07-02-2017, 09:52 PM | #1 |
Clear over polished grille
Subject been discussed here before using auto clear coats etc with conflicting results.
I'm looking to clear over my polished grille since it always needs polishing. I tried wax over it but doesn't help much I researched a bit and found a commercial coat especially made for various metals including aluminum. Used on exterior building and storefront doors etc. anybody try it? If not I'm game and will post my results. https://www.everbritecoatings.com/ca...-only-c-7.html
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
07-03-2017, 10:10 AM | #2 |
BlahBlahBlah
Re: Clear over polished grille
Wonder if having it clear powder coated would work?
07-03-2017, 11:25 AM | #3 |
70+ ( Old Skool Club )
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-03-2017, 11:32 AM | #4 |
Proprietor of Dale's Corner
Subbed for future info
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
07-03-2017, 12:35 PM | #5 |
I have used the everbrite on polished rims and various polished parts. Works as described,just make sure you clean the metal with wax and grease remover prior to applying. I have used a spray gun as well as foam brushes to apply and you cannot tell one from the other once dry.
07-03-2017, 12:45 PM | #6 |
How long is the coating expected to last?
"You can take the man out of PA, but you can't take PA out of the man" |
07-03-2017, 01:19 PM | #7 |
They also sell it in rattle can.
Not sure how long it lasts. I think a long time being a coating used on high traffic areas such as commercial doors. . Check out the website. I'll try it and post my results Posted via Mobile Device |
07-05-2017, 11:10 PM | #8 |
I tried the perma clear today. Tired of constantly polishing the inprotected aluminum, constant battle.
First was to polish with Mothers mag and aluminum polish and microfiber buff by hands . Absolutely amazing stuff by the way. Then directions for permaclear say to wipe metal with baking soda and water to mutrelize any acid from the polish Then wipe down with denature alcohol or xylene Use denatured alcohol! Xylene is nasty stuff. Very high VOC I bought 4oz bottle and applied with foam brush. Laid down like a spray finish. Pretty thin stuff. Anyway. Looks great and I'll post in a month to see how sits holding up. I think we have something here though See pics. Mark.
07-05-2017, 11:31 PM | #9 |
20' Daredevil (Ret)
Subscribed
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-06-2017, 01:25 AM | #10 |
Subscribed!
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
07-06-2017, 02:15 AM | #11 |
Subscribed
07-06-2017, 09:08 AM | #12 |
I read their info and no mention of UV resistance? They also state easy to strip and redo, how is that accomplished? Did you choose the brush because you applied it already mounted to truck vs the spray?
It looks like the original anodizing with a thin satin finish,is that right? Thanks for the info. |
07-06-2017, 09:47 AM | #13 | |
The permaclear gave the finish a bit more gloss finish. I have to check it this morning now that it's dry. Not sure on the UV protection. I would email them for more info. All I know was for $20 on amazon it was worth a shot. https://www.everbritecoatings.com/ca...ar-ezp-97.html
07-06-2017, 08:39 PM | #14 |
Subscribed
07-06-2017, 10:16 PM | #15 |
I checked this morning. The finish looks good. No brush marks although I used a foam brush, either way the stuff laid down nice.
Looks factory and see what time does. I got the 4oz can and and used very little of it so it goes a long way. RRM
07-06-2017, 11:37 PM | #16 |
Sub'd for results in a month.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-07-2017, 05:56 PM | #17 |
BlahBlahBlah
Looks good! I just looked at my dopey earlier comment. Read right past what you were up to and assumed you were looking for ideas ... duh haha.
07-07-2017, 09:32 PM | #18 |
Looks great, I hope it lasts. Waiting for your conclusion on that.
07-07-2017, 09:42 PM | #19 |
07-07-2017, 09:51 PM | #20 |
following
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
07-08-2017, 12:12 AM | #21 |
I have had Everbrite on some E-T slot mags for 3 years now. They still look great and they get driven a lot.
07-08-2017, 08:25 AM | #22 |
I think you nailed it looks like an OE finish hope it holds up...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
07-08-2017, 09:51 AM | #23 |
sub
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
08-08-2017, 10:04 PM | #24 |
Well I promised I would post one month results.
So far the coating is working great. Looks exactly has it did when I applied it. Previously for this I was trying wax and other products and having to re polish weekly to get the grill looking nice. Anyway. Highly recommend Pic attached. Posted via Mobile Device |
08-09-2017, 08:23 AM | #25 |
Relative to my current project at GM: we are using CNC billet polished aluminum for the bright exterior trim (body side moldings, window trim, etc).
We used clear powdercoat over the aluminum (which is the production process for aluminum wheels) but are gravitating towards using automotive clear paint over the aluminum, which gives us a little bit smoother finish. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
