Old 12-28-2016, 09:10 PM   #1
idbeast
new bed step part fustration...
I bought new bed steps and brackets for the '56, but the braces wouldn't fit, thinking I ordered the wrong ones, I ordered a second set... got the same ones from Dynacorp... do I have the correct ones????
idbeast is offline   Reply With Quote
Old 12-28-2016, 09:51 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: new bed step part fustration...
Looks like, "Cut to fit, bend to suit, paint to match".
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-29-2016, 12:00 AM   #3
iowaboynca
iowaboynca's Avatar
or better yet..."Hmm...looks like i need a new hole..."
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 12-29-2016, 12:07 AM   #4
paulspickupparts
At some point in its life your bed may have been changed from a 60-66 . You ordered the 55-59 bracket. Can you used the bracket shown attached to the bed?
paulspickupparts is offline   Reply With Quote
Old 12-29-2016, 12:10 AM   #5
Joe Pass
Joe Pass's Avatar
55 thru 59 brackets are different than 60 thru 66....as are the cross sills because of frame changes and widths.....wrong year bracket or bed?
Joe Pass is offline   Reply With Quote
Old 12-29-2016, 12:13 AM   #6
Joe Pass
Joe Pass's Avatar
The existing brackets you show are the style on my 62....my 56 has your new style....you probably have a later bed adapted?
Old 12-29-2016, 12:27 AM   #7
paulspickupparts
X2^
Old 12-29-2016, 11:32 AM   #8
my56chevytruck
my56chevytruck's Avatar
As said, the brackets you ordered do fit the 56. drill another hole??
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-29-2016, 12:55 PM   #9
idbeast
I guess I'm going to drill a couple holes, I just wanted to check first, this aftermarket parts stuff is frustrating to say the least! The holes in the bed steps are off and needing lots of work to make them straight and fit properly!
Old 12-30-2016, 04:07 PM   #10
my56chevytruck
I'm wondering if those originals were from a different truck to begin with. seems as though from your pictures that your originals differ greatly from the new ones you've bought.
1940 Ford Dlx Coupe
1969 Mach1
Old 01-07-2017, 12:22 AM   #11
idbeast
So I got this figured out, my bed steps were not formed at a 90 degree angle, so I cut webbing and formed them correctly and it fits good with the proper braces!
Old 01-07-2017, 01:38 AM   #12
mongocanfly
mongocanfly's Avatar
Glad you got it figured out...in your first pic in post you can see that the new and old steps are different..the one where you have one on top of the other
Old 01-07-2017, 02:05 PM   #13
Russell Ashley
Russell Ashley's Avatar
Glad you got it figured out. Do you have the rod that goes from the frame to the step to support it? I haven't seen it in your pics.
Russell Ashley is offline   Reply With Quote
Old 01-07-2017, 02:36 PM   #14
idbeast
I ordered a new set that I just received, I'm waiting for my garage to warm up as it was 32 degrees in the garage this morning and only 27 right now!
