Old 12-28-2016, 10:28 PM   #1401
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
The solution for the contact between the pinion stub shaft U-joint and the cross member is to notch the cross member with a pipe notch. Cut out here, it will be finished when I take the powertrain out again.
Steering almost worked with only two u-joints though it needed three to clear the frame and exhaust header. I still need to do the stake procedure per Borgenson directions and this part is done. Their parts are pricey and worth it...don't cheap out on steering.
Next up is mounting the brake pedal assembly bracket...marked out here from fitting.
Decided to take a look at that again tomorrow to verify accuracy before drilling holes in the firewall. Really don't want to do that wrong....
Oh, check out the light my new Snap On LED puts out. Wow, under dash is now as bright as shop floor. And the light isn't hot.
Advanced Design is offline   Reply With Quote
Old 12-29-2016, 12:07 AM   #1402
youngrodder
youngrodder's Avatar
Steering looks great Doug. I need to get the LS mock up block back to confirm my set up clears the headers...It's nice having functional steering when pushing the truck around. Since I swapped the 20's up front I was able to hook up my steering rack links.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-29-2016, 12:22 AM   #1403
iowaboynca
iowaboynca's Avatar
You aren't kidding about those lights. I bought a pair at Costco a while back. Just like you said, bright but not hot. That was a big win with me as i have a ton of little ones running around.
So who's going to end up with the sweeter 'burb? You or youngrodder?
Right now, its neck and neck. I realize it's not a competition, but nice.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 12-29-2016, 06:05 AM   #1404
RockinKees
RockinKees's Avatar
Steering looks good Doug!! Wish mine was that "easy"....
I've got a small version of that worklight, I find them really nice to work with.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-30-2016, 03:29 PM   #1405
99 to Life
99 to Life's Avatar
very clean looking
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-30-2016, 04:52 PM   #1406
joedoh
joedoh's Avatar
haha nice light, I got rechargeable LED shop lights for christmas so no more knocking around that old (and hot) drop light
column looks great, nice install pics!
I have a question about the upper arms, I see the slots are in the direction of force of the arms, do they ever loosen (or even not loosen) and go out of alignment?
Old 12-30-2016, 07:02 PM   #1407
Advanced Design
Marc
Thanks Marc, hopefully yours will fit OK. If my engine would have been a little higher, I think two joints would have done this one.
Yep, those lights are bright...it still freaks me out they aren't hot, so that is really good for safety. Sweeter Burb? Marc's, like I mentioned on his build, only AD on the planet with Porterbuilt drop components.
Thanks Kees...easy..yeah, not bad. I ordered a small light too and it showed up today.
Originally Posted by 99 to Life View Post
very clean looking
Thanks 99! Looking forward to your engine updates and TCI install.
Oh I have disliked the old drop lights since my college days and one branded my arm in a tight spot under dash. Thanks, column looks like it will work.
The slots in the upper arms are styled after the original 74 - 78 Mustang II using T bolts (serrated on bottom) to clamp the arm in place. Cater and camber obviously adjusted by loosening the T bolt and sliding. They work OK I guess as there are many out there. One came loose on my black truck once..
Brake pedal assembly, booster and master cylinder are in place. The hardest hole to drill in that new firewall was the first one. Really took my time in measuring, marking and verifying and they came out dead on.
Made a little support for the end of the brake pedal assembly to tie it into the diagonal brace under the dash. Wow, I had fabricators block on that one as I stared at it and fumbled around with various ideas for 2 hours. I think the downward force of a brake apply is now spread evenly across the back of the brace.
Those little switch on magnets are really handy! Was it 99 using them last year and I ordered some?
The cross piece on top of the brace is welded solid across the back. Front side has three short welds.
Now to get the brake push rod length adjusted for the booster and master cylinder.
Thanks again to Mark - Reaper71- for the lead on this brake assembly from Speedway. Booster came from Summit and Wilwood from my friend Mike at Rutters Rod Shop.
Old 12-30-2016, 07:09 PM   #1408
Advanced Design
Fun putting shiny new parts together....even if only for test fitting.
Old 12-30-2016, 08:40 PM   #1409
oldman3
oldman3's Avatar
Doug, should have no problem with the brace. Pedal looks good. Have a happy New Year...Jim
oldman3 is offline   Reply With Quote
Old 12-30-2016, 09:00 PM   #1410
reaper71
reaper71's Avatar
Came out nice Doug just like you planned!
