Old 09-11-2016, 04:36 PM   #51
whitels1
whitels1's Avatar
Re: 1975 Chevy K10 Scottsdale Rebuild.
Looks awesome and the caps are a nice touch!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-11-2016, 07:57 PM   #52
MTCK
MTCK's Avatar
Man those look great. Go sling some mud.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-11-2016, 08:53 PM   #53
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thanks fellas!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-11-2016, 11:45 PM   #54
Greenlee
Greenlee's Avatar
Nice! The new tires and wheels look great.
Greenlee is offline   Reply With Quote
Old 09-17-2016, 10:31 PM   #55
y5mgisi
y5mgisi's Avatar
Finally got the k10 into the garage for the auto to manual transmission swap! Today I got the column out and the old pedal assembly out. Tomorrow morning I'll drill the hole for the linkage and get the new pedal assembly in and the column back in.
Old 09-18-2016, 01:26 PM   #56
whitels1
whitels1's Avatar
How are you setting up the clutch / linkage?
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 09-18-2016, 03:49 PM   #57
y5mgisi
y5mgisi's Avatar
I'm just using an original manual clutch pedal/linkage setup.
Got the pedals in and column back in.
Old 09-18-2016, 04:57 PM   #58
LT7A
Lol I have had a couple. Never really hit the spot the way all the other body styles do!
Hey y5,was catching up on your thread. I had commented awhile ago on the K5 ad that you posted. You had said that you weren't really stoked on the K5s (or something to that effect) and then I said, who wouldn't want a Blazer like in the ad. Answer: you! Ha. Just caught that on my re read and wanted to say that my comment wasnt a challenge to your comment. Just me gettin caught up in the ad.
The truck looks great with the new wheels and tires!
Old 09-18-2016, 07:25 PM   #59
y5mgisi
y5mgisi's Avatar
Lol all good my friend! And thank you! I'm ridiculously excited about how it looks now!
Old 09-20-2016, 08:47 PM   #60
y5mgisi
y5mgisi's Avatar
Trans is out.
Old 09-20-2016, 09:57 PM   #61
68Timber
I know the pieces fit
68Timber's Avatar
That's some slick thinking right there.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-21-2016, 09:26 AM   #62
y5mgisi
y5mgisi's Avatar
Thanks! I thought it was clever.
Old 09-21-2016, 06:49 PM   #63
jott_06
Camaro Club
jott_06's Avatar
its going to be a blast to drive with the 4 speed. And I dont know about you but I love the mechanical clutch's. My 88 Suburban has everything from a late 70's truck so its mechanical and it has a much nicer pedal feel than my boss's 85 k30 dumptruck or his stepdads 85 k20, both with Hydrolic clutch's.
jott_06 is offline   Reply With Quote
Old 09-22-2016, 04:01 AM   #64
MTCK
MTCK's Avatar
Best part about my 4 speed '77 was my wife never wanted to borrow it! Just kidding. Should be a blast to cruise. Something is just right about an old truck with a stick.
-Marcus
Project Plow Truck
Old 09-22-2016, 11:39 AM   #65
y5mgisi
y5mgisi's Avatar
I can't wait! Hopefully get it wrapped up here in the next couple weeks!
Old 09-25-2016, 09:43 PM   #66
NewType72
NewType72's Avatar
Always a pain not having help in the garage but it does make you feel like mcguyver when you get clever out there
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-26-2016, 08:17 PM   #67
y5mgisi
y5mgisi's Avatar
Had to get creative a good number of times over the years! I did get the flywheel and clutch bolted on.
Old 09-28-2016, 07:26 AM   #68
y5mgisi
y5mgisi's Avatar
I decided now would be a good time to replace the clutch fork and pivot ball...
And made myself up a neato little clutch linkage bracket.
Old 09-28-2016, 09:23 PM   #69
y5mgisi
y5mgisi's Avatar
Got the bell crank mounted up with my fancy little bracket.
Old 09-28-2016, 09:25 PM   #70
y5mgisi
y5mgisi's Avatar
And my solution to the problematic heat riser exhaust valve. I knocked out the shaft and drilled and tapped the hole for a bolt.
Old 09-29-2016, 07:53 AM   #71
68Timber
68Timber's Avatar
Looks good! The bracket you made, is that hard to find? Just curious, I have most all the parts to do the same swap but have never swapped an auto for a manual trans.
John
74 Honda Z50 build
Old 09-29-2016, 08:00 AM   #72
y5mgisi
y5mgisi's Avatar
I was having a little bit of a tough time finding one. I'm sure I could have but in the end I just decided that it would be easier to make one out of some angle iron I had.
Old 09-29-2016, 10:52 AM   #73
MTCK
MTCK's Avatar
Nice work on the fab. You should be grinding 1-2 shifts faster than you can say go!
-Marcus
Project Plow Truck
Old 09-30-2016, 10:32 AM   #74
y5mgisi
y5mgisi's Avatar
Lol!
Old 10-02-2016, 08:09 PM   #75
y5mgisi
y5mgisi's Avatar
Took it around the block a few times! So far so good!
