Bought a '91 suburban without engine/transmission or wiring harness for $200 body is excellent...I have a '90 suburban cracked frame going to switch everything from the '90 to the '91
I haven't actually driven it since not really sure early 2016...fuel pump I thought went out but a friend hooked the relay to the battery and it started and drove fine but obviously would drain the battery. I did replace the relay and oil pressure switch but without it being hooked to the battery with the hot wire it won't start. I'm a total novice at wiring, any help on what is out of place would be greatly appreciated! '90 gmc suburban 5.7 tbi/700r4 miles on engine 45k Having issues uploading photos
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Photos
More photos
Re: 5.7 tbi
A relay is essentially a switch. If you can only get it to run by applying direct power to the "switched" terminal then whatever is telling the switch to open is where I would look. There are 4 wires on a relay... 12v power in from battery, 12v out to fuel pump, ground, and switch wire. Figure out which wire is your switch and trace it back and see if a problem shows itself. I am not familiar with the wiring for the TBI engine to give you any better advice.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
Now, I know why the wires were wrapped in duct tape, electrical and loom...to hide this mess!
Fixed the engine harness today, found this when tracing the wires to the tank. Could this cause it to not start? Thanks!
