Old 03-03-2017, 08:52 PM   #176
nebdrummer
nebdrummer's Avatar
Re: '53 duramax
lol that's great. I have a 3 bar map on mine, but I won't ever get there.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 03-06-2017, 09:20 PM   #177
lower50's
lower50's's Avatar
Re: '53 duramax
How much boost are you planing to run?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-06-2017, 09:26 PM   #178
Firstgenfan
Re: '53 duramax
1 psi less than it takes to lift the heads! Probably no more than 35psi.
Firstgenfan is offline   Reply With Quote
Old 03-07-2017, 06:51 PM   #179
lower50's
lower50's's Avatar
Re: '53 duramax
The problem is finding the highest psi before that point. You could just put head gaskets and studs in.
1951 MG TD
Old 03-07-2017, 06:52 PM   #180
Firstgenfan
Re: '53 duramax
Already done 😉
