Old 01-03-2017, 06:10 PM   #1
KyleSeal
KyleSeal's Avatar
Rust Proofing In Hard to Reach Spots...
Just finished up floors, rockers and corners, my question to the board is how do we keep the welds on the interior to the panels from rusting? Is there a specific way to keep them from rusting? A spray that we drill a small hole and shoot through?
I intend on keeping this truck for a long time and dont want to have to redo these panels soon.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-03-2017, 06:20 PM   #2
scooterpimp
scooterpimp's Avatar
Re: Rust Proofing In Hard to Reach Spots...
They have a waxy type rustproofing that sprays through a small hose for inner doors & cavitys. Used for years at dealership , i believe eastwood has a similar setup. It fogs inner panels.
scooterpimp is offline   Reply With Quote
Old 01-03-2017, 06:59 PM   #3
paul blair
EASTWOOD Has Rust Encapsulator and internal frame coatings in spray cans with a flexible 24 in. hose and brass nozzle you could use along with rubber plugs(drill holes to fit) It is thin and will flow out of any cracks or drain holes in panels. messy so wear gloves and protect your finish paint. Check it out and beware of drain holes in doors and rockers! GOOD LUCK
paul blair is offline   Reply With Quote
Old 01-03-2017, 07:21 PM   #4
cooter26
cooter26's Avatar
I have seen them use a bed liner type rubberized spray from a opening after but at a minimum I coat the backside with a weld tru primer or something with zinc before I weld it in.
Corey
1991 V3500
cooter26 is offline   Reply With Quote
Old 01-03-2017, 07:34 PM   #5
Gromit
I used this spray corrosion stop product from Home Depot ..(my photo attached)
I got the idea that this area (the space between the inner and outer roof sheet metal) might be a problem area deserving of attention from board member "bcutt" who did his roof sheet metal restoration and took the trouble to try and help the rest of us by posting photos of his work (please see attached photos of his from this forum) back in December 2011
Actually I really think bcutt should have gotten some kind of maximum award or medal for his total heroic effort on the part of devotion to these trucks... he did an amazing job - On one of the most technically difficult sheet metal areas - lots of compound curves and close tolerances..Class AAA work!
Here is a link to what he shared:
http://67-72chevytrucks.com/vboard/s...d.php?t=496154
Gromit is offline   Reply With Quote
Old 01-03-2017, 08:56 PM   #6
LongBox
I have found a spray product from a buddy who worked at the hangars at the local airport. It is used to prevent corrosion on airplanes. It is called "Ardox" or something like that. I used it 28 years ago on an old MG I had, and it totally prevented any corrosion on the steel body.
I suggest finding an airframe mechanic, and asking him what they use in the local hangars.
If y0u need the exact name, let me know, and I'll go out to the garage and find one of the cans. It's an aerosol spray can.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 01-03-2017, 09:24 PM   #7
projectking
projectking's Avatar
http://m.skygeek.com/ardox-av-8-corr...FVG2wAodss8FtA
Is this the stuff?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-03-2017, 09:35 PM   #8
john@thepier
john@thepier's Avatar
I have been having all my vehicles cavity waxed like the first response suggested, stuff is sprayed in at the consistancy of say chicken broth and flows into all the nooks and creeces before it solidifies. I have had crew cab trucks and suburbans done, cost about $200-$250 at a reputable shop
john@thepier is offline   Reply With Quote
Old 01-03-2017, 10:07 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
We used 3m rust fighter when I was still working in the body shop. It cures to a solid waxy consistency.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 01-03-2017, 11:06 PM   #10
Dustytrix
Ospho, read up on it. I used it and it seems to work good. Found it on hot rod forums.
Dustytrix is offline   Reply With Quote
Old 01-03-2017, 11:27 PM   #11
LongBox
Originally Posted by projectking View Post
That looks like it, only the one I have is an aerosol spray. It forms a kind of barrier film over the metal that repels water. Tomorrow, I will get the camera out and take a picture of the can, then post it.
Rick
Old 01-03-2017, 11:42 PM   #12
KyleSeal
KyleSeal's Avatar
So does the Eastwood stuff just find its way to different areas or do I need to drill a bunch of holes to spray?
Is there anything I can do at home to work? Something like the fogging stuff that finds its way into unreachable cavities?
Old 01-04-2017, 12:20 AM   #13
ratty69
That kind ( AV8 ) forms a hard film that's reddish and dry to the touch. They also make AV30 which forms a soft wax like bacon grease. When I worked in aircraft maintenance, we sprayed AV30 over top of dry AV8 for the ultimate seal. The soft waxy film gets in everywhere and doesn't chip off.
If you decide to spray this stuff, a full-face respirator and tyvek suit is a good idea. One thing about about aviation chemicals - they work great but are really TOXIC.
ratty69 is offline   Reply With Quote
Old 01-04-2017, 12:46 AM   #14
HO455
HO455's Avatar
I drilled one inch holes and used a undercoating gun with a flexible wand to spray POR15 everywhere on my 67 Burban. I went with one inch holes so I could use factory plugs to fill them afterwards. If you want more information check out my Working Man's Burban thread in the Suburban section. You could use the same gun to spray Fluid Film in the voids also. It is an old school rust proofing agent that is non-toxic and works well.
RIP Bob Parks.
Old 01-04-2017, 05:39 AM   #15
Bigdav160
Bigdav160's Avatar
A schutz gun and cavity wax.
Although, I think the EPA and their crackdown on VOC has caused a lot of these products to go off the market.
Get it while you can
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
paint, panel replacement, patch panel, rust, rust proofing
