02-05-2017, 12:51 AM | #801 |
Re: 53 Surburban "Family Truckster"
I went to Moser to get my rear diff shortened on Friday. It was just under 3 hrs one way. I arrived just before 8 am. I tired to snap some pics but I was told that would not be allowed. There where (2) other people dropping stuff off for same day service.
Upon inspection the guy noticed that my axles were gnarled up where the axle bearings ride. This is a common problem for 10-12 bolt rear diffs. I had to have new axles made because they would just chew up my new bearings if I didn't. The bad news is it doubled my overall expenses. I was able to have them drill out the axles to except my lug studs that are matched to the front (7/16-20). This will save me from doing it. By 12:20 I was back on the road to MI... Tonight, I finished welded my brackets and I started getting the rearend cleaned up and reassembled. Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-05-2017, 01:13 AM | #802 |
Very nice...as usual
02-05-2017, 09:50 AM | #803 |
Too bad about the axles. Were you able to watch them narrow the rear? Seems they were pretty fast.
02-05-2017, 10:41 AM | #804 |
Marc, hate to hear about the added cost. But now you should be good to go for along time...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-05-2017, 11:26 AM | #805 |
Bummer about the axles but you don't want to do it halfway and suffer later. It's pretty cool to make one stop and get it all done in a day especially with a custom job!
The spring perches look good - are you boxing those in by chance? I had a set just like that on a '69 Camaro with a 525hp 408 and a Richmond 5 speed and they collapsed during a very sporty burnout - I guess the tires were stickier that day! The rear end rolled as the perches collapsed and the driveshaft twisted off after it gouged a hole in the floor. Bad day. Maybe overkill but every time I see a set of those it brings back expensive memories!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
02-05-2017, 07:49 PM | #806 | |||
Thank you
Marc
02-07-2017, 01:45 AM | #807 |
Sucks about the bummed axle but good thing you still got it all in one day.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
02-09-2017, 11:22 PM | #808 |
I have been spending time/money getting the various seals and bearing necessary to reassemble my rearend. It took 3 tries to purchase the correct axle bearings and bushings. For the Zr2 this is a common occurrence that other people have had. After some searching on Google, I was able to locate the correct part numbers.
I finished welding my brackets on the rearend. I then cleaned it up and painted it with frame paint for now so it wont rust. Tonight I pressed in my axle bearings and axle seals as well as a new pinon seal. This weekend I hope to get the rearend fully put back together. Here is a pick of my new axles with the new lug studs that I drive in the other night. No my front and rear lug studs are the same size and thread count. Marc
02-09-2017, 11:57 PM | #809 |
looks great. just went through a full rebuild on my daily not long ago, so this process is dejavu.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
02-09-2017, 11:59 PM | #810 | |
Marc
02-10-2017, 12:33 AM | #811 |
Marc, looks great, doing some great work also...Jim
02-10-2017, 01:17 AM | #812 |
Every axle I have had apart I learn something new. Looks good.
02-10-2017, 01:18 AM | #813 |
if you are not rebuilding the whole thing. Def don't mix up your shims. Putting the shims back in takes a few times to get a good grip on the best method to do it. Get a deadblow hammer cause you'll need to hammer the carrier back in, tapping the shims. you can prolly trust everything when its torqued to spec, but it would be good to check the backlash on the ring gear and check your gear teeth pattern with paint. Be a booger to have to redo something in there once your whole truck is done and you want to just drive!
02-10-2017, 10:24 AM | #814 | ||
Thanks Jim
Marc Quote:
Marc
02-11-2017, 07:34 AM | #815 |
Too bad for the extra costs Marc, but now you know it lasts a lifetime!
Back in the old times when I was still at work at big trucks (MB), I did a few axles. We had special tools to set the ring and pignion and set the bearings at the right tension, also colored the theeth of the ring to see if it made the right contact area on the pignon. Looks like today is all about swapping axles in those big companies. In short... I respect that you do your own axle, it isn't that easy!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
02-11-2017, 11:32 AM | #816 | |
Marc
02-11-2017, 09:57 PM | #817 |
Wicked thread, spent most of the day with a very sick toddler sleeping on me reading it. Tons of info.
I plan to mount my tank and compressors similar (or at least mock up that way) and was curious about rolling the fenders since it's common in the car world. Also was considering the same booster set up so you basically validated a bunch of my theories and I'll probably use a lot of the fuel info as well! |
02-12-2017, 12:09 AM | #818 | |
As soon as I get my rearend back in I can really move forward on finishing my inner wheel tubs. Looking forward to more progress forward. At times it seems like I move backward more... Marc
02-13-2017, 12:10 AM | #819 |
He's on the mend now which is good (actually seems like it never happened). With the ebay brake set up any worries about the booster being an offshore unit? I'm Canadian so it's hard to find competitively priced parts made here anyway but a few people said sometimes the quality is off.
02-13-2017, 10:00 AM | #820 | |
Marc
02-13-2017, 11:30 PM | #821 |
Sunday I had the whole day clear and I planned to reassemble my rearend. after I determining that threads on my pinon shaft were screwed up I was unable to start the pinon nut. With it being a Sunday I knew I was out of luck to find a 7/8"-14 die. I was able to pick up one today and get my threads fixed. I was able to get the rearend put back together tonight. I also bolted up the rotors and calipers to get a look and check clearances. I was fretting putting the center section back in but it went in without too much trouble.
I'm happy with how it turned out. Next I will throw it back under the Suburban and get cracking on finishing the tubs. Marc
02-13-2017, 11:48 PM | #822 |
Rear looking good marc..nice and clean
02-14-2017, 12:13 AM | #823 |
Looking good there Marc...Jim
02-14-2017, 12:21 AM | #824 |
Nice job - looks great! It'll be nice to see it back under the burb.
02-14-2017, 12:50 AM | #825 |
Where did THAT bolt go?
Nice and clean!
The Swiss Car Club......A drinking club with a car problem.... |
