12-23-2017, 10:42 PM | #226 |
Re: A real BadSeed
12-24-2017, 01:40 AM | #227 |
Re: A real BadSeed
18,700 views!!
12-26-2017, 11:55 PM | #228 |
Re: A real BadSeed
Some pics.
01-07-2018, 09:44 PM | #229 |
Re: A real BadSeed
I got all my parts in for the battery trays.
01-07-2018, 09:46 PM | #230 |
Re: A real BadSeed
Time to mock them up and get them mounted. These will be bolt on when done.
01-07-2018, 09:50 PM | #231 |
Re: A real BadSeed
I want these to match the rest of my parts with a radius like the frame corner.
01-07-2018, 09:51 PM | #232 |
Re: A real BadSeed
And installed...
01-08-2018, 12:05 AM | #233 |
Re: A real BadSeed
Speechless! OMG - mad skillz and even sicker style! This truck is gonna crush the scene which is hard to do these days!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
01-08-2018, 01:35 AM | #234 |
Re: A real BadSeed
Damn Great build so far!!!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
01-14-2018, 12:08 AM | #235 |
Re: A real BadSeed
I finished up the battery strap with a barrel hinge on the corner to make it more easily removable. This side is done. On to the driver's side
01-14-2018, 12:09 AM | #236 |
Re: A real BadSeed
#BadSeed #AirLift #DotLowRides #XtremeLowz
01-15-2018, 11:41 PM | #237 |
Re: A real BadSeed
Can you show what your using as a base for the foam seat ?
01-16-2018, 10:38 AM | #238 |
Re: A real BadSeed
Battery tray set-up turned out very nice. I'm wondering about their placement though. Seems they're installed in the same real estate the front bed panel will need to occupy?
01-16-2018, 10:17 PM | #239 |
Re: A real BadSeed
01-16-2018, 10:19 PM | #240 |
Re: A real BadSeed
I'm using the factory bench seat with the springs removed. I have a 2000 rack under it, and a combination on 67 and 00 feet attached to the bottom.
01-21-2018, 01:26 AM | #241 |
Re: A real BadSeed
I've been workin on finishing the second battery bracket. It's almost there, then I just have the second strap to do.
01-21-2018, 01:28 AM | #242 |
Re: A real BadSeed
Here's a shot of both. I'm real happy with how they came out. On to the next project.
01-21-2018, 03:25 PM | #243 |
Re: A real BadSeed
SICK! Nice work! Are you going to have access doors in the bed?
01-21-2018, 10:08 PM | #244 |
Re: A real BadSeed
05-26-2018, 02:01 PM | #245 |
Re: A real BadSeed
Well, it's time to get back on this. It' shard to coordinate getting friends over to help so I made a cab puller.
05-26-2018, 02:03 PM | #246 |
Re: A real BadSeed
I'm replacing the vents in my dash. The dimple die is overdone these days. So I'm going with my own custom design. I needed to make a duct bucket for ach one, and this is what I came up with. After this I will be focusing on finishing the chassis.
05-27-2018, 03:51 PM | #247 |
Re: A real BadSeed
I started making the plates to box in the frame.
05-29-2018, 12:29 AM | #248 |
Re: A real BadSeed
First time marrying the SBC350 to the 700r4 trans. I have a Lokar shifter kit in it too.
05-29-2018, 12:31 AM | #249 |
Re: A real BadSeed
Motor/trans mock up
06-09-2018, 04:04 PM | #250 |
Re: A real BadSeed
Does anybody look at this?
Tags |
67 c10, badseed, marley marvelous |