Mark...
reaper71 is offline   Reply With Quote
Old 12-30-2016, 11:14 PM   #1411
youngrodder
Looks great Doug. The dashes are pretty flimsy. I know mine could benefit from an additional brace and that's even with my brakes being a frame mount.
Nice looking booster..
Marc
Old 12-31-2016, 06:46 PM   #1412
Advanced Design
Thanks Jim, Mark and Marc.
Last update of the year... Fabbed up and installed the fuel fill pipe support today.
Happy New Year to my internet friends!
Old 12-31-2016, 11:29 PM   #1413
youngrodder
You know that's cheating using that lift don't ya??? That modification would be more satisfying laying on your back under the suburban...
Happy New Year Doug
Marc
Old 12-31-2016, 11:42 PM   #1414
MIKESAD50
Very nice build. wish I had some of you ability. Really like the build. hope some day to have a Burb to match the truck.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-01-2017, 03:03 AM   #1415
joedoh
joedoh's Avatar
what he said! I have a brace from the pedals to the dash brace too and the firewall still flexed with vigorous brake application. if you want some piece of mind run a "foot" of some angle from the booster mount down the to the toe board.
I love those little switch magnets, just the right size for lots of stuff. I used one to hold the door open on my 41 tonight!
Old 01-01-2017, 11:03 AM   #1416
reaper71
reaper71's Avatar
Happy New Year Doug to you and yours..
Mark..
Old 01-01-2017, 09:20 PM   #1417
Advanced Design
Happy New Year Doug
Marc
Yep, it is cheating and we were discussing that when adding in the support bracket. Glad we have the lift. Happy New Year to you too Marc!
Thanks Mike. Really been enjoying your build.
Yeah, you are right. I've been telling myself I will evaluate firewall flex later and address if needed...I just need to do it now. Oh right, you had a post about the switch magnets. Short video...
Mark..
Happy New Year Mark!
Old 01-03-2017, 07:34 PM   #1418
lower50's
lower50's's Avatar
Happy new year!! I have a brace from my fire wall to the dash and I see no flex. Yours looks much nicer tho That light will be real nice when you get to the under dash wiring.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-04-2017, 05:39 AM   #1419
RockinKees
RockinKees's Avatar
Happy new year Doug and your family!!
Nice and simple support for the fuelpipe.
I also made my own bracket between firewall and dash, I have no flex.
Already had to make an emergencystop at 30mph, all is still in one piece
I'm with Lower, yours look plenty strong!!
Cheers!! Kees.
Kool Guyz CC
Old 02-12-2017, 12:46 AM   #1420
Scott2
Originally Posted by Advanced Design View Post
When I went to PRI Thursday I stopped by Koul tools. They were really good guys and enjoyable to talk with...plus they had a show special of free shipping.
I couldn't resist and ordered one....way overkill for what I need....and I will be ready for the push lock hose assembly on this Burb.
I have the same kit and really like it - god buy!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 04-14-2017, 08:00 PM   #1421
T-P Auto
Doug;
Have posted new pic on the panel project;
Al so posted New pic in the Alternate Tinkering post.
T-P Auto
T-P Auto is offline   Reply With Quote
Old 06-10-2017, 12:00 PM   #1422
55 Chevy Dave
55 Chevy Dave's Avatar
The Burb is looking great Doug. The pedals and steering aren't the funnest part of the project but definitely necessary. Your install on each looks great.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 06-13-2017, 05:59 PM   #1423
Advanced Design
Thanks guys! Dave, appreciate your positive comments, you do such awesome work! Apologies for lack of Burb progress....we've been busy with many other projects, adventures and duties it seems this year. Shop Ceiling repair and paint, gator engine, lawn mower stuff, funerals, family, yard projects. Basically life ...
We are in the middle of Long Haul on Hot Rod Power tour right now. What a blast! St. Louis, Indianapolis and Bowling Green left to go.
So, we plan to be back on this Burb soon.
Thanks for hanging in there with us.
Old 06-13-2017, 06:13 PM   #1424
iowaboynca
iowaboynca's Avatar
Welcome back!
Yeah, life has a tendency to do that.
Have fun on the tour. We want pics!
Old 06-13-2017, 07:27 PM   #1425
smbrouss70
smbrouss70's Avatar
Have fun on the tour! I wish I was running alongside of you.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
