Old 03-05-2018, 01:07 PM   #1
lukespence
[noob with a deadline] engine wiring
Hey guys, I am trying to get my truck running by spring break to get it out of my house cause I am renting my house out. When I bought my 1963 chevy c-10 there was no wiring in the engine bay at all. I pulled the original 283 and put a 350 in out of a 67, but now I need to wire everything up and don't know what to do!. Help!!. Is there a wiring harness for us to buy online or will we have to jerry-rig something up?
Luke
lukespence is offline   Reply With Quote
Old 03-05-2018, 01:32 PM   #2
gizmoduck81
Junior Member
gizmoduck81's Avatar
Re: [noob with a deadline] engine wiring
Luke
Check out American Auto Wire. They have complete kits or I believe you can buy them piecemeal. They should be able to help you out with any specific requirements as well.
gizmoduck81 is offline   Reply With Quote
Old 03-05-2018, 04:20 PM   #3
pdxhall
pdxhall's Avatar
I agree with gizmoduck, I've got the American Autowire complete update kit. It has everything you will need, and great instructions. Each individual wiring phase is bagged separately with instructions.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is online now   Reply With Quote
Old 03-05-2018, 07:26 PM   #4
DPowers
One foot in front of the other
DPowers's Avatar
Another option:
http://www.wiringharness.com/
DPowers is offline   Reply With Quote
Old 03-05-2018, 08:11 PM   #5
PGSigns
PGSigns's Avatar
And then there is the wire with the two alligator clips and the screw driver. It will get it to run. Are the plugs still in the firewall? There are engine harnesses available. In the FAQ section there are links to the wiring diagrams so you can evaluate what you have still in the truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-05-2018, 09:53 PM   #6
raidmagic
raidmagic's Avatar
Yeah, how much does it need to move? How far? With about 20' of wire you can have it running.
raidmagic is offline   Reply With Quote
Old 03-06-2018, 12:40 PM   #7
lukespence
just down the driveway and around the corner!
Old 03-06-2018, 01:53 PM   #8
raidmagic
raidmagic's Avatar
Is it HEI? One power wire to the dist./ coil. Battery to the starter. You can use a remote trigger from the parts store for to start it. That will get you down the road.
Negative battery cable to the block
Positive battery cable to the starter solenoid
Wire with a pushbutton from +12V to the S terminal of the starter solenoid (or a remote starter button if you have one)
Wire with a toggle switch from +12V to the BATT terminal of the HEI.
Or you could just twist the wires together. Not that I've done that.
1963, 1967, 350, chevy, small block
