Old 01-28-2018, 07:44 PM   #1
faun_cee
Mini starter for inline 6
my 69 Chevy is running a 4.1 L inline 6 with a 350 turbo. i want to run one of those mini starters, as many people are, but ive only seen them for 350 engines.
Will a 5.7 L corvette starter work with my truck?
faun_cee is offline   Reply With Quote
Old 01-28-2018, 08:03 PM   #2
harpo231
harpo231's Avatar
Re: Mini starter for inline 6
They make one for ford 250 not chevy
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-28-2018, 08:39 PM   #3
ZEKE68
ZEKE68's Avatar
Is your six block drilled for the diagonal bolts? My 250 six was drilled for both in line and diagonal starters. I always thought that the starters were the same for six and small block, and that what matters is the flywheel/flex plate diameter. the inline bolt starters fit the 153 tooth flywheels, and the diagonal bolt starters fit the 168 tooth flywheels. But that is just what I thought. May someone else will confirm it for you.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 01-28-2018, 08:55 PM   #4
Mike C
Mike C's Avatar
What size flywheel do you have? If you have 153 tooth wheel, get a starter for a 3.0 mercruiser. The 181 cubic inch Merc is the Old Chevy II 153 ci motor bored and stroked. The Chevy II is 2/3 of a 230/250 six if you weren't familiar with them.
I used a 3.0 gear reduction starter on the 153 ci Postal Jeep motor (used by Kaiser Willys 68-70 in the short nose postal in front of a Powerglide!) I'm R&Ring for a jeep project.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-28-2018, 09:03 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm curious why you would want to spend the money on one, since the 6 cylinder starter stays plenty cool. The only reason I bought one for my truck was because the big one was getting baked by the exhaust heat.
~Steven
Simi Valley, CA
Old 01-29-2018, 03:48 PM   #6
faun_cee
its only drilled for in line
Old 01-29-2018, 03:51 PM   #7
faun_cee
A few people have mentioned putting it on their trucks. my starter is fine just wondering for future improvements.
Old 01-29-2018, 08:24 PM   #8
Don Quixote
Don Quixote's Avatar
I run a high torque mini starter on my 292. Somehow my block was drilled so I can bolt it straight up like a small block. I had never seen an inline set up like that but it worked out well for me.
I click the starter for merely a split second and it fires right up so there is almost no stress on it.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
inline 6, mini starter
