01-09-2017, 12:52 PM | #2576 |
Re: What did you do to your truck today part III
Working on a set of custom tail light brackets for my step side. So that the wires will run inside them. It was raining so I could not finish installing the bed wood.
01-09-2017, 06:22 PM | #2577 |
Added braided brake lines from INLINE TUBE last night.
01-09-2017, 06:46 PM | #2578 |
Drove around and fine tuned stuff, Found the clutch fork return spring missing and damn it, may have to replace the old Harrison radiator after all.
But all in all, not a bad ride!
Everybody has to believe in something. I believe I'll have another beer. |
01-09-2017, 07:01 PM | #2579 |
this is coolio
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
01-14-2017, 01:57 AM | #2580 |
Got my custom tail gate today.
01-14-2017, 10:09 AM | #2581 | |
Wow that looks good. Where did you get it? |
01-14-2017, 11:56 AM | #2582 |
mar k
01-14-2017, 12:02 PM | #2583 |
Getting all of my bed parts.
01-15-2017, 04:04 PM | #2584 |
I cleaned the old 6 banger to try and determine where all the oil leaks are. This exposed some casting numbers which after consulting the database on here, told me this isn't a 230 like I thought, it's in fact a 250 produced from 68 to 84. Holy crap, learn something new every day!
01-15-2017, 04:08 PM | #2585 |
Last night I installed the front bumper after painting. My truck was black with gray scallops but I've given her a makeover. I may add red scallops.
01-15-2017, 04:26 PM | #2586 |
Active Member
Reversed my rear bumper, will have to see if it grows on me. I do like the nice straight line on top now.
01-15-2017, 06:06 PM | #2587 |
01-15-2017, 06:30 PM | #2588 |
Took my '56 out of the garage so I could see how the 1.5 inch drop springs and 2in drop spindles look, also decided to sweep the floor before I put back inside!
01-15-2017, 08:01 PM | #2589 |
Well, I tried to install my rear back window but I, apparently, am an idiot. Couldn't get past the corners without tearing the seal, which I did. Going to have the local glass shop. They did a great job on my windshield.
01-17-2017, 06:08 PM | #2590 |
built new throttle linkage from the stock pedal mechanism to the Rochester Quadrajet. Ended up being really simple which was nice for my first engine swap
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
01-17-2017, 06:48 PM | #2591 |
Make sure you are getting full throttle. I had the same set up and could not get full throttle out of it.
01-18-2017, 10:43 AM | #2592 |
I'm just glad to be here!
I decided to add some color to the firewall while I'm doing my LS swap.
Before: During: After: It needs one more coat to make it look even all the way across but I ran out of the paint that I was using, I pick up some more on the way home. Should be able to get another coat on in the 24 hour recoat window.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-20-2017, 10:57 PM | #2593 |
Replaced the shocks...too soon?
01-20-2017, 11:31 PM | #2594 |
01-26-2017, 11:15 PM | #2595 |
Was finally able to push her out of the garage.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
02-04-2017, 10:32 PM | #2596 |
Built a pvc structure to keep my bed from becoming a bath tub
02-04-2017, 10:34 PM | #2597 |
Structure
02-04-2017, 10:35 PM | #2598 |
Bath tub
02-05-2017, 12:23 AM | #2599 |
Just finished a center mount hand brake lever on my A833
02-05-2017, 12:25 AM | #2600 |
Another look
