Old 11-15-2016, 04:48 PM   #126
RRR18
RRR18's Avatar
Re: Daves new 68 chevy swb
Looking good. Bet you got lot of neighbor visits when the truck rolled out into view.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 11-15-2016, 10:00 PM   #127
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Originally Posted by Woodnears View Post
Sorry guys for the delay in updates I've been busy. On Friday I had a vacation day and meet up with the truck driver and picked up all my new sheet metal. Spent the rest of Friday hanging it and loosely fitting it all. I've got a good bit of the work done. Bed is on square and cab lined up perfectly. Doors were a pain. Elongated hinge holes on the door side to get the doors out far enough to line up with the fender. Had to raise he core support a bit to support the front clip and line up the fender to door gap. Question for y'all. Has anyone had to reshape the fenders to match the doors? Here's a few pics? Seems like I could cut the inner brace and push this area in to match and reweld the inner brace. Am I thinking this wrong?
Have done that more than once, your spot on. Well that is what has worked for
Me In the past anyway
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 11-15-2016, 11:54 PM   #128
Woodnears
Not only the neighbors, I once had an ambulance stop by on their way back from a call.
It seems like a good idea. I want to get all the hardware in the door and get it for sure where I want it before I cut the fender.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 11-18-2016, 07:09 PM   #129
Woodnears
Still working on body lines. Making great progress. Here's what it looks like after a little slicing and dicing and bfh persuading.
Old 11-21-2016, 11:52 PM   #130
Woodnears
Took a side step and am focusing on the bed floor for a bit. Designing it in sketchup to work out any bugs.
Old 03-01-2017, 12:32 AM   #131
Woodnears
Its time to get this thread back beating again. I hung all new sheet metal and aligned the panels for the most part. still have a bit of fitting left but for the most part they are fitted. Has anyone sent a rear diff to Moser for rebuild? Coming up next will be front and rear inner fenders, bed wood and the interior. i need some suggestions for vendors for the interior/ buddy buckets, door panels inner door mechanicals. I also am taking suggestions on bedwood. I really like the look of a clear or light maple.
Old 03-01-2017, 01:14 PM   #132
mcbassin
Still Learning
mcbassin's Avatar
Your body looks way better after you adjusted with the bfh.
I can't help you with the wood bed since I used all steel on mine.
hang in there, someone will help you out.
Old 03-01-2017, 08:25 PM   #133
boynton
boynton's Avatar
I would use truckseats (member on the board) for your buddy buckets/door panels. I had him build mine and they turned out great. My door panels match my seats. As far as the wood be careful what you finish it with. I used poly urethane that a paint Store recommended and it ended up sealing the wood too well causing it to crack and split. I ran across another company at good guys that specializes in bed wood and they sell a great product according to them and they say it won't do the same thing. I will look them up when I get home.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 03-01-2017, 09:53 PM   #134
72 tigger
72 tigger's Avatar
I live about 15 miles from Moser engineering- I've never heard anything bad about them.
72 tigger is offline   Reply With Quote
Old 03-02-2017, 07:56 PM   #135
Woodnears
I am trying to get some prices together. Does anyone know what a rebuild on a rearend goes for these days? I was gonna just send it to Moser and have them go through it new axles bearings the works.
Old 03-02-2017, 08:35 PM   #136
69short
69short's Avatar
I had my rear end rebuilt for $150 labor. I applied all the parts. Posi and all timken bearings
69short is offline   Reply With Quote
Old 03-02-2017, 08:56 PM   #137
Woodnears
who makes a buddy bucket center seat foam?
Old 03-02-2017, 08:57 PM   #138
Hart_Rod
Hart_Rod's Avatar
Most good upholsterers can build you the center seat foam.
Hart_Rod is offline   Reply With Quote
Old 03-02-2017, 08:59 PM   #139
Woodnears
The problem is there are no "good" upholstery shops here. I live in the sticks!
Old 03-02-2017, 09:01 PM   #140
Hart_Rod
Hart_Rod's Avatar
, I hear you! You can probably make it yourself, it's pretty straigaht forward. 2" thick and a rectangle, .
Old 03-02-2017, 11:41 PM   #141
Woodnears
Let's talk 2.5" exhaust for a bit. I'm looking at mufflers and wow there's plenty of choices. Im running stock Camaro manifolds. Can I use a 90 after the manifold or should I use two 45's back to the pipes. Any suggestions on mufflers are appreciated. I'm looking for a nice drive able tone that's not too annoying.
Old 03-03-2017, 08:36 AM   #142
SCOTI
SCOTI's Avatar
Exhaust is dictated by space. You'll need the manifolds bolted up & get a visual of what works best. On my 64 (68 chassis) I have 45's on the drivers side & a 90/45 on the pass. This combo worked best to clear the oil filter/starter/chassis parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2017, 09:17 AM   #143
Hart_Rod
Hart_Rod's Avatar
You should be able to run 90's using those manifolds, well at least they worked for me on my 68 with PB setup. I personally like the Magnaflows for LS motors, seems like less drone than the FLowmasters. If you plan on going over your axles to the rear of the truck, you'll probably have to do some creative things to make that happen.....
Old 03-03-2017, 10:22 AM   #144
knomadd
knomadd's Avatar
I'm having a local hot rod shop go through mine when I get to that point. They are buying all the parts to add posi and change gears, pinion yoke and ordering my driveshaft. Their labor rate is flat for everything at $85 an hour. Kinda high, but I know they do good quality work. So for me, it's about the convenience of it being a few miles from my house, instead of towing it 50+ miles to another shop that was recommended to me. If I remember correctly, they quoted me about $2,200. Again, I think it's a bit high, but I've seen some $200 "rebuilds" that reuse the existing internals and just clean it up and put new bearings and seals in them. I've also seen some $4,000 builds that go as far as replacing the axles and everything inside. I'm sort of giving the extra $$ for convenience and piece of mind, knowing the quality they do instead of relying on someones recommendation.
It's best to look around and see what kind of reputation a shop has, then ask them for an estimate for the work. But budget a little higher, just in case.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-05-2017, 08:24 AM   #145
hewittca
hewittca's Avatar
Awesome work! I'm in for updates.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-06-2017, 06:24 PM   #146
Woodnears
Guys, either my pm's aren't coming through or the few vendors I've contracted are ignoring me. Anyone ever had this issue? Anyways I've sent a few pan's requesting prices in carpet, weather stripping, and seat foam. Not sure what's going on. Anyone have ideas where I can order these items online. Naturally I want the good stuff. Thanks for your input.
Old 06-06-2017, 06:42 PM   #147
RRR18
RRR18's Avatar
Never any problems for me with pm anyone on here.
'67 BAD IDEA
Ryan
Old 06-06-2017, 06:58 PM   #148
69short
69short's Avatar
Send me a pm and I'll let you know if I get it. It is hit or miss with the vendors from my experience. Message kyle at laidback recreations. He can get pretty much everything you need interior wise. Tell him I sent you
Old 06-06-2017, 07:26 PM   #149
Woodnears
Hrs one of them I can't get a response from. Pm sent
Old 06-06-2017, 07:53 PM   #150
Woodnears
Anyways here's a few update pics while we wait.
