11-22-2017, 03:08 PM | #26 |
Re: 72 Plaid Sub
Mocking up some sheet metal for the rear floor. Had to cut the floor for the driveline to come through when the suburban is laid out.
11-22-2017, 03:11 PM | #27 |
Re: 72 Plaid Sub
More sheetmetal mock up and you can see how high the rear fender wells are raised.
11-22-2017, 03:19 PM | #28 |
Re: 72 Plaid Sub
More rear floor work and mocking up the cardboard gas tank.
11-22-2017, 03:27 PM | #29 |
Re: 72 Plaid Sub
The new Delmo's CST wheels showed up back in January. Here's one next to the original 15" wheel cap. My custom Boyd Welding gas tank showed up as well.
11-22-2017, 03:35 PM | #30 |
Re: 72 Plaid Sub
Back in February I decide to change the Porterbuilt version 6 front drop member out for the new version 7. It allowed more clearance for the L83 motor and incorporated the new steering geometry.
11-22-2017, 03:42 PM | #31 |
Re: 72 Plaid Sub
Back in March I received one of the first Holley Gen V swap oil pans. Had to install a 2009 Pontiac G8 transmission pan on the 6L80E as well. Stock trans pan hung down below the frame.
11-22-2017, 03:49 PM | #32 |
Re: 72 Plaid Sub
Some pics out in the sunlight mocking up the front core support, radiator, and fans. Went with the Entropy LSX radiator and fans.
11-23-2017, 10:26 AM | #33 |
Re: 72 Plaid Sub
Looks really good
11-23-2017, 03:20 PM | #34 |
Re: 72 Plaid Sub
Hey, This looks great. I am going an LT in my 67 Long box and just decided to go to the V7 over my current V6 drop member based on your pictures from Instagram and the advice from Brandon over at PB. They are currently working on getting my order built and are working on a new set of Engine mounts. Curious to know what you did for mounts and what your plan is for Headers/Manifolds. I also got one of the first Holley LT pans but got Tied up is a SEMA project that pulled me away from my truck project. I wish I would have realized sooner that the V7 was going to be a better option for this engine package.
If there is anyone out there looking for V6 1' narrow Control arms I have a set for sale. Too bad I welded the drop member in could have sold it too..... Anyway the truck looks great I will keep an eye out for updates. |
11-23-2017, 06:12 PM | #35 |
Re: 72 Plaid Sub
11-24-2017, 06:50 PM | #37 |
Re: 72 Plaid Sub
The sheet metal for the notch looks great. I need to do something similar on my 53 Suburban to clear the PB notch. I went with a 2 piece drive shaft similar to what C-10 guys use and I didn't need to cut my floor up any more to accommodate a drive line. I assume you planned to run a 2 piece drive shaft. The Delmo wheels look great. Are they 22's?
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-24-2017, 11:11 PM | #38 |
Re: 72 Plaid Sub
Very nice work! Love your Burb, tagging along for the rest.
11-25-2017, 01:08 PM | #39 | |
Re: 72 Plaid Sub
I went with the Porterbuilt LS mounts and ICT Billet LS to LT adaptors. I did this because it raised the motor and trans to the proper elevation so the trans pan wasn’t lower than the frame rails. The 6L80E is a huge trans and just barely fit with the G8 pan. I will eventually talk to Porterbuilt about re-making the mounts so I don’t have to have the adaptors in there. As for the exhaust manifolds, I chopped the flange off the stock manifolds and welded a v-band flange on. This was a quick fix to get the suburban running and down to AZ for the Gitdown and Goodguys. I tried the 2016 Camaro tube manifolds, but they didn’t work with my steering. Passenger side was good, but the drivers side was no good. I will eventually make my own headers. Bret |
11-25-2017, 01:13 PM | #40 |
Re: 72 Plaid Sub
You’ll have to contact Delmo for pricing on the wheels and Rusty over at Diamondback Classics for pricing on the tires. I can tell you the wheels were priced similar to other 22” billets on the market when I bought them a little over a year ago.
11-25-2017, 01:16 PM | #41 |
Re: 72 Plaid Sub
11-25-2017, 01:25 PM | #42 | |
Re: 72 Plaid Sub
The wheels are 22 x 8.5 up front and 22 x 10 in the back. |
11-25-2017, 01:28 PM | #43 |
Re: 72 Plaid Sub
Thanks!
11-25-2017, 01:32 PM | #44 |
Re: 72 Plaid Sub
11-25-2017, 07:19 PM | #45 | |
Re: 72 Plaid Sub
Bret, Thanks for the information, the Guys at PB are currently making a set of LT mounts so I should be getting one of their first sets. I will be getting them un welded as they are using the stock GMPP pan (Corvette) I of course have the Holley pan and their accesory drive for my setup so I am anticipating some differences in how everything will fit because the GMPP engine uses a vette balancer and I am running a truck balancer. Once I have the engine in place I will be giving the guys at Ultimate header a call as they already have an LT header and will work with me to move the collector around if I need it in a different area. |
11-27-2017, 12:14 PM | #46 | |
Re: 72 Plaid Sub
11-27-2017, 02:42 PM | #47 |
Re: 72 Plaid Sub
Bret that is awesome information.
The reason I Went with the Holley parts is I got the engine as a pull out and did not have the balancer or water pump. at the time when I was doing the initial fit there was only one option for a drive system that I was not too impressed with so the Holley was the next best choice..... Maybe now I will have to consider going to the Drive Junky Kit. I got a chance to see some of their kits at SEMA. and they look like a great piece. Are you Running the AC compressor on your engine. Any fitment issues with it? |
11-28-2017, 01:15 PM | #48 | |
Re: 72 Plaid Sub
11-28-2017, 01:23 PM | #49 | |
Posted via Mobile Device |
12-07-2017, 01:46 PM | #50 | |
Re: 72 Plaid Sub
