05-21-2017, 09:41 PM | #1 |
Need pinion & yoke for Chevy 12 bolt
Anyone have a 12 bolt for parts? Missing some things on this one..
05-22-2017, 07:48 AM | #2 |
Re: Need pinion & yoke for Chevy 12 bolt
I have some stuff. Do you have a list of what you need?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-22-2017, 09:39 PM | #3 |
Forgot to post pics, here's what I've got
05-23-2017, 12:53 AM | #4 |
60-66 Nut
You can not just put a pinion gear in there. The pinion gear and ring gear must be used as a matched set. You will have to buy a set of ring and pinion gears. And of course the yoke, bearings and seals.
05-23-2017, 07:16 AM | #5 |
I would pull it out and clean it good. The look at what condition the carrier and axles are in. Then you can make a list of what you will need. You may as well put all new bearings in it and if you are planning a gear swap now is the time to do it.
Jimmy
05-23-2017, 03:51 PM | #6 |
Moderator
http://www.quickperformance.com/GM-1...t_p_20451.html
After thinking about this you have much more to do than just replace the bearing and yoke. You have to set shims and stuff. Oh boy.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-23-2017 at 03:56 PM. |
05-23-2017, 07:42 PM | #7 |
