Old 08-26-2015, 05:56 PM   #101
hammersmith
hammersmith's Avatar
Re: how about some pics of inline 6 engines
Originally Posted by Sixteen Tons View Post
@hammersmith
That fresh air draw from the exhaust manifold to air cleaner is something I've never seen before. Is this modified (doesn't look like it) or a different exhaust manifold altogether??
This stove pipe is not the original one from my truck but it did have one very similar back in the day. I got this one from a 69 camaro and the air cleaner. The horn of the air cleaner has a larger opening and sits more at 5 o'clock we're my original sat at 4 o'clock.
hammersmith is offline   Reply With Quote
Old 06-29-2016, 11:25 PM   #102
rdhowe2006@yahoo.com
rdhowe2006@yahoo.com's Avatar
Anyone know where I can get an air filter assembly for my IL 6 Cylinder?
rdhowe2006@yahoo.com is offline   Reply With Quote
Old 06-30-2016, 07:30 AM   #103
Grumpy old man
Grumpy old man's Avatar
Watch the parts section , I found one for $10.00 + shipping . Media blasted it and after a few coats of high build primer it looks brand new .
Old 07-01-2016, 01:50 AM   #104
VWNate1
VWNate1's Avatar
Post Re: how about some pics of inline 6 engines
It depends on which one you want ~ the big off set truck one is out there but hard to find as no one wants them so they gets tossed aside or damaged
The flat typ as used on Chevy II's , Camaros , Malibus and full size sedans , are also out there and often cheap .
I have a few but they're a bit rusty , once I get access to a bead blaster I'll clean and strip them then sell off .
Same air cleaners interchange between 194 , 230 , 250 and 292 CID engines with the later Rochester carby (?) BC series IIRC .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 07-04-2016, 04:22 PM   #105
Hey do you know where I can get an Air Filter Assembly like yours. I have been looking for one like 6 months. I cant even drive my 1970 c10 IL 6 250 because I have no air filter assembly. Any help would be appreciated.
Old 10-02-2017, 09:38 AM   #106
old51sedan
old51sedan's Avatar
Originally Posted by '68OrangeSunshine View Post
As far as I know, "there ain't no such animule" as a fan shroud for the L6 engines. They all had "Finger Guards" which is a piece of bent sheet metal that bolts onto the radiator support and extends down about 6" over the fan to keep all but the most dedicated idiot from losing his fingers.
This is not to say a fibreglas/plastic fan shroud from an SBC set up wouldn't fit in that spot.
As far as the clutch fan idea, it might work out OK. I've been using a FlexFan on my 292 since 1977 and have not had a problem yet. [And I live in Ariz.]
I have a 69 C-10 that I bought in CA with the 250/ 3 speed auto. It has a fan shroud and a 3 core radiator, looks original to me, no heating problems. I removed the smog control and installed PS. I'm currently rebuilding a 292 for it and I need thermostat housing for it. I need one where the top rad hose points towards the drivers fender, not straight up. Would you by any chance have one? Thanks, Donn
old51sedan is offline   Reply With Quote
Old 10-02-2017, 02:58 PM   #107
'68OrangeSunshine
'68OrangeSunshine's Avatar
Did you mean one of these?
Old 10-02-2017, 06:40 PM   #108
Not in a truck but wouldn't that be cool?
Old 10-02-2017, 07:36 PM   #109
'68OrangeSunshine
What is it? Looks like maybe a Vortec 4.2, but the early '60s oil filler tube/breather cap throws me. Also looks like a Pontiac Catalina/GTO nose, w/ Sprint badge. So is it an El Cabrito? [Sp. for '' little goat''] Some might contend that it is a truck, then.
Can't read the numerals on the fender badge.
Old 10-02-2017, 07:43 PM   #110
old51sedan
old51sedan's Avatar
Yes, something like that. Is there a place there for the temp sending unit? Does it take the larger hose, meaning bigger around?
