01-05-2017, 10:59 AM | #151 |
Re: 4x4 1971 K20 build
Things have been going slow lately but they are starting to pick up again. My 78-79 dana 60 is on its way. I'm looking into a transfer case. The wiring has been started. Steering column and gear box will be sent off to be restored.
1971 C20 Daily, Built 350/700R4 1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s K20 Build |
02-23-2017, 08:51 PM | #152 |
As my truck is patiently waiting for wires I have been thinking about my motor mount setup. As it would be a nice easy setup for a stock engine, mine won't be. I have decided to redo the whole crossmember as I plan to be putting lots of ponies to the ground later on in life. My Dana 60 will be rebuilt when the truck is on the road and I collect money, but for now it will wait. My steering parts are back and look wonderful. He is about ready to start the wiring. In the meantime my 71 dd had a hg blow so we hooked it up with some arp head bolts and it's rockin again. Stay tuned as hopefully the progress will pick up again.
02-25-2017, 11:22 PM | #154 |
03-25-2017, 09:09 PM | #156 |
Picked up a straight bedside with a small line of rust in the wheel well, and a real nice gate. Brakes are mostly plumbed, engine crossmember should be finished this weekend or damn near done. Then I need gate hardware and an NP261XHD or NP261HD for a transfer case.
03-26-2017, 12:23 PM | #157 |
That is a nice tailgate. Good find.
Posted via Mobile Device |
03-27-2017, 01:42 AM | #158 |
It needs a little attention on the bottom but it is really nice. Only small dings on the inside. The guy had about 30 67-72 trucks.
04-05-2017, 04:39 PM | #160 |
6>8 Plugless........
Nice gate and bed side. The cross member is looking nice too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-05-2017, 10:16 PM | #161 | |
Here's the crossmember. As of now it weighs 42 lbs. 1/4" and fully boxed. This shall keep my dirtymax calm no matter what.
04-06-2017, 03:48 PM | #162 |
Lol. That should do the trick.
04-10-2017, 08:18 AM | #165 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-10-2017, 08:22 AM | #166 |
They are getting shipped out today. Got a great deal. They need cleaned up.
04-10-2017, 08:44 AM | #167 |
Nice, they look pretty good.
07-03-2017, 09:34 PM | #169 |
I was really hoping for it to be done by now but it will all be worth it. Got a heavy duty crossmember put in. Made all of 1/4" thick steel. I also bought a 14 bolt 11.5" rear out of an 8.1 and it is now installed, just needs painted. Now I'll have a huge u-joint with disc brakes. If anyone needs rebuilt 71 k20 axles I got em! All of the intercooler plumbing is on its way. The rear drive shaft should be finished soon as well. I also bought a fun daily since I have a 60 mile round trip for work each day.
07-12-2018, 03:32 PM | #170 |
Well the duramax finally runs now after new injectors. It now has an 8" lift as well. I bought a new trans cooler and i now need to order crossover steering.
07-14-2018, 12:13 AM | #171 |
That is one bad to the bone project man. A 1971 with a D-max and an LS1 daily driver.....
07-16-2018, 05:08 PM | #172 |
Thanks! The LS is amazing, fun and reliable. It also averages around 21MPG.
07-19-2018, 07:14 PM | #173 |
Awesome on all accounts! Too bad you had to replace the injectors but at least it is running and you know they are new now.
03-03-2022, 04:06 PM | #174 |
I know its an old thread but hopefully you'll still get notifications. What radiator did you use? Motor mounts?intercooler?
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
03-04-2022, 08:13 PM | #175 | |
Tags |
4x4 build, 6 inch lift, duramax conversion, duramax swap, k20 |
