Old 11-12-2016, 08:12 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Can anyone kindly ID these three parts please?
Picture should be self explanatory. I'm hoping for names and descriptions. Thanks for any input. Edit, that white wire runs up into a harness. Don't know what it powers, but with that and the scotch lock, it's a good guess it's not supposed to be spliced.
On a side note, this restoration business is a kick in the pants. I can see why it's a lifestyle for many.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-12-2016, 08:17 PM   #2
toolboxchev
Re: Can anyone kindly ID these three parts please?
Clockwise, Horn Relay, Brake light switch, and finally the dreaded ignition reverse and drive starter lock out circuit.
toolboxchev is offline   Reply With Quote
Old 11-12-2016, 08:18 PM   #3
irl104
The relay - is for the horn. Whats That - is the brake light switch. Not sure on the white wire. More educated people will chime in.
irl104 is offline   Reply With Quote
Old 11-12-2016, 08:30 PM   #4
69chevytrucker
69chevytrucker's Avatar
toolbox is right on all three
ui would say the scotchloc is maybe done to jump the reverse light just a guess though
69chevytrucker is offline   Reply With Quote
Old 11-12-2016, 09:09 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Can anyone kindly ID these three parts please?
Big arrow pointing down at it. Top left Horn relay. Little arrow pointing left: brake switch
Bottom is the reverse lights and neutral safety switch. It goes on the steering column when it's installed through the hole in the fire wall.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2016, 09:15 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Take the wire tap off and the short white wire will come with it. You don't need it....
LockDoc
Leon
Old 11-12-2016, 09:45 PM   #7
undertaker72
undertaker72's Avatar
toolbox is the winner , give him a lolipop
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 11-12-2016, 09:52 PM   #8
JJR
JJR's Avatar
Being that the white wire goes to the brake light switch, I would guess one of the previous owners may have installed a trailer brake controller.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 11-12-2016, 09:58 PM   #9
Jeff's bowtie's
X2 on the brake controller for a trailer
Jeff's bowtie's is offline   Reply With Quote
Old 11-13-2016, 12:35 AM   #10
71CHEVYSHORTBED402
You guys will laugh, not about Guy I mean. I likely did too when this truck was new to me (1989). We worked in a shop, and my buddy, Guy, who has since been murdered (literally), was a practical joker. I believe in one instance, the horn would go off when I turned the blinker on. There was at least one other occasion, so I believe what you're looking at is brake to horn.
Correction: Post #8, BINGO. This did have a brake controller. I removed it decades ago, so I'm likely the culprit. I'll leave the above story up for entertainment value, though RIP Guy.
Thanks Lockdoc on the Scotchloc. I'm rewiring this entire thing anyway.
Thanks for all the responses. I don't know what a "dreaded ignition reverse and drive starter lock out circuit" is, but I'll look it up. Perhaps that's another term for neutral safety switch and it runs to the ignition? I'm just guessing here, at some point I'll chase all the wires.
Thanks for all the info.
Tony
Old 11-13-2016, 08:18 AM   #11
Andy4639
Old member
Andy4639's Avatar
Why is it when add on electrical connections like in your picture on the brake wires people feel they need to address them. That wire could be for anything!
I don't address things like that in my answer's for one reason. I have no idea what the person who installed it was doing. The wire could be for a third brake light. Who knows what it's for.
I have been working on these trucks for over 30 years and I have seen stuff that I had no idea why it was wired as it was are how in the world it even worked.
And yes this is the same thing.
Neutral safety switch and back up light switch!
Old 11-13-2016, 10:41 AM   #12
toolboxchev
I got rid of my Revere, Neutral Switch Safety deal thingy.
I like my truck more better!
Old 11-13-2016, 03:51 PM   #13
71CHEVYSHORTBED402
I get it to extent, but think I'll keep mine. Was just edgucated on install: http://67-72chevytrucks.com/vboard/s...d.php?t=633796
Mine was missing one screw.That was a common theme inside this cab. But that's what I bought my 72 for:
The tap was definitely for trailer brakes. In addition to that, the original owner had the following on this SWB: Step bumper W receiver hitch > fifth wheel with brackets mounted to frame, and of course bed holes. > saddle gas tanks > camper mirrors > CB > boat launching hitch.
Between that and MANY loads of rocks and dirt, and the fact he bypassed the factory transmission cooler for an auxiliary, everything they say about the 400TH is true. It still feels new. I even hauled what had to have been 5-6 ton of rock in a trailer once, 30 miles. Course 25 MPH down the highway. Not the wisest decision. Building with rocks is a passion for me, but this new bed won't haul more than a blanket....That's what the 72 is for as well.
Tony
