Old 03-05-2018, 12:10 AM   #1
'65 chevy lover
Throttle linkage
I need the linkage and return spring that connects the floor peddle to the carburetor. I looked at Summit and, there are so many different ones I have no idea which one I need. Could someone please head me in the right direction? Thanks in advance for any help.
'65 chevy lover is offline   Reply With Quote
Old 03-05-2018, 12:32 AM   #2
Captainfab
60-66 Nut
Re: Throttle linkage
What year of truck and what engine?
Old 03-05-2018, 04:15 PM   #3
'65 chevy lover
'65c10 with 383 stroker. Below is pic of carb and part of throttle in engine bay.
Old 03-05-2018, 05:22 PM   #4
forestb
forestb's Avatar
I have used threaded rod with two heim joints. That worked pretty well.
forestb is offline   Reply With Quote
Old 03-05-2018, 05:23 PM   #5
forestb
forestb's Avatar
I used threaded rod wit 2 heim joints. That worked pretty well.
Old 03-05-2018, 06:27 PM   #6
Southcity
Southcity's Avatar
The swedged aluminum throttle linkage rod from Speedway (in black or Aluminum color) makes for a very tidy and sturdy linkage setup, don't forget the right hand and left hand heim joints for each end.
https://www.speedwaymotors.com/Swedg...read,3944.html
This swedged throttle linkage tubing is tapped 3/16" (10-32) LH and RH thread. One end of the throttle rod will have left hand threads, and the other end will have right hand threads. Made of 5/16" x 0.049 round aluminum tubing.
Note: When measuring for your tube length, you will want to allow 1.5" in length for the rod ends (3/4" of length for each end when calculating your eye-to-eye measurement. For instance, an eye-to-eye length of 11.5" would require a 10" swedged tube.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-05-2018, 07:25 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
This is how I did mine. I used the original rod.
DPowers is offline   Reply With Quote
Old 03-05-2018, 08:08 PM   #8
'65 chevy lover
Thanks for the reply.
Old 03-05-2018, 08:09 PM   #9
'65 chevy lover
Unfortunately I don't have the original I'd really like to use the same piece as original...
Old 03-05-2018, 10:15 PM   #10
DPowers
DPowers's Avatar
Let me look. If I have one- you are welcome to it.
Old 03-05-2018, 10:54 PM   #11
'65 chevy lover
That would be great!
Old 03-05-2018, 11:08 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That's how I did mine on my 66.
My 65 has the original linkage.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-06-2018, 12:29 AM   #13
Captainfab
60-66 Nut
You are also going to need the bushing and sleeve that goes in the large hole in the throttle arm on the carb.
https://www.summitracing.com/search?...ord=HLY-26-103
Old 03-06-2018, 12:14 PM   #14
'65 chevy lover
Ok, thanks, Captain!
Old 03-06-2018, 12:41 PM   #15
Macdaddy1
I just did mine and used a 12 inch 3/16 throttle rod form e-bay that had the ends and bolted one to the carb and the other to the accelerator bracket and adjusted. It seem to work great.
Macdaddy1 is offline   Reply With Quote
Old 03-10-2018, 03:44 PM   #16
DPowers
DPowers's Avatar
Going to over where my part trucks are this afternoon to check.
Old 03-10-2018, 04:24 PM   #17
1966c10shrtbd
1966c10shrtbd's Avatar
This is where I found my parts
https://www.classicparts.com/1947-72...ctinfo/89-523/
https://www.classicparts.com/1960-66...ctinfo/89-527/
1966c10shrtbd is offline   Reply With Quote
Old 03-10-2018, 05:28 PM   #18
'65 chevy lover
Cool, I appreciate it!
Old 03-11-2018, 12:39 AM   #19
DPowers
DPowers's Avatar
PM sent
Old 03-11-2018, 08:37 PM   #20
rvrfoot
I made my own.Name:  DSCN0836.jpg
rvrfoot is offline   Reply With Quote
