Old 11-21-2017, 10:51 PM   #1
NC_John
NC_John's Avatar
1-7/8" long tube headers?
Anyone aware of a 1-7/8" long tube LS header available for the 67-72? I've found 1-3/4" but not the larger diameter tubes.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 11-22-2017, 09:08 AM   #2
Steve Cole
Re: 1-7/8" long tube headers?
Speed Engineering makes some but they are not coated, they are stainless steel. I guess you could have them coated. They are cheap enough and fit well.
Steve Cole is offline   Reply With Quote
Old 11-22-2017, 09:22 AM   #3
Steve Cole
https://www.speed-engineering.com/ls...2-ls3-ls6.html
Try this link.
Old 11-22-2017, 11:49 AM   #4
NC_John
NC_John's Avatar
Originally Posted by Steve Cole View Post
Thanks Steve. I'll see how they compare (visually) to the long tubes we ran on the dyno.
1970 C-10 LWB "Blu"
Old 11-22-2017, 12:59 PM   #5
clemsonteg
This is what I plan to run. Box is sitting in the garage waitin on me.
http://www.dougthorley.com/1967-1987...3Y-C_p_46.html
clemsonteg is offline   Reply With Quote
Old 11-22-2017, 09:41 PM   #6
NC_John
NC_John's Avatar
I have those now but want to switch to long tubes (better high rpm performance). Its too bad because the DT's look top notch.
1970 C-10 LWB "Blu"
Old 11-22-2017, 11:01 PM   #7
67LS3GMC
I just installed Speed Engineering 1-7/8" long tubes and am impressed with the quality for the price. It will be a while before I run them (frame off rebuild)
Did have to grind a little (3/8) off pass side frame . Also ear on transmission and nub on block above oil filter. I used MSD multi angle plug wires.
67LS3GMC is offline   Reply With Quote
Old 11-23-2017, 08:27 AM   #8
NC_John
NC_John's Avatar
Thanks for the feedback. Yeah, they might be the only game in town for a direct fit 1-7/8 LT header. I think there are some others that *might* or *should* fit (keep hearing trailblazer SS should) but they aren't sold for our specific application so I'm staying away (I don't want to create unnecessary headaches). My engine guy compared them (visually) to his engine dyno headers and he said they looked pretty close.
I haven't heard anyone grinding on anything but the transmission to fit (and figure since mine is a M6 I might not have to). Guess I'll brace myself in case I have to do some more "fitting" like you did and maybe leave the front clip off until I know for sure.
1970 C-10 LWB "Blu"
Old 11-23-2017, 11:47 AM   #9
71Charlie10
67ls3 , do you have a picture of how low the long tubes hang past the frame? trying to get an idea how low they hang from a distance before i pull the trigger.
71Charlie10 is offline   Reply With Quote
Old 11-23-2017, 04:00 PM   #10
67LS3GMC
Sorry , gave up trying to post pic
Old 11-25-2017, 11:15 PM   #11
Steve Cole
Read this thread, you will find pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=746414
Old 11-26-2017, 01:24 PM   #12
wesmigletz
wesmigletz's Avatar
Does anyone know if the speed engineering 1 3/4 or 1 7/8 headers work with a column shift?
Thanks,
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 11-26-2017, 02:31 PM   #13
NC_John
NC_John's Avatar
I ordered a set this morning (1-7/8 long tube). I'm running a T-56 so I won't be able to comment on shift linkage clearance but I'll post some pics when they come in and I get them hung.
1970 C-10 LWB "Blu"
