BMW & ASE Master Certified
Re: LT1 GenV swap
Alternator brackets finally done
![]() Happens that a old BMW belt is exactly the right length for this setup w/o the idler.. be good enough to test it out. A/C... the factory sucrion hose line is a no go unless the frame is notched... a lot. The discharge side can work.. the sensor is kinda close to the frame.. maybe re work the line a little. Already drew up the suction adapter and waiting on the quotes to come in. I'll take a picture of that next time I install the compressor.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
