Old 11-12-2016, 09:15 AM   #51
Bennett68C10
Bennett68C10's Avatar
Re: A real BadSeed
Awesome build! You have some crazy metal shaping skills. Love the rendering too, cant wait to see more!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-13-2016, 10:55 PM   #52
MarleyMarvelous
Re: A real BadSeed
I'm using tools I've never used and doing things I've never done before on this truck. I try to learn something everyday, but when I'm in the garage I learn the most.
MarleyMarvelous is offline   Reply With Quote
Old 11-13-2016, 11:06 PM   #53
MarleyMarvelous
Re: A real BadSeed
Porterbuilt hood hinges.
Old 11-14-2016, 10:50 AM   #54
Rochlow
Re: A real BadSeed
love the defrost vents and smooth cowl.
Would you consider making some of the defrost vents to sell?
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 11-14-2016, 02:45 PM   #55
RRR18
RRR18's Avatar
Re: A real BadSeed
Excellent work.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 11-16-2016, 03:37 AM   #56
MarleyMarvelous
Re: A real BadSeed
Thanks! I wish I had time to do anything. I barely have time to work on my truck. I couldn't do it anytime soon
Old 11-16-2016, 03:38 AM   #57
MarleyMarvelous
Re: A real BadSeed
Originally Posted by RRR18 View Post
Excellent work.
Thanks you very much.
Old 11-16-2016, 04:17 AM   #58
casey g
casey g's Avatar
Re: A real BadSeed
Originally Posted by MarleyMarvelous View Post
Even more sure now.
what size are you wanting to run
casey g is offline   Reply With Quote
Old 11-16-2016, 02:58 PM   #59
goldenburb
goldenburb's Avatar
Re: A real BadSeed
I love your color of chose,, your skills but the most impressing thing to me is your building it in a home garage...WOW
Your the really talent not some bube with a marker..
Keep it coming.����
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 11-16-2016, 03:44 PM   #60
Hart_Rod
Hart_Rod's Avatar
Re: A real BadSeed
Nice build
Hart_Rod is offline   Reply With Quote
Old 11-16-2016, 10:04 PM   #61
MarleyMarvelous
Re: A real BadSeed
22" front and back. Did you shorten that axle? If so how much?
Old 11-16-2016, 10:06 PM   #62
MarleyMarvelous
Re: A real BadSeed
Keep it coming.����
Thank you. The compliments mean a lot because I'm self taught.
Old 11-16-2016, 11:37 PM   #63
casey g
casey g's Avatar
Re: A real BadSeed
We ordered a ford 9 inch for the truck. Wheel face to wheel face was 54 inches. They reason I asked about what size is there was another build with the same wheels and he was selling his. I'll see if I can find the link. Pretty sure he was 22/22
Old 11-16-2016, 11:39 PM   #64
casey g
casey g's Avatar
Re: A real BadSeed
http://67-72chevytrucks.com/vboard/s...=701520&page=3
Bottom of the page.
Old 11-21-2016, 12:52 AM   #65
MarleyMarvelous
Re: A real BadSeed
I wish I had the money already. I have to build accordingly. But man that's tempting. I saw you were unhappy with the front offset. What would you say would be a perfect offset for the front?
Old 11-21-2016, 01:02 AM   #66
MarleyMarvelous
Re: A real BadSeed
Here's a little trick I found. I got some solid round bar that was a little smaller diameter than the frame holes I plan to fill. I cut plugs on my bandsaw. Magnet on the back till it's tacked, then remove the magnet and burn it in
Old 11-21-2016, 01:04 AM   #67
casey g
casey g's Avatar
Re: A real BadSeed
Nice! when I plugged a bunch of holes I just put a copper backer on the back side and plug welded the holes
Old 11-21-2016, 01:07 AM   #68
casey g
casey g's Avatar
Re: A real BadSeed
I was just disappointed in the fact there really isn't any lip. I feel the back spacing is correct but since its a concave wheel they automatically have less lip. Raceline doesn't make that when in a non concave. If I could do it again I would do no concave in the front and concave in the back.
Old 11-21-2016, 01:07 AM   #69
MarleyMarvelous
Re: A real BadSeed
I cut out the inner boxing plates and installed the ones at the notch first. And blended out the frame rails.
Old 11-21-2016, 10:05 AM   #70
JustToxic
JustToxic's Avatar
Re: A real BadSeed
I love the amount of fab work going into this truck. Great looking build so far.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 11-21-2016, 03:53 PM   #71
MarleyMarvelous
Re: A real BadSeed
That's how I did the smaller ones too.
Old 11-23-2016, 11:09 PM   #72
MarleyMarvelous
Re: A real BadSeed
Frame notch (top) welded in. I opened up the inside of the notch so I can run my hoses and wires through the frame to the fuel cell, air management system, and body electrical
Old 11-24-2016, 03:54 PM   #73
MarleyMarvelous
Re: A real BadSeed
I scored some original C10 wheels to use for rollin purposes until I can purchase the 22" wheels im gonna run. I got enough done on the notch to drop it down and introduce the frame to the ground for the first time flat frame rails.
Old 11-24-2016, 04:00 PM   #74
MarleyMarvelous
Re: A real BadSeed
I never buy stuff on Craigslist or anywhere else. But, in 1 week, I found wheels on Craigslist, and these 2 OEM 67 grilles on OfferUp. Both were great deals too. Gonna have to look more often
Old 11-24-2016, 04:40 PM   #75
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Re: A real BadSeed
I was born in Chula Vista and Castle Park High class of '77. As we would say back then "Radical Man" and your build is awesome! I'm staying tuned...
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
67 c10, badseed, marley marvelous
