2016, 04:42 PM   #14
Yukon Jack
Yukon Jack's Avatar
Re: A new member
Welcome! Nice K5!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-21-2016, 10:11 PM   #15
solo72
solo72's Avatar
Re: A new member
Looks good! Nice jimmy! Does the 35's still rub? Mine rub with 4 inch lift done by the Po. Like the Patina!
solo72 is offline   Reply With Quote
Old 09-22-2016, 01:00 PM   #16
cleszkie
cleszkie's Avatar
Re: A new member
I figured that was on your to-do list. Very nice and solid Blazer. Welcome to the board!
Old 09-26-2016, 11:46 PM   #17
T'S1972
Re: A new member
I have a question, I am unsure on the original blue color the window sticker and SPID say dark blue the outside looks dark blue Then I see other trucks on here that are darker blue and my interior color looks lighter than other dark blue interiors. The PO did some interior painting 8 years ago, did he use the wrong color? or, are the other trucks I am seeing here painted a darker non factory color? I am attaching pics of my interior and exterior it is at the painters now so I have to figure it out, I was hoping to not paint the interior. Its not a great pic of the window sticker and I don't have one of the SPID.
Excuse the crappy motel I am out of town at work and they are cheap.
Old 09-27-2016, 12:17 AM   #18
T'S1972
Re: A new member
No they don't yet, I have only driven it on the road though, The BDS lift seems to be a little higher than others.
Old 10-12-2016, 08:50 PM   #19
T'S1972
Re: A new member
OK, so I had thought about leaving the Jimmy Patina because I did not have the money to paint it right all the way. I decided against that as I am taking it back to Texas and the rockers had bare metal places on the where they had been rubbed. The hood had some bare metal on it and in East Texas if it is exposed it is rusted away in no time,this truck has all its original metal and i wanted to protect it better. So I went with quick and cheap outside only paint job. I think it will protect whats there until I can do a better job. It's not perfect but they actually did a good job. I am proud. I also included a little tribute to my wife who passed away earlier this year.
Old 10-13-2016, 09:22 AM   #20
bambbrose
Re: A new member
Looks awesome, same color I'm going with.
Sorry to hear about the wife, that would be one of the toughest things I could think of going through.
bambbrose is offline   Reply With Quote
