12-01-2016, 02:49 PM | #276 |
Re: Post your Bed Wood/Metal - Customized/Modified or Stock
The diamond plate looks sharp and I bet it's functional, too
My truck ain't dead, it just smells funny. |
12-01-2016, 03:54 PM | #277 |
12-22-2016, 01:14 PM | #278 |
One piece of 3/4 cabinet grade plywood, that was split down the middle and covered in tiger stripe veneer. New stainless with the sliding adjustable bolts.
Bed was also raised 3" due to the lowering of the truck. Sides were sprayed with Raptor liner. |
12-22-2016, 01:35 PM | #279 |
12-22-2016, 09:13 PM | #280 |
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
12-22-2016, 09:23 PM | #281 |
looks good you have ben hard at it
12-23-2016, 11:24 AM | #282 |
Nice Jim.. wanna come over and help me with mine?
12-23-2016, 07:45 PM | #283 |
Sure now that I know what I'm doing
12-25-2016, 12:15 PM | #284 |
Just finished getting my bed wood installed yesterday. Wood is Oak that has been lightly scorched.
12-25-2016, 09:59 PM | #285 |
12-26-2016, 10:07 AM | #286 |
cioutlaw ,nice touch i really like the look!
12-26-2016, 10:12 AM | #287 |
Mar k oak ebony stain and boiled linseed oil.
12-27-2016, 12:45 PM | #288 |
I got bed rails for Christmas. Thought I would mock it up before I started bolting everything down. I took me half the day to drill holes in one angle strip cover and install it.
03-30-2017, 04:25 PM | #289 |
finished it up
02-04-2018, 01:03 AM | #290 |
Went from steel plate over the wood to factory specs. My dad and I cut, routed, and stained the wood ourselves. Used the bed strips I had in the truck since they were still in good enough shape and got new bolts all around. Completed this part of the project over the summer, and not long after used it to snag a fridge for my dorm room. I added some tie down points since there weren't any down low from the factory.
All the info on this forum has helped me a ton since I bought the truck, thanks everyone.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-04-2018, 09:49 PM | #291 |
02-04-2018, 10:12 PM | #292 |
It's Better With Nitro
Flame burnish then red mahogany stain.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
02-05-2018, 06:48 PM | #293 |
Ipe...or Brazilian Walnut...Super hard, weathers to a grey if you don’t oil it. Has to be drilled when used as a deck material to put fasteners in it. Stuff is so hard and dense it don’t float. Found it in 3.5, 5.5 and 7.25 widths and it works in the original mounting holes, you do have to trim the 3.5 down a bit to tuck it under the two side strips so the holes show up. Adds a little more weight, but that should just give a better ride for our coil spring trucks. Buying the boards and routing the grooves for the strips myself was cheaper than all pre drilled oak kits I could find. And I hid the bed/frame bolts by inserting the bolts heads into the board’s underside with a forstner bit. Stacked head dado cutter on table saw, two passes for the strip insets...picts of a test board...
06-08-2018, 01:29 AM | #294 | |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-08-2018 at 09:49 AM. |
08-04-2018, 02:47 AM | #295 |
Here's my shoptruck bed, just finished this week.
Walnut budget style. I used spruce 3/4"x6" burnt the grain, two coats of Nescafé Brasero instant coffee , one coat of walnut stain topped of with three coats of varnish. I think it turned out great for a budget bed floor.
Driver carries no cash. He's married. '67 Chevrolet C10 SWB - 350 Vortec/TH700R4 Backyard Engineering |
08-04-2018, 11:31 PM | #296 |
60-66 Nut
Looks good.....interesting use of coffee
Fredrikstad.....I like that town and I want to go back and spend more time there as well as some other places.
08-06-2018, 10:44 AM | #297 |
Black walnut from our property.
