11-15-2016, 04:48 PM | #126 |
Re: Daves new 68 chevy swb
Looking good. Bet you got lot of neighbor visits when the truck rolled out into view.
11-15-2016, 10:00 PM | #127 | |
Wide n'Low
Me In the past anyway
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
11-15-2016, 11:54 PM | #128 | |
It seems like a good idea. I want to get all the hardware in the door and get it for sure where I want it before I cut the fender.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
11-18-2016, 07:09 PM | #129 |
Still working on body lines. Making great progress. Here's what it looks like after a little slicing and dicing and bfh persuading.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 Last edited by Woodnears; 11-19-2016 at 11:16 PM. Reason: Misspelling |
11-21-2016, 11:52 PM | #130 |
Took a side step and am focusing on the bed floor for a bit. Designing it in sketchup to work out any bugs.
03-01-2017, 12:32 AM | #131 |
Its time to get this thread back beating again. I hung all new sheet metal and aligned the panels for the most part. still have a bit of fitting left but for the most part they are fitted. Has anyone sent a rear diff to Moser for rebuild? Coming up next will be front and rear inner fenders, bed wood and the interior. i need some suggestions for vendors for the interior/ buddy buckets, door panels inner door mechanicals. I also am taking suggestions on bedwood. I really like the look of a clear or light maple.
03-01-2017, 01:14 PM | #132 |
Still Learning
Your body looks way better after you adjusted with the bfh.
I can't help you with the wood bed since I used all steel on mine. hang in there, someone will help you out. |
03-01-2017, 08:25 PM | #133 |
I would use truckseats (member on the board) for your buddy buckets/door panels. I had him build mine and they turned out great. My door panels match my seats. As far as the wood be careful what you finish it with. I used poly urethane that a paint Store recommended and it ended up sealing the wood too well causing it to crack and split. I ran across another company at good guys that specializes in bed wood and they sell a great product according to them and they say it won't do the same thing. I will look them up when I get home.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-01-2017, 09:53 PM | #134 |
I live about 15 miles from Moser engineering- I've never heard anything bad about them.
03-02-2017, 07:56 PM | #135 |
I am trying to get some prices together. Does anyone know what a rebuild on a rearend goes for these days? I was gonna just send it to Moser and have them go through it new axles bearings the works.
03-02-2017, 08:35 PM | #136 |
I had my rear end rebuilt for $150 labor. I applied all the parts. Posi and all timken bearings
03-02-2017, 08:56 PM | #137 |
who makes a buddy bucket center seat foam?
03-02-2017, 08:57 PM | #138 |
Most good upholsterers can build you the center seat foam.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-02-2017, 08:59 PM | #139 |
The problem is there are no "good" upholstery shops here. I live in the sticks!
03-02-2017, 09:01 PM | #140 |
, I hear you! You can probably make it yourself, it's pretty straigaht forward. 2" thick and a rectangle, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-02-2017 at 09:07 PM. |
03-02-2017, 11:41 PM | #141 |
Let's talk 2.5" exhaust for a bit. I'm looking at mufflers and wow there's plenty of choices. Im running stock Camaro manifolds. Can I use a 90 after the manifold or should I use two 45's back to the pipes. Any suggestions on mufflers are appreciated. I'm looking for a nice drive able tone that's not too annoying.
03-03-2017, 08:36 AM | #142 | |
03-03-2017, 09:17 AM | #143 | |
03-03-2017, 10:22 AM | #144 | |
It's best to look around and see what kind of reputation a shop has, then ask them for an estimate for the work. But budget a little higher, just in case.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
04-05-2017, 08:24 AM | #145 |
Awesome work! I'm in for updates.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
06-06-2017, 06:24 PM | #146 |
Guys, either my pm's aren't coming through or the few vendors I've contracted are ignoring me. Anyone ever had this issue? Anyways I've sent a few pan's requesting prices in carpet, weather stripping, and seat foam. Not sure what's going on. Anyone have ideas where I can order these items online. Naturally I want the good stuff. Thanks for your input.
06-06-2017, 06:42 PM | #147 |
Never any problems for me with pm anyone on here.
06-06-2017, 06:58 PM | #148 | |
06-06-2017, 07:26 PM | #149 |
Hrs one of them I can't get a response from. Pm sent
06-06-2017, 07:53 PM | #150 |
Anyways here's a few update pics while we wait.
