Old 02-09-2018, 07:48 PM   #1
bob8619
Speedometer stuck on 70mph
My new project 68 came without a speedometer cable. Should the speedo needle fall on zero mph when nothing is connected to it? I installed the new cable and the speedo just spins randomly around, I don't know if I damaged it by hooking it up before it was on zero or if it was already shot.
1968 C10
bob8619 is offline   Reply With Quote
Old 02-09-2018, 07:52 PM   #2
demian5
demian5's Avatar
Re: Speedometer stuck on 70mph
Id like to see video of that!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-09-2018, 08:40 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes. Dunno what else is wrong with it though....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 02-09-2018, 09:11 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
You will find oil has found its way into the speedo head mechanism,,,
the speedo head needs to be cleaned or replaced...
AussieinNC is offline   Reply With Quote
Old 02-09-2018, 10:25 PM   #5
bill3rail
bill3rail's Avatar
Step on the brakes? J/K
Should drop to zero with no cable attached.
I don't think you can damage it unless you hook up the cable while driving!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 02-10-2018, 04:40 PM   #6
toolboxchev
If its going that fast, don't fix what aint broke!
toolboxchev is offline   Reply With Quote
Old 02-11-2018, 04:17 PM   #7
bob8619
I solved the issues that I described but now a new one has appeared. It seems to be accurate (compared to gps speedometer) up until 25+mph. Once I reach 25mph actual speed the truck speedometer says 50mph and it just gets crazier the faster I go. I figure its shot but figured I'd see if anyone here knows for sure.
1968 C10
Old 02-11-2018, 04:33 PM   #8
Grumpy old man
Grumpy old man's Avatar
Sounds like your problem is in the cable and not the speedometer ...
Old 02-11-2018, 04:35 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
If you want to send it to me, I can go through it and make it work correctly or just send you a good working one.
I have a certified speedometer calibration tester and tools to make your speedometer work like new.
Let me know if interested,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-11-2018, 04:41 PM   #10
bob8619
Tom
Thanks Tom, I'll mess around with it a bit more and if no luck, I'll take you up on that offer.
Grumpy, I know that the the cable can stick if not lubed well enough and causes a jumping needle, but it can also just cause it to read faster than actual? And just in case it sounds like I'm challenging your thought, I assure you I'm not.
1968 C10
Old 02-11-2018, 04:47 PM   #11
TBONE1964
Cluster King
TBONE1964's Avatar
Here is the test to know if your trans gears are the issue or the speedometer.
Drive on a portion of road where you can go a measured mile, like on a freeway. Don't worry about your actual speed but drive the mile and see what the odometer does. If it matches and rolls one mile for the measured mile driven, then the trans gearing is good. If it does not and goes over or under a mile in the same driven mile, then you look at different trans gears based off tire size and rear gear ratio.
If the measured mile tile passes, then your probelm is speedometer calibration.
Hope this helps everyone understand how it works.
Thank you,
Tom
Old 02-11-2018, 04:55 PM   #12
bob8619
But its within a few mph of the gps reading when under 25 and then once I go over that it jumps to being off my 25mph give or take a few. I wouldn't expect a big jump in inaccuracy if it was just related to trans gear. Sounds more like calibration to me wouldn't you agree?
1968 C10
Old 02-11-2018, 05:01 PM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
Yes it sure does sound like speedometer calibration. I wanted to explain how you can eliminate the trans gearing as the issue.
