Old 05-22-2017, 01:36 PM   #1
04ls1gto
Insulating Suburban
Whats everyone done to insulate there suburbans from sound and heat. I have entire interior our and might as well do something prior to reinstalling
04ls1gto is offline   Reply With Quote
Old 05-22-2017, 09:40 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Insulating Suburban
Right, wrong, or indifferent, I sprayed the inside of my Panel Truck with 3M "Body Shutz" undercoating then used 2" pink foam board on the sides and 1" white foam board on the roof interior. I couldn't believe how much it quieted that tin can down....
LockDoc
Leon
Old 05-23-2017, 03:24 PM   #3
Hart_Rod
Hart_Rod's Avatar
I used FatMat.
Hart_Rod is offline   Reply With Quote
Old 05-23-2017, 09:13 PM   #4
04ls1gto
Originally Posted by Hart_Rod View Post
I used FatMat.
Did you feel like it made a difference? And how many square ft did you use to do entire truck?
Old 05-24-2017, 07:49 AM   #5
Hart_Rod
Hart_Rod's Avatar
Yes, I feel it does. I used 4 or 5 rolls, (50 sqft/roll), but I doubled it on the floor and firewall.
Old 05-24-2017, 09:31 PM   #6
HO455
HO455's Avatar
I used 2- 50 sq ft rolls of B-quiet mat on the steel floor and firewall. Then some foil backed bubble wrap on the roof. On the floor in back I have a 3/8" felt carpet pad under the carpet. I may still add some more insulation on the sides one I get some miles on it. I know it helped even with the few miles I have on it. Plus during the installation I discovered a spot on the roof that drummed like thunder with just a light tap of the finger. Replacing the window felts also made a huge improvement. If you want more info my WMB thread has some starting about page five.
RIP Bob Parks.
Old 05-25-2017, 09:15 AM   #7
Hart_Rod
Hart_Rod's Avatar
Good stuff! FYI, PRP finally has the 3rd door quarter glass window rubber corrected, .
Old 05-25-2017, 09:49 AM   #8
HO455
HO455's Avatar
Did you get the first set? That is good to know I know someone local who is looking for one. Thanks to Richard2717 for giving me a good used one I was able to get my glass installed last year.
RIP Bob Parks.
Old 05-25-2017, 09:58 AM   #9
blazer2007
LockDoc
how did you attach the foam board to the sides
blazer2007 is offline   Reply With Quote
Old 05-25-2017, 10:21 AM   #10
Hart_Rod
Hart_Rod's Avatar
I got multiple "first sets" . But I think PRP has addressed all the issues and they should work quite well now.
Old 05-25-2017, 03:49 PM   #11
HO455
HO455's Avatar
If they followed through with your input and your high standards of quality they will be perfect.
RIP Bob Parks.
Old 05-25-2017, 08:41 PM   #12
LockDoc
LockDoc's Avatar
If you are going to use side panels you don't need to attach it. The panels will hold it in just fine.
LockDoc
Leon
Old 05-26-2017, 07:21 AM   #13
olblue60@aol.com
member
Contact Rick at "Raam Audio". I usually mind my own business and don't usually do referrals, but.... This owner, " Rick ", is probably one of not only the friendliest but very knowledgeable people about the products he sells . Call all the others that you want first , Then call Rick ! His prices are great too!
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 05-26-2017, 11:51 AM   #14
HO455
HO455's Avatar
I think I need to apologize for Hart_Rod and I hijacking this thread. I hope no one has been offended.
RIP Bob Parks.
Old 07-05-2017, 11:55 PM   #15
Gobuffalo
Gobuffalo's Avatar
I used Lizard Skin.
One coat of sound insulation and one of heat insulation.
I went from the top of the firewall to the wood floor and the entire roof.
Took 2 gallons of each.
Gobuffalo is offline   Reply With Quote
Old 07-05-2017, 11:57 PM   #16
Gobuffalo
Gobuffalo's Avatar
Here's the floor.
Old 07-07-2017, 10:43 AM   #17
AnotherWs6
AnotherWs6's Avatar
Lizard Skin ^^^^^ How did this work out? Noticeable?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 07-08-2017, 01:33 PM   #18
Gobuffalo
Gobuffalo's Avatar
I don't know yet. I'm going to start it for the first time today.
Old 07-09-2017, 11:39 PM   #19
HO455
HO455's Avatar
Still waiting for those updates.
RIP Bob Parks.
Old 07-10-2017, 02:16 PM   #20
Awjunkies
Got my burb painted, put the new wood bed I made in Saturday and on this insulation step now. Putting a dynamat/fatmat type insulation on the steel floor.
Lizard skin is good for roof and sides/doors but expensive, they sell one for heat and noise reduction.
One of the biggest perks of working in the high end restoration business for 10+ years I learned a lot from the actual vendors where they developed their products. For my 74 mini clubman race car I made before the burb I used a latex paint/insuladd combo since all I had in the interior was seats and a rollbar and it helped a ton.
Lizard skin and all the other companies sell you a premixed formula. Look at insuladd.com and see the benefits. Be wary of amazon and eBay they sell a replica version and it doesn't work as well.
Bought the insuladd heat and a gallon of generic paint for a 1/4 the price. Made it extra thick and coated the inside roof, sides, and doors yesterday. Putting in some foil backed styrofoam on the roof and frp panels/trim lock I got from Home Depot.
Awjunkies is offline   Reply With Quote
Old 07-10-2017, 09:50 PM   #21
HO455
HO455's Avatar
Thanks for the Insuladd tip. Did you use Azek for the new floor? Your Burban is looking good. Great color choice!
RIP Bob Parks.
Old 07-10-2017, 10:32 PM   #22
Awjunkies
Used regular pressure treated plywood, 2 coats of primer and 2 coats of paint. None of my local hardware stores carried a single sheet big enough so I bought two and joined together. Wood is joined together with a half lap splice, just used the old one as a template and drilled all the same holes. Went in a lot easier then it was to take it out.
Old 07-11-2017, 10:31 AM   #23
WannaBe68
WannaBe68's Avatar
Sorry if I missed it, but who is PRP? I bought a complete set of the new 3 door suburban door seals from GMC-P and the fit is great! But the 3rd door 1/4 glass seal......not so much. Would love to find a set that fit.
Thanks!
WannaBe68 is offline   Reply With Quote
Old 07-11-2017, 11:15 AM   #24
Awjunkies
I'm about to install the doors as well from gmcpaul. Also have the rear cargo door and window and the super expensive long rear glass gaskets hopefully they all go in smooth.
Old 07-11-2017, 09:18 PM   #25
HO455
HO455's Avatar
Thanks!
Once again I hijack this thread. PRP is Precision Rubber Products. They have redone their window seal for the third door fixed windows. HartRod worked with them on the new version and if he is happy then the seal is correct. It sounds like you have the old version. HartRod has pictures of the new ones near the end of his Superburban build thread.
RIP Bob Parks.
