Old 01-31-2018, 09:26 PM   #1
upon1
upon1's Avatar
4l60e cooler line fittings
What is the best sealing washer to use? Been having trouble not crushing the Nylon type and was wondering if the brass washers would work better?
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 01-31-2018, 11:05 PM   #2
sprint_9
sprint_9's Avatar
Re: 4l60e cooler line fittings
Copper is good
sprint_9 is offline   Reply With Quote
Old 02-01-2018, 03:19 PM   #3
truckdude239
truckdude239's Avatar
I used an fittings that had platic washers been in there 3 years havent leaked a drop
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-23-2018, 04:20 AM   #4
LS-K
Im sure you’ve might have already made your mind up on what set up to use.
Here is my 2¢.
I initially went with the AN fittings and nylon washers. That only lasted me about 2K miles before I sprung a leak.
I went with the original GM fittings at the case that use the C-Clip lock thinks and then use 98-02 Camaro Camaro hardlines. I made a few tweaks to the hardlines, nothing crazy. I ran the hardlines till the reached, let’s say the crank pulley. I cut them off and used Earls hardline to AN compression fittings. From there I ran some fabbed up hoses to my front mounted trans cooler.
LS-K is offline   Reply With Quote
