Old 01-01-2018, 07:55 PM   #1
Jmh68C10
Jmh68C10's Avatar
Need recommendation on swap parts for ls3 porterbuilt truck
I am mid process on my 68 c10 build and need to order some parts. I trying to figure out what my best options are for a few parts I am ready to order. I have the porter built (stage 3 ) Version 7.
Questions
1. My Ls3 is out of a 2011 escalade so it has the truck intake (Tall). Will I have clearence for this?
2.What master cylinder/ brake booster should I go with that will give me adequate clearance with the Ls3. I converted to 4 wheel disc brakes.
3. Can stock exhaust manifolds be used? If so , I still may run aftermarket so recommendations are appreciated.
4. Am I correct in that the a/c compressor has to be relocated to fit with the swap? I have a 4l75e ordered from chevy coming in next week so I will getting the engine and trans set in hopefully next weekend.
I am somewhat getting to the final stages before I break it back down for paint so I would love to hear some advice from people who have completed similar projects. Here is my frame as it sits tonight.
68 c10- Under construction
Jmh68C10 is offline   Reply With Quote
Old 01-02-2018, 04:33 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Need recommendation on swap parts for ls3 porterbuilt truck
1. With the v7, should be no problems, as the engine is much lower than previous versions (near stock crankshaft centerline).
2. Same here, stock-sized should work. I’d stay at least 11” booster, or dual 8” if you’re looking for clearance. 4-wheel disc master of your choosing
3. Stock Camaro LS3 manifolds should clear, otherwise CPP or Hooker (or f-body, or trailblazer). Chevelle shorty or mid length headers is what PB recommends—I’m gonna see if long tubes will work
4. I’ve seen people fit the compressor in stock location swaps, though I have yet to see low mount with a dropmember. Like you, I hope to mock up soon and measure for accessories
Check out my ‘70 build in my signature. It’s an in-progress DMv7 LS swap
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-02-2018, 10:53 PM   #3
Jmh68C10
Jmh68C10's Avatar
Nice build ! Here is a pic of my truck before I disassembled. (and when my garage was alot cleaner)
Old 01-02-2018, 11:34 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Nice start, and good progress!
-Chris
Old 01-04-2018, 04:33 PM   #5
Hart_Rod
Hart_Rod's Avatar
Questions
1. Not sure on the newer version, but the truck intake wouldn't work when I built mine.
2. I used a Wilwood setup with 9" booster using the CaptainFab booster mount.
3. 2010+ Camaro exhaust work great!
4. The factory AC compressor would not work with the older PB version, I went with a complete Holley accessory setup.
5. You'll need different front wheel tubs (SloshTubz or Hills Rod & Custom).
6. You'll also need to raise the rear bed floor, meaning you will need shortened rear wheel tubz. I'll put a shameless plug in here for my ChubTubz, . http://67-72chevytrucks.com/vboard/s...d.php?t=675754
7. You'll need new hood hinges. If you are going to use PBFab hood hinges, I make a bracket that will allow you to bolt them to your hood without welding.
http://67-72chevytrucks.com/vboard/s...d.php?t=679945
You can check out my build thread as I encountered most of the stuff that you will: http://67-72chevytrucks.com/vboard/s...d.php?t=551258
Check it out and let me know if you have any questions - Rob
Hart_Rod is offline   Reply With Quote
Old 01-05-2018, 08:28 PM   #6
Jmh68C10
Jmh68C10's Avatar
Appreciate the input. Truck looks awsome. Here is Brandon from porterbuilts input which pretty much confirms what you said. The tall manifold may or may not work. More than likely, it will not, but we have had some guys have luck with it. I believe they did have to run a different accessory set-up though.
"You should be ok with a 7" booster mounted on the firewall.
No, stock headers will not work. The only headers we know will fit 100% are the set we sell. You can order them direct from our dealer c10shop.com. They have them in stock.
Yes, the a/c compressor will have to be relocated. You can get a bracket from Dirty Dingo. "
Sure ill have some questions for you as the build goes on
Old 01-05-2018, 09:12 PM   #7
Jmh68C10
Jmh68C10's Avatar
Hart_Rod What version pb drop member are you running ?
Old 01-06-2018, 02:26 PM   #8
Hart_Rod
Hart_Rod's Avatar
I think it was version 3 or 4, but can't remember.
Old 01-06-2018, 03:05 PM   #9
Jmh68C10
Jmh68C10's Avatar
Do you have some pics of how you raised your bed floor?
Old 01-06-2018, 03:13 PM   #10
Hart_Rod
Hart_Rod's Avatar
Take a look at my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=551258
Old 01-07-2018, 05:31 PM   #11
Jmh68C10
Jmh68C10's Avatar
Do you have a set ready?
Old 01-07-2018, 05:47 PM   #12
Hart_Rod
Hart_Rod's Avatar
Yes I do!
Old 01-07-2018, 06:04 PM   #13
Jmh68C10
Jmh68C10's Avatar
Yes I do!
Pm sent
Old 01-07-2018, 09:39 PM   #14
Hart_Rod
Hart_Rod's Avatar
Pm sent
PM returned.
