Old 02-21-2017, 01:48 PM   #226
Donnie Lee
Re: LS engine swap info
Originally Posted by mcbassin View Post
This depends on how you want to do the swap, i.e. how much do you want to spend? or what is your skill level with wiring?
You can buy a plug and play harness/pcm that all you have to do is connect like 4 wires or you can completely rework the stock harness and have the pcm reflashed.
It's not hard but it does take some time and a whole lot of patients.
Brendon at lt1swap.com can reprogram your pcm and he has some info about the harness : HERE
mcbassin, who sells the plug & play harness/pcm?; looking for engine for '50 model truck & am getting discouraged with info from numerous conversations regarding using LS engine/trans.
Donnie Lee is offline   Reply With Quote
Old 02-21-2017, 02:00 PM   #227
Hart_Rod
Hart_Rod's Avatar
Modern Vintage Systems, Painless, BP Automotive, Speartech...just to name a few.
Hart_Rod is offline   Reply With Quote
Old 02-22-2017, 10:04 AM   #228
Donnie Lee
Thanks Hart Rod, i spoke with two vendors yesterday from the above mentioned.
Old 02-22-2017, 10:36 AM   #229
68 Four on the Floor
68 Four on the Floor's Avatar
Have you cheked the ls swap classifieds on this forum?
68 Four on the Floor is offline   Reply With Quote
Old 02-22-2017, 11:56 AM   #230
A1971Blazer
A1971Blazer's Avatar
I found this guy in Florida and had him rework the factory harness that came with the LS1 that I got from a 2002 TransAm...he did a great job at a reasonable price...I think it was around $350.....
http://www.standaloneharness.com/ls-engine.html
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-24-2017, 01:58 PM   #231
doublebeetx
My 64 had a 6 cylinder in it. I have a set of V8 stands which mount in a forward location of the stock 6 cylinder stands. I bought adapter plates for my 4.8 to use standard motor mounts. Any ideas on which stands will be better to use ? Thanks for any advice.
doublebeetx is offline   Reply With Quote
Old 02-24-2017, 06:02 PM   #232
Donnie Lee
I've looked thru several pages of the classifieds & did not see a reprogrammed harness for '05 GTO engine & auto trans.
Old 03-06-2017, 09:05 PM   #233
Donnie Lee
Question on oil pans; we have '05 GTO LS2 with factory front sump oil pan & need to change to rear sump. After much searching it appears the LS1 pan #12628771 is what we need. When you change to this oil pan do you also change the oil pump pickup, windage tray, dipstick tube, dipstick, o-ring for oil pump pickup. I found the part #'s for all these items on LS1 Tech in the LSX Oil Pan thread. Of course we would change the pan gasket as well & all of the bolts if I can find them listed.
Thanks For Any Assistance
Old 03-06-2017, 11:09 PM   #234
ls1nova71
ls1nova71's Avatar
Yes, you'll need the pick up tube, windage tray and dipstick tube. When you have the GTO pan off, don't forget to knock out the little plug in the block where the dipstick goes, otherwise you'll be pulling the pan again!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-06-2017, 11:27 PM   #235
Donnie Lee
Thanks ls1nova; so we reuse the original dipstick?, & the plug removed for the new dipstick location, is that plug instsalled in the original dispstick location?
Old 03-07-2017, 12:00 AM   #236
ls1nova71
ls1nova71's Avatar
You need to match the dipstick and tube to what ever pan you are using, they're all different. The new dipstick will go in he block, that's where the plug is, the GTO the dipstick tube goes into the pan.
Old 03-07-2017, 01:01 PM   #237
tlorber
tlorber's Avatar
Here is a site i came across a while back that may provide some info.
http://www.improvedracing.com/LS-oil-pan-dimensions.php
tlorber is offline   Reply With Quote
Old 03-08-2017, 10:08 AM   #238
Donnie Lee
Thanks tlorber
The Fbody pan is what we need; at GM parts direct it appears the pan does not come with new bolts, don't see them for the windage tray either. Are these bolts re-usable, if not has anyone ordered these separately?
Old 03-08-2017, 11:17 AM   #239
aggie91
I'm just glad to be here!
aggie91's Avatar
The oil pan bolts and windage tray bolts are reusable.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-10-2017, 12:37 PM   #240
Donnie Lee
Thanks aggie91; I talked with the local Chevy parts guy & new bolts come with the pan & windage tray.
New question, do we use antiseize on the oil pan bolts?
Old 03-10-2017, 01:08 PM   #241
kehstr
kehstr's Avatar
You don't need to, but it couldn't hurt to put a little on them
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 03-10-2017, 04:48 PM   #242
aggie91
aggie91's Avatar
I don't unless its an aluminum block.
