03-07-2017, 09:29 PM | #1 |
Big Block Downpipes
Where can I find downpipes for my 69 396?
I'm using the stock exhaust manifolds.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 03-08-2017 at 02:19 PM. |
03-07-2017, 10:21 PM | #2 | ||
"I ain't nobody, dork."
Re: Big Block Downpipes
Any exhaust shop can make them.
Gary
03-07-2017, 11:34 PM | #3 |
Actually, he/she/it said Downpipes, so only a Downpipe shop can provide such a mythical beast...
03-07-2017, 11:38 PM | #4 |
I searched all over the internet for some and never found any, post up if you find some.
03-07-2017, 11:41 PM | #5 | ||
Am I thinking of something different then just a pipe with a 2 or 3 bolt flange that bolts to the manifold and then is bent to mate up with the rest of the exhaust?
Gary
03-07-2017, 11:45 PM | #6 | |
I hate going to exhaust shops, just bad experiences there and would rather buy the correctly bent piece. And if I order the right part I don't have to drive or trailer the truck to the exhaust shop with open exhaust. |
03-07-2017, 11:55 PM | #7 |
I'm well aware that any muffler shop can make some pipes with crushed bends, but I'm hoping I can find some nice madrel bent factory made pipes.
Pypes, Flowmaster and other companies have them for 60's & 70's Chevy big block cars, but I haven't found them for our trucks. I've got an email out to Pypes Performance Exhaust. I'll share what they tell me.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 03-08-2017 at 12:13 AM. |
03-07-2017, 11:56 PM | #8 |
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
03-08-2017, 12:33 AM | #9 | |
#JERK
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
03-08-2017, 12:43 AM | #10 |
Try these guys, I know, I know, its a muffler shop. Yet they make all the stuff so you can make your own!
03-08-2017, 01:02 AM | #11 |
Did you forget to include a link or a name?
03-08-2017, 09:30 AM | #12 | |
here is a diagram with part numbers from napa, they should easily cross to walker. if you need it bigger PM me with your e-mail and I'll forward it.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
03-08-2017, 12:26 PM | #13 | |
There fixed it! |
03-08-2017, 01:33 PM | #14 |
On Jegs you can buy weld up header kits that are mandrel bent, not sure your looking to do that tho. just a thought
03-08-2017, 01:37 PM | #15 | |
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 03-08-2017 at 02:16 PM. |
03-08-2017, 01:42 PM | #16 | |
03-08-2017, 01:58 PM | #17 | |
Pypes responded to my email and said that the don't offer a downpipe for our trucks. PYPES DGU20S Downpipes 1970-81 Camaro 1964-77 Chevelle & El Camino Big-Block Chevy http://www.jegs.com/i/PYPES/958/DGU20S/10002/-1
03-08-2017, 02:04 PM | #18 | |
03-08-2017, 07:36 PM | #19 | ||||
Gary
03-08-2017, 09:17 PM | #20 | |
03-08-2017, 11:06 PM | #21 |
That is great to hear. Did you modify the pipe or use a shorter filter? Do you have any photos?
03-10-2017, 11:43 AM | #22 |
I used a shorter filter. I also cut both tails off.
01-16-2024, 09:09 AM | #23 |
Reviving an old thread with a similar question, Looking for downpipes for a '68 396 factory manifolds...???
I'm simply looking for a economical ($300-$500 range) functional exhaust, does not need to be full factory. I 'thought' I'd find a system, use what I need and go from there, but this is proving a bit more of a challenge. Short of trying to find a shop to make something (as in $$$) I'm probably going to piece it together myself. I'm fine with this, but I've not yet been able to find downpipes (396 w/manifolds). Does anyone know of any source? Thanks, Kevin Adding, I am aware that it appears the original poster may have opted for the Pypes downpipes, but I'm not sure I'm keen on going with a shorter filter. I am also aware companies like Waldron's make a full system, but I'd rather not end up spending close to $800 for a system. A photo of the truck, where exhaust currently exits front of rear tires under utility bed (where I am planning to keep it):
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
01-16-2024, 10:35 AM | #24 |
When I did my truck, the only people that I found that supplied dual exhaust down pipes for our big block trucks was Waldron Exhaust in Michigan. They made me 2 1/2" exhaust pipes for mine, that I cut off behind the cab, and adapted to a 2 1/4" muffler system that I bought from LMC I think. Waldrons is usually backed up, and it takes awhile for them to make a run of any certain pipe, so I had to wait awhile for them.
1968 SWB Step Side, Big Block, 4L80E , Running! |
01-18-2024, 10:43 AM | #25 |
Took my bbc to exhaust shop, $350 dual exhaust with tail pipes, custom bent. I supplied thrush mufflers..
