Old 05-11-2017, 10:17 AM   #751
zach_carver
zach_carver's Avatar
Re: How about some pics of Static Dropped C-10's
Heres my 65 C10 5/7" drop 20x8 and 20x9.5. P245/40r20 front and P285/35R20 rear BFGs. Also has 1" rear wheel spacers to make rear farther away from the bed.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-11-2017, 10:53 AM   #752
knomadd
knomadd's Avatar
^^^ I like it! ^^^
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-11-2017, 11:09 AM   #753
jeh
jeh's Avatar
Hey Zach, I was parked right behind you guys at the All Truck Nationals a couple weekends ago in pigeon forge. Your truck looks awesome, it was one of my favorites there
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 05-11-2017, 11:50 AM   #754
zach_carver
Thanks a lot guys. I love the truck a lot!
Old 05-15-2017, 11:39 AM   #755
66clow
66clow's Avatar
Those running 20's with a 5 7 do you have a c notch in the rear?
66clow is offline   Reply With Quote
Old 05-16-2017, 07:50 AM   #756
zach_carver
Yes my truck has a small notch in the rear. Bed floor and all is original though.
Old 05-16-2017, 08:07 AM   #757
mongocanfly
mongocanfly's Avatar
Looking good zach..
Old 05-16-2017, 10:03 AM   #758
Custom.Chevy
Custom.Chevy's Avatar
I started doing a notch on my truck and wanted to make it easier so i took the bed off. One thing led to another and now im like 1500$ into a coil over 4 link with watts link all inboard the frame.
instagram - @custom.chevy
Custom.Chevy is offline   Reply With Quote
Old 05-16-2017, 10:56 AM   #759
BossHogg69
motor exploder
BossHogg69's Avatar
I'm running 19's, 5/7 drop with c-notch and stock bed floor/location.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-16-2017, 11:10 AM   #760
Mator
Mator's Avatar
66clow I know we talked before but 5 inch springs and 2 inch blocks in the rear with 3 inch springs in the front. No C notch and no problems.
First pict just with 5inch springs 2nd after adding 2 inch clocks.
Mator is offline   Reply With Quote
Old 05-16-2017, 12:10 PM   #761
Custom.Chevy
Maybe its the angle of the photo but for some reason the truck pictured doesn't look low enough to have a 5/7 drop? Doesn't a 5/7 drop typically tuck the top of a 27-28 inch tall tire into the fender? What size tires are you running? Total diameter.
Old 05-16-2017, 12:13 PM   #762
Mator
Mator's Avatar
I thought it would have been lower too, only 3-7 drop. The 20's seem to keep it up more than I anticipated. Rocket Racing Booster 6 20x9 +0 wheels Toyo Proxes S/T 275/45 tires with Autospring Lowered 3F / 7R
Old 05-16-2017, 12:14 PM   #763
Custom.Chevy
The reason i say this is because i just did a 5 inch drop on the rear of a truck yesterday evening and it was tucking the top of a 30" tire, so my tire is probably taller but i also only did a 5 inch drop not a 7. Im probably tucking 2-3 inches of tire so a 7" drop would easily tuck a 27-28" tire.
Your truck look killer though. Love it. That color is awesome.
Old 05-16-2017, 12:17 PM   #764
Mator
Mator's Avatar
Thanks, I would like it lower but I am about maxed out on funds. Still thinking of drop spindles after I get new mid length headers. I am afraid my long tube will hit if not careful.
Old 05-16-2017, 12:28 PM   #765
zach_carver
Originally Posted by mongocanfly View Post
Looking good zach..
Thanks man! I love it
Old 05-16-2017, 12:33 PM   #766
66clow
66clow's Avatar
I was wondering too since I'm at 5 in the rear and it is sitting pretty low with springs. Not sure if there is a difference due to the bed. Haven't looked lately at the axle spacing underneath.
Old 05-16-2017, 12:35 PM   #767
Custom.Chevy
I hear you. I finally got my truck to the height i wanted to keep it at just to find out exactly what you said. My long tubes are dragging on everything. Im having to use 2x4 to get in and out of my drive way. Sheared 4/6 collector bolts pulling out of a gas station. My next step for my blue/silver truck is mid length headers and exhaust that is closely tucked to the body,, im hopefully going to run the exhaust through the frame as close to the front of the truck as possible then run it outside the frame and dump it down at an angle towards the outside. Just ideas right now.
Old 05-16-2017, 12:38 PM   #768
Mator
Mator's Avatar
Now you guys have me second guessing myself. I ordered new springs when I did this but never checked the measurement.
Old 05-16-2017, 12:41 PM   #769
66clow
66clow's Avatar
Lol, you have any photos from underneath of how much room you have above the axle? I'm going to check mine this evening.
Old 05-16-2017, 01:27 PM   #770
Mator
Mator's Avatar
I will get some tonight.
Old 05-16-2017, 02:21 PM   #771
BossHogg69
motor exploder
BossHogg69's Avatar
Just for comparison, my rear tires are 27" tall as they sit on the truck (actual measurement), my rear fender lip is 27.75" from the pavement. I'm running a 6" Hotchkis drop spring and an 1.5" block in the pic here.
Adam
Old 05-16-2017, 03:26 PM   #772
Mator
Mator's Avatar
Pulled up some picts from the build. first before tear down. 2nd after 3 -5 drop and last sitting in the driveway with the 2 inch blocks added..
Old 05-16-2017, 04:59 PM   #773
66clow
66clow's Avatar
Awesome before after photos. Looks like I have about 4 inches between the axle and frame with 5 inch springs only. So not sure if that is enough clearance with 2 inch blocks or not. Also I have 20's with 40 series tires. Your fender gap looks about the same. You might not have 5 in springs.
Old 05-16-2017, 09:43 PM   #774
RodsGreen10
RodsGreen10's Avatar
Haha my little boy loved your truck at the show man.
Follow me on Instagram @rodsgreen10
Hit my YouTube page up http://www.youtube.com/c/RodsGreen10
RodsGreen10 is offline   Reply With Quote
Old 05-17-2017, 07:27 AM   #775
zach_carver
RodsGreen thats awesome!!! Thats what its all about! Its definitely had its fair share a kid pictures thats for sure.