Karl
The LST Challenge:
Old 09-18-2017, 12:48 PM   #243
Scotts Elle
There are a few links that have since expired or are dead at the beginning of this thread. Also, many pictures are linked to "free" hosting accounts that require the hosting person to sign up for third party hosting. Can anyone please provide the vacuum check valve fitting for the brake booster? The fitting I have for the LS motor is larger than the barbed check valve on the existing booster.
Also, does the coil power feed provide 12v while cranking on a stock 67 engine harness? Wiring diagrams are not very clear. I have my LS installed and it cranks but will not fire. I have fuel pressure, VATS was disabled and base tune loaded. Data logging while cranking doesn't show much.
Scotts Elle is offline   Reply With Quote
Old 09-18-2017, 12:59 PM   #244
tlorber
tlorber's Avatar
Scotts,
I'm not clear on the question referencing a '67 harness. If using an LS motor, are you not using an LS harness/PCM? If so, are they the ones that originally came with that motor?
Coil packs should be getting voltage while cranking.
Also, if the motor was sitting for a long time, it would be worth checking and cleaning the injectors. I doubt they would cause a non-fire situation but clean injectors will definitely help it run better.
Old 09-18-2017, 01:11 PM   #245
Scotts Elle
Thanks for the help!
I have a LS harness but it needs a 12V switched from the truck. I tied the switched 12 volt into the old 67 engine harness using the old coil wire but not sure if its powered during cranking.
The motor/trans/PCM and harness was pulled from a 04 Avalanche. It was running when pulled a couple months ago. Followed LT1swap for harness modification and was able to test fire it before installing it.
Old 09-18-2017, 01:39 PM   #246
tlorber
tlorber's Avatar
As a permanent solution, it would probably be better to build a stand alone harness/fuse block for powering up the PCM-that way you are not relying on any potential issues with the existing '67 harness. Here is a link to the page on the lt1 site. Near the bottom of the page it shows the fuse block that gets key hot/battery hot power to run the PCM independently of anything else.
http://lt1swap.com/2000harness.htm
As a temporary measure, you can locate the pcm, fuel pump, and coil wires and connect them to a key hot or battery hot circuit. Then tap a direct, heavy wire from the battery to the starter to kick it over. You may also want to temporarily bypass the pcm controller for the fuel pump, and just feed a key hot line to the fuel pump. The pcm will only allow the fuel pump to run for a couple seconds without sensing the engine cranking over. Even if the engine is cranking, you are not certain that the PCM is sensing it if all sensors are not hooked up properly. I try to remove as many variables as possible until you can pinpoint the problem.
Old 09-19-2017, 09:31 AM   #247
aggie91
aggie91's Avatar
Definitely check and clean the injectors. I experienced the same no fire issue with an engine that had set for a good while. Had power every where I needed and the coils where firing when they should. Ended up pulling all 8 injectors and ALL of them where stuck. Cleaned them and made a harness to cycle each one with a drill battery to make sure they clicked open and closed before reinstalling them. Put them all back in and the truck fired up the first crank...To clean mine, I pulled them out, pulled the o-rings off and soaked them in a pan of berrymans carb cleaner over night. I had to tap most of them on a hard surface to get them to cycle while applying 12 volts. I also sprayed brake clean in each one with it held open with the battery and blew thru each one to get all the gunk cleaned out of them.
As for the 12v coil wire, it should have power while cranking. Make sure it is not a resistance wire or has a resistor inline. This wire needs to be a full 12v for the PCM. That is how I have my '65 wired, I just replaced the coil wire with a regular 16 ga wire from the plug on the firewall all the way to the PCM.
If you followed the lt1swap.com rework, then you should have already made the relay/fuse block that tlorber talks about.
Karl
The LST Challenge:
Old 09-19-2017, 09:58 AM   #248
Scotts Elle
Thanks all. I did end up checking the coil wire and it was hot during cranking. There was 2 issues (of course, 100% was me rushing and missed things). The crank position sensor was only lightly pushed into it connector. I had set it there a week or so back and thought, "I will pull the starter later to plug that in". Being hidden, I completely missed it.
The other issue was the Holley returnless in tank pump was wired in reverse. When I tested the fuel system before installing the motor, it worked great. All lines pressured up to 60psi, no leaks... When I installed the connector and wired the relay for its final install, I reversed the leads. I heard the fuel pump kick on so I thought it was fine when I was trouble shooting. I was going to pull the injectors and noticed that the fuels didn't release any pressure. That's what tipped me off.
Anyone know the brake booster check valve part number? The hose is larger on the intake that the original hose to the stock booster.
Old 09-19-2017, 10:59 AM   #249
aggie91
aggie91's Avatar
For the Check Valve, try Dorman 80190 or 80189. One of them comes with new grommets.
Karl
The LST Challenge:
Old 10-08-2017, 03:53 PM   #250
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's some good reading.
http://www.chevyhardcore.com/tech-st...kyard-ls-swap/
http://www.enginelabs.com/engine-tec...ags-to-riches/
http://www.superchevy.com/how-to/eng...to-ls-engines/
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
