#526 |
Re: Project "Steppin Wolf" LS swap
I would have thought that the truck would run 12's with that engine and some slapper bars. Turbo is cooler though!
I think it is going to be a bit too small though. Going from rear mount to front mount will require it to move a lot more air.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#527 | |
This turbo is definitely small but I payed $150 for the whole rear mount setup after selling the headers that came with it so it'll do for now. It was making almost 500 whp on the firebird in a rear setup so it should be good with what I'm trying to do. If not I'll upgrade later. Good thing about it is it should spoil right off idle so will feel more like a supercharger and with a stock stall that's exactly what I'm looking for. Like I said when I first started this build, I'm not looking for a drag strip monster, I'm looking for a fun daily driver. I'm pretty sure I've got the right combo for that goal. ![]()
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
#528 |
Alright gentlemen(and ladies), Turbo build is moving along great! I started a playlist that shows nitrous runs and then all the custom fab work we've done for the turbo set up. You can check it out here..
https://www.youtube.com/playlist?lis...2gHi_EKoCBYBkr
#529 |
The entire hotside was fabbed together from junk. We chopped up a set of 6.0 manifolds, then made the crossover out of pieces of old exhaust we had laying around.This was the beginning.
#530 |
Then I wrapped them and installed them on the truck.
#531 |
intercooler has also been mounted and all coldside piping cut and run.
#532 |
Oil pan has been tapped, feed line ran, etc. Dont have anymore pictures but lots of video of this whole process here:
#533 |
One foot in front of the other
![]() Join Date: Aug 2008
Nice to meet you today. Cool build
#534 |
It was good to meet you too! and thanks!
#535 |
Ok guys here it is! FIRST DRIVE OF THE TURBO C10!
https://www.youtube.com/watch?v=k9eKkrQv6qA&t=25s
#536 |
This is how much it cost me to do a completely custom budget turbo set up on my ls swapped C10!
https://www.youtube.com/watch?v=RybOvdANTMA
