Old 01-06-2017, 11:16 PM   #1
BronzeGMC
BronzeGMC's Avatar
Ls with nv3500 trans
I got this truck today 1990 4x4.
What's it take to keep the transmission i have and bolt in a 5.3 out of a 2002 truck?
Different fly wheel? Bell housing adapter?
BronzeGMC is offline   Reply With Quote
Old 01-06-2017, 11:24 PM   #2
mild68
mild68's Avatar
Re: Ls with nv3500 trans
I used a 5.3L w a NV3500 in an S10. From what I have found is the pilot bushing/bearing you use depends on the year of the engine. My trans is a 96 from a S10. The 5.3 is a 2000. I used a flywheel from a 2000 4.8L full size. I got luck w the pilot bushing. It too was from a 2000 4.8L full size, as was the clutch kit I used. Different year 5.3's can use either of 2 different pilot bushings. The one I was able to use is the smaller diameter that fits deeper in the 5.3 crank. Some are a large diameter that don't fit deep in the crank.
Hope that's clear.
mild68 is offline   Reply With Quote
Old 01-07-2017, 06:54 PM   #3
BronzeGMC
BronzeGMC's Avatar
Would a 6.0l be a better option to mate up to my transmission.?
Old 01-07-2017, 07:46 PM   #4
grumpyolddog
You would want a NV4500 with a 6.0L
grumpyolddog is offline   Reply With Quote