Old 10-02-2017, 08:32 PM   #111
bill3rail
bill3rail's Avatar
Since I was not the one to dig up this thread, I'll add to it.
Air cleaner has been replaced and looks much better now.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 10-02-2017, 11:47 PM   #112
'68OrangeSunshine
Well, yes and no. The stock Chevy Thermostat Housing is made from cast aluminum. Stock OEM form, it has no hole for a temp probe. My original piece broke, once when I overtightened it. I went to Pep Boys and showed them the broken part. They didn't have anything like that for a [then] 25 year old Chevy L6. But, the parts guy started looking around amongst other makes and found a Thermostat Housing from [I think] a Toyota Landcruiser that had the big ''I-6'' 2F 4.2 Liter. (It was a clone of the old Chevy 261 L6 -- a Korean War logistics expedient, that stayed).
The Toyota housing is made of cast iron, fits the same, and does have a port for a temperature probe.
Hoses fit, no issues.
Moral of the story: Chevys have L6s, Ford and Toyota call it an I-6.
Old 10-03-2017, 12:39 AM   #113
IRQVET
IRQVET's Avatar
250ci Inline 6 out of a 68 C-20 Flat Bed . . . Correction, it's a 292ci. (Thanks VWNate1)
1998 Chevy Tahoe 2D
1949 Willys CJ2A
1967 C-20 Flatbed (Sold)
IRQVET is offline   Reply With Quote
Old 10-03-2017, 08:20 AM   #114
Originally Posted by 68OrangeSunshine;8052573]What is it? Looks like maybe a Vortec 4.2, but the early '60s oil filler tube/breather cap throws me. Also looks like a Pontiac Catalina/GTO nose, w/ Sprint badge. So is it an El Cabrito? [Sp. for '' little goat'
It's a Pontiac OHC6, based on the Chevy 230 block.
https://www.google.com/url?sa=t&rct=...66PjstR6GPlOnX
Old 10-03-2017, 08:24 PM   #115
VWNate1
VWNate1's Avatar
That's a 292 C.I.D. engine......
-Nate
Geezer
Old 10-03-2017, 08:31 PM   #116
IRQVET
IRQVET's Avatar
Dam, I think your right.
1998 Chevy Tahoe 2D
1949 Willys CJ2A
Old 10-03-2017, 09:41 PM   #117
VWNate1
VWNate1's Avatar
Talking Re: how about some pics of inline 6 engines
I am, rejoice ! .
-Nate
Geezer
Old 10-03-2017, 10:56 PM   #118
Oscar the grouch
Oscar the grouch's Avatar
292 in my 67 k20 long stepper
1970 chevy k10 305/4 speed
Oscar the grouch is offline   Reply With Quote
Old 10-04-2017, 02:28 AM   #119
'68OrangeSunshine
I didn't catch that at first. Yes, the Pass side motor mount is forward of the fuel pump.
That yellow '68 C/20 also has a strange looking water neck [T/Stat Housing] with a flat spot that could be machined for an opening to mount a temp probe, which I think Old51Sedan is looking for.
Old 10-04-2017, 12:56 PM   #120
IRQVET
IRQVET's Avatar
Thanks guys, I'm new to these trucks and to inline 6's in general. Old yellow was the previous owners hay picker upper/ farm truck. The paint job on it is one of the worst DIY jobs I have ever seen, lol.
1998 Chevy Tahoe 2D
1949 Willys CJ2A
Old 10-04-2017, 03:01 PM   #121
cjrolke
here is my little guy
cjrolke is offline   Reply With Quote
Old 10-05-2017, 10:58 PM   #122
IRQVET
IRQVET's Avatar
Anyone here turbo or supercharge their inline 6? I love seeing something different . . .
https://www.youtube.com/watch?v=8uKYVGH6yA8
https://www.youtube.com/watch?v=Vk-AJEkkR9I
And then the token Canadian . . .
https://www.youtube.com/watch?v=3GPy2_aGQKc
1998 Chevy Tahoe 2D
1949 Willys CJ2A
