Old 04-01-2017, 12:17 AM   #1
dmjlambert
dmjlambert's Avatar
TH400 transmission cooler line connectors
On my 1969 CST/10 with SBC 350 and TH400, I had an external cooler added in front of the radiator when the transmission shop rebuilt my transmission. The steel lines attached at the transmission are pictured.
I would like to disconnect these lines at the transmission, and disconnect the transmission to move it out of the way to replace the flex plate on the engine.
I was thinking about putting caps on the lines and caps on the transmission so I keep things neat and clean and won't lose transmission fluid out of the cooler or transmission while I have it disconnected, and will keep dirt out. I would like to get ready for this job and order what I need from Amazon or Summit or someplace like that, but don't know what to order. What do you guys think?
Old 04-01-2017, 12:32 AM   #2
Gmc.guy
Gmc.guy's Avatar
Re: TH400 transmission cooler line connectors
When I pull a trans and plan to pressure wash or it will sit for more than a day I loop a quick 6 inch chuck of 3/8 fuel hose over the both to keep them from dripping and getting junk in the lines. I don't remember getting much from the fittings on the trans
-Cody
Gmc.guy is offline   Reply With Quote
Old 04-01-2017, 02:03 AM   #3
GR8-68
GR8-68's Avatar
You can get a couple of these at lowes or home depot for the lines and transmission
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-02-2017, 10:25 PM   #4
dmjlambert
dmjlambert's Avatar
Thanks for your replies.
connectors, cooler, th400, transmission
