Old 09-20-2007, 10:31 PM   #26
abebummy26
abebummy26's Avatar
Re: 73-87's Tire / Lift size chart (WILL IT FIT?)
I think this one is more accurate http://www.4wheelparts.com/tire_fitment.html
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 03-31-2008, 08:37 PM   #27
tommy4x4
tommy4x4's Avatar
i have an 85 blazer with 33/12.50 on 15x8 wagon wheels with 0 lift and only rubbed when wheel was turned all the way i adde rough country addaleafs and gained 2 inches of lift in the front and 2and 1/2 in the back no more rubbing will post pic as soon as i take one
tommy4x4 is offline   Reply With Quote
Old 04-02-2008, 08:06 PM   #28
jkade
jkade's Avatar
5" of lift and 37/12.50/16.5
jkade is offline   Reply With Quote
Old 04-25-2008, 04:12 AM   #29
Dooley
Dooley's Avatar
Originally Posted by bigarmzz View Post
thought i'd see if i could start this thread for the 73-87's, since there's already one for the 67-72's
could we make "this one" a sticky too?
lots of 73-87 owners wanting to know this same question
I have run BF Goodrich 33/12.50/15's on 8 inch wide rims for over 25 years on a 1977 K10 Suburban and a 1980 K10 pickup.
I ran 33/12.50/16.5, 10" wide rim on a 79 K20 Suburban too!
No lift and no problems!
I would like to try 34.8" 315/75-16's on my new to me 1986 CUCV pickup with no lift or sheetmetal trimming and 8-9" rim width. They are 2.5" wider than my current tires. Here's the truck with 33.3" 255/85/16 tires on stock wheels. Still some room left!
Dooley is offline   Reply With Quote
Old 06-22-2008, 08:48 PM   #30
74 C-30
Dually Pride
74 C-30's Avatar
i thought that CUCVs came stock with 36s and no lift...
74 C-30 is offline   Reply With Quote
Old 06-24-2008, 11:52 AM   #31
Dooley
Dooley's Avatar
Most came with 235/85-16E, a few had 245/75-16E depending on bodystyle equipment. The Blazers had 31/10.50-15's,(10.00-15) on15x8 wheels.
Old 10-19-2008, 09:50 PM   #32
primered_junk
ASE master tech/machinist
primered_junk's Avatar
12" suspension, 3" body. 44" gumbos they would rub with the wheels turned full lock when flexed.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 12-15-2008, 01:38 AM   #33
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
i have put about 4 inches of lift on my truck and have had about every size of tire from 33 to now 42. the 42 got into the firewall even though i moved the axle 1.5 foward so now i'm running 39.5. they fit perfect with all the fender trimming i've done .
bmeredith is offline   Reply With Quote
Old 02-11-2009, 10:51 AM   #34
thirdstreettito
Resident of Here
thirdstreettito's Avatar
84 K10 SWB Diesel
29x9.5xR15 Stock Suspension
I have no clue how it could EVER rub!
When these tires need replacements I'm getting
33X9.5R15
Load Range C
BFGoodrich All-Terrain T/A KO
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-13-2016, 01:05 AM   #35
Eug396
Eug396's Avatar
Here is mine with a Rough Country 4" lift and a 1" body lift from Off Road Design. Currently sitting on 35" Goodyears.
1980 K20 396/SM465/NP205/D44/14BFF
1978 K20 400/TH400/NP203/D44/14BFF
Eug396 is offline   Reply With Quote
Old 01-23-2017, 03:41 PM   #36
BERRY82GMC
Ive got an 82 Sierra classic with a 2.5 in lift (new front leaf springs and blocks in the back) it currently has 31s on the original wheels. i would love to try to stuff 35s under it but i dont think theyll fit. should i try to fit the 35s or play it safe with 33s?
BERRY82GMC is offline   Reply With Quote
Old 01-23-2017, 08:10 PM   #37
TwoFiftyShifter
35s would look horrible to me. 33x12.50 might not be bad. It looks great as is
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-15-2017, 09:02 PM   #38
cochino12
It followed me home?
cochino12's Avatar
I'm wanting to run 37x13.5x20 on a 20x12 wheel, 6" lift w/1 zero rate in front moving the front axle forward also. Any ideas if this will rub with just around town driving? This truck will be on the street 98% of the time so I'm not real worried about flexing it much. I'm thinking I might be a little wide not to rub
Oh and its a '90 K30 crew cab
thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is online now   Reply With Quote
Old 02-16-2017, 09:27 AM   #39
obijuan
Yes they will.
These are 37x12.50 on 10 inch wheels rubbed. 6 inch and a zero rate. I had to cut the front of the fender off and some of the rear for clearance.
Yours will likely rub alot.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 02-16-2017, 10:11 AM   #40
cochino12
cochino12's Avatar
I figured so, thanks for the info. I was hoping the taller frame of the 1 ton and the zero rate would be enough. I hate when tires rub, guess I'll go with a 325-60-20 .
thanks again
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-16-2017, 10:28 AM   #41
obijuan
The one ton frame is lower in the belly of the truck. Not the firewall forward. It is also heavier so it could sit lower than my blazer did.
Old 03-18-2017, 11:48 PM   #42
Low_Life86
Low_Life86's Avatar
81 gmc c25 no lift on 35s they rub on full lock but are dailyable
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
Old 05-22-2017, 03:26 PM   #43
jdrobin
Ok guys, I'm new to the forum as well as the whole lifted truck scene. My son and I are doing a complete frame off with a 1977 chevy short wide k10. We added a rough country 4" suspension lift. Yesterday I dropped the bed onto the frame to just get an idea of what I was going to look like. this is it. Those are 31X10.5 15s. Is it me or does that look WAY taller than it should? Granted the cab, motor, tranny aren't on the truck but still....the top of the bedrails are at 64" on 31" tires. I attached a pic. Let me know if you can see it or not.
https://photos.google.com/share/AF1Q...ZxcTRnLW5HZVdn
jdrobin is offline   Reply With Quote
Old 02-10-2020, 02:22 AM   #44
Magicalzoomer
4" Superlift/Spring work&2" block on rear/35"BFG ATs/9.75x16.5 steelies on`84,never rubbed:
Spring shop arched and added leaf in front to level/33"BFG ATs/10"finned on`90,caught behind the front tires a bit.Never wheeled it:
4"TuffCountry EZ-Rides all 4/35"MTRs/10x16"D"holes on`91,caught behind the front tires if I wasn`t careful:
Hey Special-K,
What is the lift/tire/wheels setup on your 85 Jimmy? It looks really good. Thanks.
Magicalzoomer is offline   Reply With Quote
