Old 12-18-2017, 08:02 PM   #1
RedBed
RedBed's Avatar
Coverlay install question
I bought a Coverlay dash cover. The PO had tried to recover the dash himself, with comical results (see pic).
I really like the look of the Coverlay and I'm getting ready to install. But the current vinyl cover is folded in a couple of places and a bit bulky under the cover. I am able to peel it off and be left with the foam padding intact. It might be better to install the cover over the foam so it would conform better, but I have not done it, and once you glue it, I assume you are pretty much "stuck" with it.
Has anyone installed one and if so, has anyone done it over the foam?
I did attempt to contact the Mfg, but they are closed for the day. They are very good about answering questions, but I am curious if anyone else has done this?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 12-18-2017, 10:59 PM   #2
RedBed
RedBed's Avatar
Re: Coverlay install question
My dash pad was screwed down on the right side in 4 places. Is this the way it normally mounts?
Old 12-18-2017, 11:23 PM   #3
mongocanfly
mongocanfly's Avatar
got one in my truck...works and looks good...I'd strip that garbage off...the coverlay only contacts the old dash in a couple places. .read the instructions. .it shows you where to put the silicome adhesive...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-18-2017, 11:40 PM   #4
RedBed
RedBed's Avatar
After a little research it seems the 4 holes on the right side are normal. But the Coverlay does not have any holes in it, so I guess once it is on there is no removing the dash pad again unless you break the strip on the bottom?
Old 12-19-2017, 12:55 AM   #5
Desert_Eagle02
Yes the 4 screws on the right side is how it is supposed to be. I have never used a Coverlay but I did replace my old dash pad with a new one. The new one had 4 rectangular indentations for the 4 screws just like the factory one. You put the dash pad in and get it lined up and when you are happy, you use a pick or an awl to make the screw holes in the pad itself. Perhaps that is how you also do it with the Coverlay?
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 12-20-2017, 09:49 PM   #6
tucsonjwt
I did not install a Coverlay but I did install a competing brand of stick on cap. It was a disaster, though installed per mfg instructions. In HotZona 110+ degree heat it buckled and cracked all over the place. I had to remove it (and it took a lot of good foam and vinyl with it) and will be attempting to have a local upholsterer recover it. It might work in a nice cool climate like TX, but not AZ.
tucsonjwt is offline   Reply With Quote
Old 12-20-2017, 10:28 PM   #7
RedBed
RedBed's Avatar
Originally Posted by tucsonjwt View Post
...It might work in a nice cool climate like TX, but not AZ.
Never heard anyone describe Texas as a "nice cool climate" but I will take it from an Arizonian... you guys are NUTZ!
Did a test with the glue on the crappy DIY vinyl the PO put on my dash. It peels right off. So that will not work, not even gonna try. Will contact the Mfg tomorrow to see what they say. If I have to return it, I will also call an upholstery shop.
However, Coverlay guarantees the dash against warping or breaking for the life of the vehicle. Can't speak for the other companies that make caps.
Old 12-21-2017, 09:00 AM   #8
TKCR
TKCR's Avatar
Why not just get a new dash form Cheyenne Parts or USA1 Industries. I realize they are more money, but it sure would save you all the aggravation of the work involved. I have seen more Coverlay installs that look like crap vs. one that actually turned out good.
http://67-72chevytrucks.com/vboard/s...d.php?t=736613
https://www.usa1industries.com/1979-...nyl-style.html
Old 12-21-2017, 01:23 PM   #9
RedBed
RedBed's Avatar
That idea is what I am considering. I may have to return the Coverlay and just go for the real deal. A shame though. I think the Coverlay would look real nice... if it worked for me.
Old 12-21-2017, 01:29 PM   #10
RotaryRocketeer
RotaryRocketeer's Avatar
FWIW, the dash I got from Cheyenne was awesome and came with the clips already installed. A breeze to put in, and improved the interior of the truck 100%.
RotaryRocketeer is offline   Reply With Quote
Old 12-21-2017, 02:26 PM   #11
RedBed
RedBed's Avatar
Yep, ok. Coverlay is boxed up for return. Will be calling Cheyenne. Thanks!
Old 12-21-2017, 05:13 PM   #12
TKCR
TKCR's Avatar
You will be happier with the new dash. And all you’ll have to do is install it. Post up pics when it’s back together!!
Old 12-31-2017, 02:14 AM   #13
RedBed
RedBed's Avatar
Ordered the dash pad from Cheyenne, will post when installed!
Old 01-03-2018, 09:16 PM   #14
tucsonjwt
Personally, I would not install any plastic dash pad, even one that is all plastic. I think the metal frame of the original dash makes it worth a shot for recovering, and I will be trying that at an upholstery shop.
Old 01-04-2018, 11:48 AM   #15
RWJJR
RWJJR's Avatar
You will love the dash from Cheyenne , best looking and fitting on the market.
1980 Silverado short bed
1993 GMC 1500 LS swap
2006 Lifted Z71 Crew Cab
RWJJR is offline   Reply With Quote
Old 01-12-2018, 04:48 AM   #16
echo7bravo
Has anyone ever paid an upholstery shop to recover a dash pad? Was thinking black leather with French seams would be sexy.
echo7bravo is offline   Reply With Quote
Old 01-12-2018, 12:01 PM   #17
RedBed
RedBed's Avatar
A custom would be nice, but I received and installed my Cheyenne dash pad, and it is BEE-YOO-TEE-FUL!
Once I am done with interior I will post pics.
Old 01-12-2018, 02:43 PM   #18
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
This is my Cheyenne pad that I installed last week
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-24-2018, 12:58 PM   #19
RedBed
RedBed's Avatar
You guys were right. The Cheyenne dash pad is THE way to go. I am really happy with mine.
Old 01-24-2018, 01:37 PM   #20
Ol Blue K20
Looks great!! I love mine too.
Dale
Old 01-24-2018, 02:34 PM   #21
Mattchu60
Did your cheyenne dash drop right in? I got one that I believe was made by Dashes Direct a couple years ago - the install took many hours as it fit pretty poorly - had to cut a lot of material away to get it to sit flat on the dash and run a screw into the drivers side of the dash as it wanted to flare out.
Mattchu60 is offline   Reply With Quote
Old 01-24-2018, 02:43 PM   #22
RedBed
RedBed's Avatar
It just slid right in, no trimming, no hassles. Came with the clips already installed. Actually it was one of the easiest jobs involving my interior refurb.
Old 01-24-2018, 03:04 PM   #23
RotaryRocketeer
Right? Mine was a breeze and looks awesome. Definitely an easier job than anticipated.
Old 01-24-2018, 03:56 PM   #24
Ol Blue K20
On mine (89 V3500) it didn't like my drivers side speaker. I had to modify the speaker mount. Other than that it was a easy installation and looks great. I would buy another one in a heartbeat. They cost a little more but in my opinion it's worth it.
Dale
Old 01-24-2018, 05:12 PM   #25
RedBed
RedBed's Avatar
Originally Posted by Ol Blue K20 View Post
...They cost a little more but in my opinion it's worth it.
Yep. I am a notorious tightwad, and normally it works out, but occasionally, I "lose money by saving money".
The Coverlay is a great product if you have a stock, beat up dash. Looks good, easy install.
But in my case, the dash had been recovered by a non-pro, and it looked like sh*t aside from making it unable to accept the Coverlay. I should have known this and gone with the Cheyenne dash in the first place. Would have saved me on return shipping...
Live and learn... or not... heh heh.
